Question about Hitachi 42HDT52 42 in. Plasma HDTV
Can't change channels
Suddenly the TV won't change inputs or channels - either by using the original remote, or the buttons on the side (Hitachi 42hdt52). Volume and power buttons work fine.
  • woods595 Aug 19, 2008
    I am having the same problem. I have it at a repair shop now and they can not figure it out either.
I had exactly the same problem. I finally found the power button on the underside of the TV. It is well hidden and to find it, you need to run your fingers underneath the panel. Turn it off for a minute or so and turn it back on and then turn on the switch on the panel on the upper right side where the channel and volume buttons are. It works.
Posted on Nov 14, 2008
What channel on the hci tv can I view my dvd I hooked the red yellow and white jacks into the back of tv but cannot find a channel to view the dvd
You probably need to find a Source or Input button or menu item. Change the source from TV (if that is your current source) to A/V (or composite video). Depending on the model, there may be a source/input button on the TV. There will always be a sourc/input button on the original remote. If you are using a universal remote, you may need to try a different code to get the function to work.
On a few TVs, you can find this in one of the sub-menus. However not all TVs let you change the source in the Menu system.
I hope this helps. Please add a comment with the model of the HCI TV and whether you have the original remote or a universal remote to control the TV if you would like me to find the specific information for your TV.
(For example, the HCI RM22 III remote has the input button on the left side just below the power button.)
Dec 21, 2016 | Televison & Video
Won't channel up and down, stuck in input mode
Good morning Cheri
try restarting the tv, just disconnect all electricity for 30-60 sec.
connect again. If that does not work, Try set- up on the menu, if you get the apparatus to obey you and leave the input mode.
If that does not work I always restart the router and "exchange"box,
enjoy your day
Mar 25, 2014 | Sanyo DP50749 50 in. Plasma TV
How to change input on older model magnavox tv remote
Some of the old sets input/tv-video are only on the original remote.
If no buttons exist on the set you may be out of luck---One possible thing to try depending on age of set:
Some if you scan the channel button down below channel 2 you may find the input is on a channel for example 91-99.
Good luck and hope you get it working.
Dec 06, 2012 | Televison & Video
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
Hitachi TV turns on but cannot get channels.The blue light and power lite comes on. Changed batteries in remote, still no channels
sounds like a simple input problem, find the input button on the remote or the tv and change the source input until you get a picture,
May 28, 2011 | Hitachi 42 in. Plasma TV
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
Change from TV mode to AV mode for a Hitachi C28W4110SN
There should be buttons somewhere on the TV itself to switch input modes. Look around where the power button is located and see if there is a menu button you can access. Then use channel up/down and volume up/down to scroll thru modes to find input
Hope this helps
Apr 27, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from:
Mar 16, 2008 | Toshiba 24AF45 24" TV
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
No Video
From the manual (search Google for CM27101S): Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve connected another component to your TV(such as a VCR) using the Video/Audio input, you will want to be able to view the signal from the component. To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows: 1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear. 2 Use the WCHVbuttons to select ? Input ?. 3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?. 4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
Aug 07, 2006 | RCA F27676BC TV
Hitachi 42HDT52 42 in. Plasma HDTV Logo
481 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
