Question about Samsung Office Equipment & Supplies
Black Toner not adhering to paper on CLP500. The machine has been a permanent problem since I have had it. I thought of dumping it, but was willing to give it once last chance. Purchased New Drum, Transfer system and Toners, which is why I am annoyed. Incidentally I regularly have the Waste toner full problem, when it is actually empty, but gather this is a well known problem and know how to fix it.Cannot believe it was shipped with such an elementary error.
  • 3,037 Answers
Are you using any special king of paper? Is there ink on the paper or is it printing poorly to begin with. Do you have a picture of a piece of paper that has been printed on that you could post here. If so, please post it. Will be waiting for your response to my questions
Posted on Aug 13, 2008
Double image on ricoh mpc 2800
Make sure that the printer is set properly for the weight of the paper. If it is 28 pound laser color paper, set it up for middle thick, etc., in (User Tools / System Settings / Tray Paper Settings). It will run the machine slower, so the toner will more fully melt and adhere to your paper.
Jan 28, 2015 | Ricoh Aficio Mpc2800 Digital Color Copy...
I have Avery Gloss labels for laser printers and have a Ricoh laser printer. The black toner is adhering to the labels and the other colours are not
Look to your menu for a paper setup and find the one for label or card stock and choose that. Thicker paper or labels require more heat to fuser the toner to the media.
Feb 11, 2011 | Ricoh Aficio CL7200DL Laser Printer
Brother MFC-8220 leaving ink on printed docs. How do you clean that?
That's usually a bad toner cartridge that dumps too much toner per print. Buying a new toner cartridge should fix it. You may need to wipe up a little spilled toner inside. Just use a dry cloth, and be very careful around the little black levers that stick up to detect the paper.
There are other manufacturers who sell toner for these, but some of them have toner inside that's so hard to stir, it breaks the gear in the machine. That makes a very expensive repair for the little money you save on generic toner.
Dec 03, 2010 | Brother MFC-8220 Fax
The toner is not adhering to the page. If you wipe your finger on the printed page the toner brushes off
You need to replace the fusing unit. This is the part that gets hot just before the paper exits the machine. It "fuses" the toner onto the paper. Strange that you are not getting a fuser code if it is not heating up. You may have lost the fusing pressure somehow.
Goos Luck
Nov 22, 2009 | HP LaserJet 3330 All-In-One Printer
Dell 3110cn Color Laser Printer Certain colors will not adhere to the page when printed on heavy paper. Combination of green/black wipes off the paper when rubbed.
Either the paper is just too thick for the printer to fuse the toner correctly, or you've NOT selected the right paper type (in the printer driver options.
If you're just printing that same as you would on ordinary A4 paper, the fuser can't get enough heat through the thick paper to fuse the toner.
May be a wrong toner problem if you've done this successfully before, but only had this problem since changing toner cartridge(s)
Oct 19, 2009 | Dell 3110cn Laser Printer
The toner of the printed document does not adhere quite well on the paper. Wipping wich the pand over the paper the toner will come off partly. I thought it was a problem of the toner, however after buying...
If you've been using Okidata original cartridges then it sounds like there's something wrong with the fuser unit in your printer. The fuser is what heats the paper to "melt" the toner onto the page. If you haven't been using Okidata cartridges, the one you purchased could either be laying down too much toner or low quality toner that can't be properly adhered to the page.
Oct 17, 2009 | OKI B4100 Laser Printer
I have a Ricoh 2232c - ? to install blk developer unit
Press "clear/stop" button, then "1" then "0" then "7" then press and hold "clear/stop" button for ~ 3 seconds. This sequence has to be completed within 5 seconds. This will get you into SP mode. (Don't mess with any other settings in SP mode because this could damage the machine). Now, you will need to navigate to SP5 area, then scroll thru until you find 999 (5-999) Good luck.
Aug 26, 2009 | Ricoh Office Equipment & Supplies
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Toner does not adhere to paper
You have got a warped fuser this is the hot thing that cooks the toner onto the paper. Your best trying to locate a fuser unit for the machine this will solve your problem.
May 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
