Question about HP Photosmart 3310 Printer
Ink system failure
Getting a error 0xc18a101
  • 1 more comment
  • sionah Sep 04, 2008
    I have an hp all in one photosmart 3310 printer.
    Same error code as posted here.
    Tried the fix but on the step #2 it shows information menu on the display.
    How can I fix it?
    Any suggestions, ideas or help would be highly appreciated.
    Thnx
  • Anonymous Dec 08, 2008
    oxc18a0001
  • Anonymous Feb 01, 2009
    Same as you.I can't find “System Configuration Menu
Printer is hp ps 3310
step 1 is OK
step 2 can't find “System Configuration Menu” I find "infomation menu" not same as you say
Posted on Sep 01, 2008
  • 234 Answers
Step1: Get into support menu by following the steps:
Press & hold the * Key then press # key.
Display says “enter special key combo”, Press OK on it.
Press & release 1, 2 & 3 keys in sequence.
Display says “Support” & FW rev. then go to Step 2
Step 2:
a. Press and release the right arrow button twice.
b. Display should say “System Configuration Menu”. Press and release the “OK” button.
c. Display should say “Hardware failure status”. If not there already, press the right Arrow Key over to “Hardware failure status”,
d. Press and release the “OK” button.
e. Display should say “Hardware failure status: Clear. Press OK to clear”. Press and release the “OK” Button.
f. Display should say “Hardware failure status Cleared. Press Cancel to continue”.
g. Press and release the “CANCEL” button as many times until the “Welcome to Photosmart Express” window appears.
h. Turn the unit off and then on by using the power button on the control panel, continue with the installation/setup of the unit.
1. If the error is still there, then perform the power cycle.
If it works it is good, if not if your printer is in warranty you will get the unit replaced for free from HP.
If not call HP and get a Out Of Warrnty Upgrade option where you will get a good discount,
Call 1800 474 6836
Good Luck
Posted on Aug 29, 2008
  • Rakesh Pramod
    Rakesh Pramod Sep 06, 2008
    Please do not go as per the error message you get.
    Because the error message means a lot, like the error message you have 0xc18a0201, as per this message the unit has to be replaced (As i have worked with HP i know which error message has to be replaced or can be fixed)
    But you can try this steps once. and i would not garauntee to fix your issue, But Better to give a try.
    First of all unplug the power cord from the All-In-One from the printers end aswell as the power outlet.
    Leave the cable unpluged for atleast 1Min.
    Then connect the cable direrctly to wall outlet without the surg protector. and then connect it back to the All-In-One.
    If the message is still there.
    Press the # and * key in the All-In-One (The Display will say enter special key Combo)
    Then press no 1, 2 and three.(The display will give some information) Ignoge the display.
    Press the right arrow key till you see System Configuration Menu> Then press “OK.
    1. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
    2. Press and release the “OK” button.
    3. Display should say “Hardware failure status: Clear. Press OK to clear”.
    4. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
    5. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    6. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    7. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    8. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
    9. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    10. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
    "PLEASE TRY TIHIS RESET ONLY ONCE"
    If ir reoccures replace the unit. you can call HP and get the unit replaced. if it is Warranty.
    If not you can also go for a Out Of Warranty Upgrade Option.
    Good Luck and Regards
    Rakesh Pramod
  • 14 Answers
I think your printer also "slipped a gear". Refer to http://www.fixya.com/support/t439120-ink_system_failure_error_message
Posted on Oct 07, 2008
Error code OXC4B827F
This is an Ink System Failure message. I would try this guide. 'Ink System Failure' or a '0x...' or a 'C2...' Error Message Displays on the Front Panel. To help resolve the issue.
If that doesn't work, please call our technical support at 800-474-6836. If you live outside the US/Canada Region, please click the link below to get the support number for your region. http://www.hp.com/cgi-bin/hpsupport/index.pl.
Oct 12, 2015 | HP Officejet 4630 Inkjet Multifunction...
Tip
Hp Ink System Failure: Ink System has failed. Unable to print. Error: ?0xc18a??
Hp Ink System Failure: Ink System has failed. Unable to print. Refer to Printer documentation. Error: “0xc18a…” Products that may encounter this problem: (A survey based on Fixya.com database)
HP Photosmarts:
C6180, C6288, C3210, C3310, C5180, C7280, C6188, D7460, C8250, C7180, C5183, C6288, C7268, C6150, C7360, C7160,c309a, C6380 . (Ink System Failure)
As you can see, only Photosmarts encounter this problem, however that does not mean that other HP printers types wont be affected.
Common Error Codes:
0xc19axxxx, 0xc18a0001, 0xc18a030a, 0xc19a003f, 0xc18a0201, 0xc19a0003, 0×05d1281, oxc18a0307, 0xc18a101, 0xc052281, 0xc05d0281, 0xc18a0306, 0xc19ac3ff, 0xc18a0101, 0xc19a0031, 0xc18a0007, 0xc18a506
Troubleshooting:
When you have one these error messages on your printer screen there are two things that you need to consider to enlighten yourself on what to do when you are in this kind of situation.
Is your product in warranty or out of warranty?
For In-Warranty products, please do not do any self troubleshooting. Immediately contact HP technical support to have them troubleshoot the problem for you. In most cases, printers with these error messages are replaced but you must also be patient and follow the technical support’s instructions and basic troubleshooting. I recommend you to read our article on how to contact HP technical phone support.
For Out-of-Warranty products, I am afraid you have to exert extra effort to be able to resolve this issue on you HP printer. Below are ways that I recommend to resolve this.
You need to do some basic troubleshooting steps below and hope that it would fix the problem.
  • Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  • Open the cover of the product and remove the print cartridges.
  • Close the cover and wait for the Insert Ink Cartridges message to display.
  • Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Open the cover and reinsert the print cartridges.
  • Close the cover. If prompted, print a calibration page.
  • Print a Self Test to verify product is functional.
  • Reconnect the USB cable, and try to print from the computer.
  • If the error is still there continue reading…
Generally, when you have this type of error message displayed on your printer screen your printer may be permanently damage, resetting your hp printer may fix it in some cases but it is almost certain that the problem wil reoccur.
“0xC18′ errors may also mean that the printer’s temperature is below 40F/5C.. Try warming up the printer and try again. If you have reached this part already and still the problem is not yet fixed, do not worry I still have 3 more suggestions to help you with this problem.
1. Chat for free in real time with an HP online support agent. Hopefully, HP can be able to support you on this.
2. I have stumbled upon a solved problem at fixya wherin user SagarJD was able to provide a special reset for the ink system and was able to successfully solve the ink system failure with error:OXC18a0205. You can try following his procedure.
3. If you have reached this part already, then most probably your product’s Ink System is permanently damaged and it is certainly unrecoverable. Servicing the printer is not what I recommend on this. Instead, I suggest you call HP tech support and upgrade your printer to newer model.
By the way, there is another way. By now you are getting ready to replace your printer, right? Why don’t you this last solution, and try it to resolve this issue. This step is only intended for OUT-OF-WARRANTY products ONLY as doing this step on IN-WARRANTY products can VOID YOUR WARRANTY. Do this step at your own risk.
There is a CMOS battery inside your printer that keeps track on your printer’s history. Ink replacements, resets, etc… Try resetting the data stored on your Hp product by removing the CMOS battery and then putting it back in after 30 minutes. Unfortunately I could not tell where you can find this battery inside your product as location differs for different products but here’s what the battery should look like inside your printer.
on Apr 28, 2010 | Office Equipment & Supplies
Ink failure ink system failure error oxc 18a0001
The "ink system failure" error is caused by air in the ink feed tubes. We have 2 articles posted on our web site giving step by step guides to purging the air from the tubes and clearing the error. You can find the articles at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | HP Photosmart C8180 InkJet Printer
Ink system failure error Oxc18a0306
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure Error: 0x05d1281
Ink system failures is a very serious problem on HP printer systems. Ifyou have this problem you should be ready to replace your printer.However there are still troubleshooting steps that you can do to try toresolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 14, 2008 | HP Photosmart C7180 All-In-One InkJet...
Ink system failure
hp photosmart c7288 all-in-one
ink system has failed unable to copy receive faxes or print refer to printer documentation error oxc19a0002
Nov 25, 2008 | Office Equipment & Supplies
Ink system failure
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Sep 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Nov 16, 2007 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
603 people viewed this question
Ben Johnson
