Cd rom not detected
Hi
my tray doesn't open on pressing the button on the drive, the cd rom is not detected.
i dont hear it spinning and i dont see the light. and i don't see the cd rom drive in the device manager!
some one can help pliz
    Genius:
  • 2,028 Answers
Sounds like the CD drive has failed. First try removing the drive from the machine, clean the connectors and put it back, make sure it seated firmly and properly. If it still doesn't work, then do a system restore. At this point, if it's still not working, then it has failed and will need replaced.
Posted on Aug 13, 2008
SOURCE:
1st sorry for my bad english ... but my cd rom dont want to open . when i press the button the green light turns one and i hear a sound, but the cd rom dont open , can u solve this please? ... thnx
This happens when the drive motor inside dies.
You can take a small paperclip and insert it into the tiny hole you find in the face of the drive to manually open the tray. Use this method to remove any disk stuck inside of the drive currently. go to www.newegg.com for a cheap replacement drive.
Aug 24, 2011 | Samsung (SC-152) Internal 52x CD-ROM Drive
Greeting I just bought "LG
Greetings... I think your having a problem with your hardware DVD R/W.
based on your observation...
1) The dvd rom drive is detected on your windows xp and by pushing open/close button still working... " this indicate that the power and SATA / IDE cable was properly connected.
2) And you've said "NOT SPINNING".... "means you have undergo testing by touching or listening DVDrom drive while the disk was inside after closing the disk tray which is right"
Therefore your DVDrom drive was defective... you can also check by opening the metal cover to see if the disk was spinning and if the laser of optical lens released a red light.
Jul 12, 2011 | LG GSA-2166D DVD RW Dual Layer Burner
Describe how you insert a dvd into a laptop
Hi Eunice, just want to clarify, for lenovo notebook if it doesn't have DVD drive you can use external DVD drive to access DVD CD. DVD external drive is just plug and play device once attached in your USB port, it will automatically detected and once detected you can use it already. Just install Burner application to burn some files if your DVD is capable of burning CD.
Jun 22, 2011 | Lenovo 3000 Y410 (59012354) PC Notebook
How do you open the cd port? i dont want to break it...
Hi, I assume you have tried to open it in the usual way by pressing the eject button. If this has not worked, switch on the machine. Get a large paper clip, and straighten it out. Near the eject button on the tray, insert the paper clip into this hole and push it in and as you do so the tray should open. Hope this helps.
Dec 31, 2010 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
LG CD-ROM not ejecting the tray
you need a pin..ir a small object...
do you see the small hole in the front of the cd rom??/you need to hit it so that it will open...
try it first...
hope i've help you.. rate me,..
Feb 06, 2010 | Computers & Internet
HP d7 notebook cd room drive will not open = (
It the CD Rom drive has a tray that comes out there is probably a small hole in the door to it. You can straighten a paperclip, poke it in the hole, and press......that will release the tray so it will open. Some notebooks do not have a tray and do not have the hole, so I hope you are in luck.
Jan 01, 2010 | HP (176135-630) (176135630) Internal 48x...
The door on my cd rom cant not open when i eject, i dont hear the motor but the light shine just at start up
Look on the front of your cd-rom, there should be a small hole somewhere just under the tray portion. Turn off your machine (to avoid possible short-circuit issues) and use a thin piece of wire (ie: a straightened paper clip) and insert it into this hole. Push it gently, you will be able to feel the unit unlocking itself and the tray will open slightly. Now you can use your fingers to pull the tray open. Be gentle when opening, you don't want to mess up the gearing.
Oct 07, 2009 | Computers & Internet
Help
Your CD-ROM may still be functional. The tray may just be stuck, instead of broken. First let's remove the CD.
Get a large paperclip and bend the end out straight. Look for a tiny hole underneath the CDS tray. Push the end of the paperclip into it, and it should open the CD tray a little. Then pull it out the rest of the way and get your CD out. Then try pushing the eject button on the CD-ROM to get the tray to go back in. It may take several trys. If that does not work push the tray in, slowly. Then try the eject button again. I hope that works.
If it does not you can continue to use the CD of course (lots of CD-ROMs have paperclips hanging out of them. And I've seen the problem go away, occasionally, after continued opening and pushing back the tray.
Mar 10, 2008 | Acer Aspire L100 PC Desktop
Drive does not opens even when the button is pressed number of times.
One of the things that I have noticed about these drives have been the complications that will be experienced with the tray motor assembly. Often the gears on the tray that connect to the motor become worn from jamming and use. Another problem that takes place is that the tray never returns to the proper position once the disk is inserted.
I would like to know the age of the drive since the MTBF is only 70000poh
Feb 27, 2008 | Sony (CRX320E-10) CD-RW/DVD-ROM (Combo)...
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
114 people viewed this question
Ekse
Marvin
Marvin
