Check the start relay fuse.....................ok
When there the key is on and the truck is up to operating temp(hot) the relay clicks when the key is turn to the on position (no cracking of engine),but also click back after the truck runs for 1-3 sec and shuts off. Freezing the start relay fuse to see if its the problem. Promblem is truck shut off after hitting operating temp. yes there is spark,there is no fuel pumping out of injectors of the throttle body.
Check the Start relay, fuse, replace the fuel filter, Check for appropriate voltage at the pump.
