Question about Behringer FBQ6200 Home Equalizer
That is not my product! Mine is FBQ1502! I cant use your info!
    Brigadier General:
  • 6,966 Answers
Hi again,
Thank you for correcting the model. To my understanding the FBQ1502 also uses ¼” TRS connectors same as the FBQ6200.
Posted on Aug 13, 2008
Behringer FBQ1502
An old trick we use to do is use the TAPE IN/OUT of the receiver and hook it to the stereo RCA IN/OUT of the equalizer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Behringer FBQ6200 Home Equalizer
Manual behringer fbq 1502
you can download a manual at this link (it's a link direct to the manual, so you only to save or print it, it will appear on your screen)
http://www.behringer.com/assets/FBQ6200_FBQ3102_FBQ1502_M_EN.pdf
There is a quickstart guide also, on the page where I got the manual download from
http://www.behringer.com/EN/Products/FBQ1502.aspx
24.August.2014
Aug 24, 2014 | Behringer Audio Players & Recorders
I want to set up my behringer fbq1502
It sounds as if you are not running in series. I assume you are in an insert on the mic channel. The insert send should go to the first item in the chain, then from the output of that to the input on the next item and so on until the output of the final item in the chain goes back to the return on the insert. This is applicable to the type of equipment you have detailed, in some cases however you may be running effects in parallel. Your case is definitely a series situation.
Mar 08, 2014 | Behringer FBQ1502 Ultragraph Pro Dual...
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
Nov 06, 2013 | Behringer FBQ1502 Ultragraph Pro Dual...
Circuit diagram for ultragraph pro fbq 1502
and you are skilled at large scale smt replacements..
Feb 18, 2013 | Behringer Fbq1502 Ultragraph Fbq Pro 15...
I would like know how to connect FBQ1502 to Mackie miixer
come out of the mixer with your main outs ( L/R ) and go into ch 1. ( l ) and ch. 2 .(r) and them come out of unit to your power amp and power amp to speakers.
Aug 26, 2011 | Music
Hi...
Hi again,
Aug 12, 2008 | Audio Players & Recorders
Product key for offce 2002
sorry but that would be illegal to give you a key
Jan 20, 2008 | Computers & Internet
Behringer FBQ6200 Home Equalizer Logo
163 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
