Question about Sony Handycam CCD-TRV37 Camcorder
Not charging? I just got a new battery, worked great but now i need to charge it. when i plug it in, it flashes an empty battery symbol, doesnt show the battery with the blackened-in parts. is there another "button battery" i need to replace, and where is this battery? PLEASE HELP i am going on vacation in 2 days. Thanks!! Kisses!
  • queenmommy73 Aug 13, 2008
    duh, ive had the camera for years, ive done all that.
    i have a plug that connects to a box that plugs into the wall. there is no light of any kind anywhere. the battery charges while its in the camera
  • 10,594 Answers
Please plug the camera charger in AC Outlet and hook it to camera. Check camera power turn ON, works fine? if OK, switch it to Standby / Off mode. Attach battery and check any charging light lit? If yes, leave the camera on charging position for 4-5 hours until its charge light flashs or turn Off. battery is chaged now. Have fun :)
Posted on Aug 13, 2008
  • Shahid Electronics
    Shahid Electronics Aug 13, 2008
    It was not mentioned in post that you have this for years. any way, pls check n confirm camera Charger because if it got defective, wont charge battery or power up camera.
    I got it, thats why asked you to turn camera power on while hooked in with charger to confirm the charger working or not. If camera powerd up and works fine, turn it off and attach battery, so camera will start battery charge. Hope this info will help you.
SOURCE:
My Samsung galaxy 10.1 tablet will not charge. It keep flashing between an empty battery symbol to a flashing yellow battery symbol. going Off and On. I can not get it to turn on at all. Im pretty sure...
Hi my Samsung galaxy tablet is flashing icon on and off signal but not charging? I have tried turning off for 30seconds still dead what should I do?
Jul 30, 2013 | Samsung Galaxy Tab Tablet PC
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
Nyko charger won't charge
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
Feb 07, 2012 | Nyko Charge Station 360 For Xbox 360
HP Pavillion ZV6000 - Charging Problems
hi
It seems that your laptop is not charging so in that case you must take your laptop to your vendor.For more support you can visit---------http://robs-tech.blogspot.com/2009/06/free-solution-regarding-computer.html
Jun 22, 2009 | HP Pavillion ZV6000 Notebook
Shows fully charged (plug icon), but isn't taking a charge. A;ready tried reboot/restore.
Get a can of air and blow it into the 30-pin connector and headphone jack to clear the phone of dust and build-up. This should clear up the problem. I learned this from an Apple Store Genius Bar associate.
Jun 01, 2009 | Apple iPhone 3G
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Symbol MC35 refuses to charge either via mains adapter, usb connection or incar charger. Charging indidator flashes to indicate the unit is charging but the battery life remains at 0%. Any useful tips or...
Try loading the latest Operating System files from Motorola. If that doesn't help you can try getting a new battery. If that doesn't work it will need to go to repair.
Apr 28, 2009 | Motorola MC35 Smartphone
I have a GoGear device that won't charge
Hi, I had the same problem with my SA31xx, when I plugged it into my PC it made the normal usb sounds and then a flash symbol appeared over the battery on the screen. It would not charge at all, I replaced the usb cable and it now works perfectly. Hope this helps.
Oct 03, 2007 | Philips GOGEAR SA6045 MP3 Player
Sony Handycam CCD-TRV37 Camcorder Logo
333 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
