Question about Belkin Computers & Internet
From Michael Cleary 3 Salters Lane Hastings TN34 3HD 01424 440965 My new N Wireless Modem Router keeps loosing wireless signal. I have been loaned a Netgear "Rangemax" and I am up and running all OK. The techician said that I should receive a new one. My Belkin was purchased at Argos and I do not a receipt. Serial 1274386331569 PIN 67658640
    Problem Solver:
  • 30 Answers
You may change it at the store without receipe showing your credit card (if you used it) of not ask for an exchange instead of a returned. That works with many stores. Good luck!
Posted on Aug 13, 2008
Poor signal with WiFi on my zeepad
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
Dec 13, 2012 | Computers & Internet
Netgear dgn1000 modem router keeps dropping out
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 29, 2012 | NetGear Computers & Internet
Can i use a wireless router with a wireless modem?
Yes you can definitely use a wireless router to work with your existing wireless modem , so you have an option to connect to the signal of the wireless modem of the wireless router. You can also choose if you like to disable the wireless signal of the mode and just use the signal of the router.
Apr 24, 2011 | Arris SURFboard SBG900 Wireless Router...
I have mtnl connection with D-link modem (502T) My connection get disconnected in between download so is there anyway that my modem could restart it self when it looses internet connection.
Signal strength drop or fluctuation are common causes of RF interference.
Try these basic troubleshooting steps:
  • Change the channel on your access point or wireless router.
  • Change the location of your wireless products. Subtle changes (2-3 feet) can make a big difference. Do not put the access point or wireless router in a cabinet or enclosure.
  • 2.4GHz phones, X-10, and bluetooth devices will interfere with your wireless network. Change the location of the base for your phone, or downgrade to 900Mhz phones, or upgrade to 5.8GHz phones.
  • The wireless signal will degrade (or die completely) when going through brick (fireplace), metal (file cabinet), steel, lead, mirrors, water (fish tank), large appliances, glass, etc.
If your wireless connection is only dropping during large file transfers or when a large number of wireless clients are connecting, change the preamble on all wireless devices to short.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
BELKIN F5D8236-4 V2:Router keeps loosing wireless connection
check the range in which you are using the laptop.please use the laptop within 6 meters if you go more than that it is difficult to recieve the signal.
if stil the problem presists then try connecting with wireless internet with some other laptop if the problem presists then it the modem problem service or replace it. if it works fine then the problem is on laptop.check with the dealer.
if you are satisfied with my answer please vote
Jul 13, 2010 | Belkin F5D8236-4 Router
My wireless ADSL2+ Router is having a problem, The ADSL Blink is going off within a few minutes of Internet use, Could you suggest me a solution?
Please check the following
1) secure cable between modem and router. it must not be loose.
2) secure cable between modem and phone jack. it must not be loose.
3) modem and router must not be near to any electromagnetic devices such as halogen lamps, computer speakers
4) cables must not be intersecting to electrical cable which sometimes cause static signals that interrupts internet signals going to modem or router
Feb 15, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Wireless adapter will connect to router for a while, then connection quits. Sometimes it stays on for a while - other times not for very long. Lights on the modem stay on but connection does not return -...
Hi there, sounds like you need to sync your modem and router. First turn off the power to the modem, then to the router. After a few minutes reinstall the power to the Modem then to the Router. Restart your computer and see if you now can connect. Good Luck...
Oct 22, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Low signal(wireless MAXg ADSL Gateway USR9108)
1.TRY siting in a place wth less people ... actually wth my USR9108 i get disconnected even if some one is standing infrront of the modem so stay in a open place wth less people.
2.RESET your modem 3 tymes and configure ur modem by the settings given from the Telecom company.
3.Check ur modem antennae ... bcoz its modem is very FRAGILE... it sometimes have an internal wire break ,,,,
TRY installing ur BRothers antannae on ur modem nd den use it....
May 01, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
GotomyPC Intermittent connection
had same prob. 3 wired an 1 wireless . wireless would not conn. an others lose connection . after cable upgrade it was in router upgrade changed settings in router i had to call maker of comps an get them to reset ip adds took almost 3 hours to get them all working again they will do a remote access help by useing your ip threw your internet company hope this helps
Aug 07, 2008 | Belkin (F5D5231-4) Router
Wireless router keeps loosing connection
go to wireless device and re-configure it
Jun 14, 2008 | Dell Wireless 2350 Router
Computers & Internet Logo
21 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
