Question about Samsung Computers & Internet
Samsung 150S Monitor suddenly super dim
I don't know what happened, but all of the sudden when I start my computer up, the monitor is so dark I can barely see anything on it. I've disconnected and reconnected it and done everything I could think of, but no go. I plugged in another monitor and it works fine. Please help if you can.
Thank you,
Todd
SOURCE: Dim Monitor
I had the same problem, took it all apart and pushed on the socketed chip, it made a click noise and it works now. I also pushed on everything including the variable resistors. First time it's worked since it quit working!!
Posted on Mar 01, 2008
SOURCE: A pink vertical line appears suddenly on the screen
i have a samsung 15inch monitor.which is only 6month old.giving blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help me.my mail id is kakhilesh83@yahoo.com.thank you..
Posted on Apr 04, 2008
SOURCE: Samsung SyncMaster 510N
its time for u poeple to buy a new moniter .....or get it repaired by a prof tecnician.....the electrons which bambard on the picture tube at a point of time they become weak...n they loose there capacity......so the moniter starts dim and after wards when the moniter heats up it get fine !!!!!!!!!!!!!!!
Posted on Sep 01, 2008
blueextc3221
  • 15935 Answers
SOURCE: my computer will not detect the monitor
install the proper driver. a generic windows driver may not be suitable. The monitor should have come with a disc.
Posted on Dec 23, 2008
  • 12 Answers
SOURCE: vg2230wm monitor Will not power on
probably your power supply. Is it a cord direct from plug in for is there a box between where you plug it in and then a small round end that goes into the monitor. This would be the good news. If it plugs in direct then that means the power sopply is in the monitor itself which means more expensive to fix
Posted on Aug 05, 2009
Samsung 21.5 LCD monitor suddenly turned dark. Can this be fixed or should I just trash it?
Your monitor has symptoms of power supply failure. The age of the monitor and the cost of repair will influence your decision whether to repair it or dump it
Feb 25, 2013 | Computers & Internet
My Samsung SyncMaster 205 bw monitor was working a few days ago. And the suddenly some black and white slanted stripes appeared on my monitor. I shut off my PC and rebooted it and nothing came up. My blue...
Sounds like your monitor has croaked. Borrow a monitor from a neighbor, friend or family member just to see if it works. If it works, your monitor is bad. If the borrowed monitor has the same issues then your Video Card in the computer is bad and needs to be replaced.
May 01, 2012 | Samsung Computers & Internet
Samsung RV520 monitor suddenly blacked out
If you turn the monitor on with no video cable attached you should get a message on the monitor "Going to Sleep" or "No Signal" if you don't get anything like this the monitor is probably bad. If you can see a message and it is very faint it is an inverter or back light, usually the first in the monitor that is bad.
Apr 17, 2012 | Computers & Internet
LG Flatron L227WTG goes to black/dim
Your problem is a very common one. That model uses the Aip-0165 power supply board and when the capacitors on the board start failing if can't power up the monitor correctly so you get a dim picture, after continued use the monitor will fail all the way. Here is a link to a repair guide that will show you what to look for and replace on the power supply board to get it back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-a-lg-l227wtg-pf-22-monitor-no-power/
I hope this helps, if so please rate my solution.
Mar 25, 2012 | LG Computers & Internet
I have a 19 inch samsung monitor. suddenly it went dark. Can it be repaired?
Please be more specific about your problem:
1. Is it black or just darker by lower brightness? 2. Is the power led turned on and what color is it showing?
Sep 14, 2011 | Samsung 19" TFT LCD Monitor...
Monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
Flickering, sparkeling, ghosting, you name it. Related to electricity in house?
No, it is not the electricity in your house, I had the same problem. Send it back to Samsung and get a new one. I have had to send my monitor back 4 times!
Oct 28, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
Oct 11, 2007 | Samsung 510N 15" Flat Panel LCD Monitor
Computers & Internet Logo
283 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
