Question about Emerson EWV403 VHS VCR
Stuck tape Yes, the tape protection guard is up and the tape engaged
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Check the tip in my profile
Posted on Jul 17, 2010
Does screen guard really protects the touch screen of mobile device?
yes it really protect the touch screen from scratches and spotted.. some good quality screen guard have anti dust and radiation quality also.
Mar 03, 2014 | Dual Electronics CECT P168 Cellular Phone
Stuck video tape
Is the tape protection guard rotated upward (and the tape engaged with the heads)?
Aug 13, 2008 | Emerson EWV403 VHS VCR
Cassette stuck
Yes, many ideas. The deck has to be opened up and unplugged, then look at why the mechanism will not cycle properly. It is most often a rubber belt that is too loose and taking the unit apart enough to get a new belt in is what is needed. To release the tape rotate the pulley by hand until the head base goes down and the door will allow eject to happen. DO NOT force the mechanism- if it gives resistance at some point go the other way and see if that releases the head base. There are all kinds of different systems that have different cam positions.
Dec 20, 2012 | Audio Players & Recorders
Turn signal just works in the back on the pas. side. HARD TO PUSH THE GAS DOWN SOMETHIMES.
I can answer the signal problem it happened to me, i noticed that water corroded the front left passenger side bulb socket because it got splashed by water due to an opening in the fender plastic guard, i changed the light bulb and the socket than i taped the socket with a good weather proofing 3M Scotch 130C Linerless Rubber tape and a protective layer of ordinary electrical tape and 6 months later NO PROBLEMS, i've also covered the gap in the plastic fender splash guard
Feb 18, 2011 | 2002 Buick LeSabre
Tape loose on dryer lint guard
i would try duct tape , the god of all tapes
Sep 09, 2009 | Dryers
HP Ultrium 920 LT03 Drive - All media is 'Write protected'
It sounds like you have broken the write protect lever (that senses the WP tape switch position ) when you removed the tape.
This is a common problem when people lever out the tape without knowing that this lever helping is holding the tape in the drive.
Yes it will need to go away for a repair i am afraid
Try for this. They charge £295 for the repair (so at the lower end of your quoted prices) but they do then offer a 1 years warranty on the drive so you should be OK for some time to come.
Aug 25, 2008 | HP (DW017A) Ultrium Tape Drive
Safe guard mode
Hi my name is Erick . Have you tried ejecting the tape??? Safe mode just means the tape is stuck or something in the mechanicism is not letting the gear works eject the tape. GOOD LUCK!!!!
Oct 23, 2007 | JVC GR-SXM470A S-VHS Analog Camcorder
Unit in safeguard mode
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Mar 29, 2007 | JVC GR-D290 Mini DV Digital Camcorder
VCR tape stuck
Yes, it is a mechanical problem. While the tape is in fast forward the gears are engaged and locked to provide drive to the spindel on the right, however when you press the rewind button without hitting stop, the gears try to engage the spindel on the left without stoping and reversing (changing rotational positioning), this causes the motor to stop (this emulates a tape jam)the tope is left in and the unload mechanism never spools the tape back in because the motor has stopped. To free the tape, what I do is open up the unit and find the main motor check to see if the belt has slipped, if it has not try to manually spin the motor to engage the unload mechanism and eject the tape.
Dec 18, 2006 | Zenith VCS442 VHS VCR
Can't record
I am having the same problem..
Sep 17, 2006 | Samsung SC-D103 Mini DV Digital Camcorder
Emerson EWV403 VHS VCR Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
