Question about Logitech Z-340 Computer Speakers
Woofer Quit My Logitech Z-340 woofer start humming and after couple weeks it quit work completly. Now only the two spearkers is working. If there was a bad power supply nothing will work, I think. What else can be? Thanks. Nyck
    Scholar:
  • 62 Answers
Check the pin connection it is loose or the pins may be bent. Check Connection to sub hold it in tight if no pins are bent and see if the hum stops. Hope this Helps it is what was happening to my set>GOOD LUCK>If pins are bent straighten them>
Posted on Jan 20, 2009
I have a couple active phobic loud speakers, one is completely out of commission and won't play anything. The other will play sound but only through the tweeter, while the speaker itself does nothing. I...
The tweeter is working but the woofer driver isn't which will change the impedance (ac resistance) of your amplifier output. The other speaker isn't working which will again, change the impedance even more. This could eventually damage the I.C. amps should you apply too much volume to the speakers.
You can turn the volume up to normal listening level and with your finger, slightly press the cone on the woofer in and out a couple of time. Does it engage in sound when you do this? If so, the woofer's coil is damaged and the woofer must be replaced. No sound? Open up the speaker (stereo off) and make sure both wires are fully secured to the woofer. Should they be attached securely, your woofer is probably defective. Should you have a crossover network, you can obtain a good, known working woof and temporarily wire it where the old woofer goes, turn on your stereo (minimal volume) which can verify the network pcb (crossover) is working.
Apr 13, 2011 | Audio Players & Recorders
My logitechh x-530 speaker system just quit, all of it. i moved my computor location from across the room and it no longer worked. i have connected and re-connected but no luck.
Just try testing the fuse in the 3 pin plug first, off chance it may have gone. Then, if that shows as OK, and you feel confident, remove the back of the Woofer and make sure that the AC wires have not come loose (can't remember if there is an inline or separate fuse in the woofer, if there is, i'd check that
Dec 29, 2010 | Logitech X-530 Computer Speakers
JL Stealthbox 10w3 Subwoofer just shut off no sign of problems just quit working im not stressing it out by operating it above its limits its being powered by a JL HD900/5 AMP im concerned it might be...
If this woofer is a dual voice coil woofer and if you are running your amp bridged or in mono would suggest try wiring your woofer in series.But before Idid anything I would unhook the woofer from the amp and pop it with a battery to make sure your woofer is still connected.
Sep 05, 2010 | Jl Audio 10W3v2 Car Subwoofer
Low sound and buzz from speakers / Hum noise from sub-woofer
Select Start > (right click) My Computer > Manage
In the Management window select > Device Manager
Next to Sound, Video and Game Controllers click the + sign
A yellow triangle will signify a problem so if one is present, right-click that device and select Properties
You can then choose to update the driver
For more details check Dell Xps 420 Manual.
Dell Xps 420 Manual
Apr 14, 2017 | Dell A525 Computer Speakers
Short in subwoofer wire - Altec Lansing computer speakers & sub
yes, you can splice the cables and put on a new connector, goto radio shack with the old connector and im sure they will have one you can splice right onto it. ive done this many times with varios equipment "headphones speakers etc" it may take a couple of tries to get the wiring right but if its just one speaker there will most likely be just 2 wires, if you wire it up and it doesnt quite sound right, wire it the other way. speakers will work wired backwards but wont sound quit right so if it doesnt, rewire it and it should. good luck and i hope this helps!
Jan 15, 2010 | Altec Lansing ADA 885 Computer Speakers
Freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Sep 06, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Logitech X-240 woofer
you should google it and find a woofer of the correct size with at least 8 ohms to be safe. (more ohms= less risk of fire!) good luck!
Jul 26, 2008 | Logitech X-240 Computer Speakers
Sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
May 15, 2008 | Audio Players & Recorders
Logitech Z-340 Computer Speakers Logo
246 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
