Question about Panasonic Office Equipment & Supplies
ERROR CODES F60 CALL SERVICE FOLLOWED BY 50FF3F00. ALSO GETTING U18 ERROR CODE FOLLOWED BY REMMAND DOC AND 18C01F00
5 Suggested Answers
  • 2072 Answers
SOURCE: xerox workcenter c2424 error code 39,014.40;33151
Could be a dirty scanner. Not much to check, it is a lamp issue.
You can try disconnecting the cables to the document feeder and scanner. The one on the right side of the machine, where the power cord, thats is odd to access and tighten often works loose.
Here is the entire documentation troubleshooting procedure, this is from the service manual.
Step Questions and Actions Yes No
1 1.
Cycle power to the system to clear.
2. Did the error recur?
Replace the Complete.
2 1.
2.
3.
3 1.
Are the lamps on?
2. Run the diagnostic test:
Go to Step 3. Replace the
lamp(s).
4 1. Is the scan head in the home position? Replace Replace
Posted on Mar 28, 2008
SOURCE: Doc 12 error code 9-343
i had similar problem a week ago running black only job on extra heavy card stock.
there is black toner built up. when you run black only copy with little toner use, it builds up toner in black developer and motor could not run.
always mix black and color jobs and run alternate, so there is no excesses in any color. or cheaper way how i did without paying color clicks.
i got rid of excess black in following manner.
took 11x17 white sheet, copied as negative (solid black) and ran 30-50 black copies, which drained all excess black and then continued with job.
hope it works for you or get professional help or you will lose motherboard and motor if you just follow instruction as it tells you on error screen... switch off and switch on. do not keep on repeating.
Posted on Nov 05, 2008
  • 653 Answers
SOURCE: error code F14 ON DISPLAY
F14 indicates invalid backup counter.
After cleared below counter, problem is solved.
*Method: Just enter 08 setting mode-->key in "388"-->press Start button. Repeat again for "389"
*After cleared the counter, it will also reset the network settings where we need to reconfigure.
Posted on Aug 25, 2009
shawn38
  • 200 Answers
SOURCE: KYOCERA PRINTER GETTING THE FOLLOWING ERROR CODE:
Drum unit non- installing error
The drum unit is not installed or not
installed properly.
The drum PWB EEPROM does not communicate
normally.
1. Install the drum unit
2. Check the connection of connectors drum
PWB (YC1) and connect-L PWB (YC3).
3. Replace the drum unit
4. Replace the engine PWB
Posted on Mar 06, 2010
After power up, error code F60 is all I get. What's F60?
After reading and trying these solutions with out success, what I did was climb to the top of my roof and throw the Panasonic unit onto the cement driveway. The end result was the unit still won't work but darn I feel much better. No Mo Panasonic electronics for me, thank you very much!!!!
Sep 19, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
We are gettign this error on our Kodak 2500D scanner U18 REMAIND DOC. 18040000
Hi what you need to do is download the latest firmware this should solve your problem
Mar 05, 2008 | Computers & Internet
I am getting a u18 error code when trying to copy a colour paper
You have reached your limit on color copies that the key operator has established for your code.
Mar 06, 2011 | Panasonic DP-C264 Color Copier
Error on display
you need to check on the connecting cables if damage replace,you can as well check my computer in system programms on monitor/visual display unit to see new device connected to system, after that restart your system.
Jul 09, 2009 | Office Equipment & Supplies
U18 remaining doc. error code;
The sensor that you can't see (at the bottom facing up) needed to be cleaned. Once cleaned with a cotton swab and alcohol the scanner works fine.
Apr 03, 2009 | Office Equipment & Supplies
Status Code F60
You could always try to force it into standby mode and back out again:
Press [í/I, POWER] on the main unit to switch the unit to standby.
Wait about 30-60secs.
Now press [í/I, POWER] on the main unit again to turn the unit on.
If that doesn't take care of it, everything thing I've found points toward a replacement of components inside the system by a repair service. Hopefully you are still under warranty!
Jul 11, 2008 | Panasonic DMR-ES35VS
Panasonic DMR-ES46V shows F60 Error
I have same problem with es40v - f60 error with no response to troubleshooting protocol. This machine also was used very little & also has a history of turning itself on. Panasonic used to make high quality products. A shame that their products are no longer trustworthy. I can understand that machines break - i'm very frustrated to learn replacement parts are not available. Guess i need to re- think brand loyalty.
Sep 02, 2007 | Panasonic DMR-ES46VS DVD Recorder/VCR
189 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
