Question about TruTech PVS12701 Portable DVD Player
Battery won't charge
I can't get the battery to charge.  If I plug in the DVD player the DVD works, but the charging light isn't lit and no matter how long it's plugged in, I can't get the battery to charge.  Once the unit is unplugged it doesn't work.
Jodi
  • 2 more comments
  • Anonymous Aug 20, 2008
    At least your player works when plugged in. I've got two units that I can't charge. Don't know if it's the batteries or the player. Since the units were bought at the same time and were used the same amount of time, the wear and tear is the same. They were both left uncharged the same amount of time (10 months). Can't find a battery either...........
  • Anonymous Sep 18, 2008
    cannot
  • scottsnewski Sep 20, 2008
    same problem here.
  • pkntw Oct 06, 2008
    Same as the last. I just baught it less than 1 month ago and it won't even turn on.
  • 4 Answers
Borrow or get a cheap volt meter to see if the power supply is working. Insert one probe on the inside, and one on the outside to see what is going on inside the power supply/charger.
Does the power supply hum or get warm? If not, it was probably made pre-broken at the factory in china. Either that or it's power lead has a break, it's power output jack or where it connects to the main board on your portable DVD player.
-Pro Hack
Posted on Oct 30, 2008
Black & Decker Cordless Drill will not charge battery
Either the charging adapter is faulty or the battery is worn out.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 03, 2012 | Black & Decker Black and Decker 18V...
When I plug in the ac adaptor to charge unit,the instructions state the chg light will go off when charged. Is it possible that it is charged and the light stays on. I charged it (in the off position)...
The unit still,work?The battery when it low,the battery light turn yellow or red?Than when it fully charge it turn green?Just unplug the unit and use it dosen't matter,if the light don't turn off the light,that find.Or the battery is old and not taking full charged anymore that another resoan the charging light still on.
Jun 14, 2010 | Mintek MDP-1770 Portable DVD Player
We have a Sony FX820 Portable DVD player. It is not under warranty. It will not turn on. When it is plugged into the car charger or the AC adapter the charge light doesn't come on. It is just dead. If...
Local tv repair shop will look and fix it in less amount. Sony service will charge you more than its worth.
I think it would be matter of couple of blown chip fuses on main board of dvd player.
Jun 01, 2010 | Televison & Video
I can't figure out how to charge my Sony portable DVD extra battery
There should be a external port,plug in,plug the tranformer to the power source now,should have
indicator light will light up.Fully charge light will go out.Have to put it in the DVD player to charge that the extra battery only way.
Nov 03, 2009 | Sony DVP-FX810 Portable DVD Player
Need help charging my mintek dvd player battery
The way the battery is usually charged is by plugging it into the player and plugging the player into the a/c outlet. Do not use the player, Just allow the player to charge the battery. The way you tell if the charging is working is the light on the front will usually be a red color and it will be steady color or blinking while charging. When the battery is fully charged, the light will turn green or turn off . This lets you know that the battery has fully charged.To test this try using the dvd player on the battery only. Play a dvd or cd and see if the battery is working properly. I hope this information helps you with your problem.
Apr 01, 2009 | Mintek MDP-1770 Portable DVD Player
Dvd player recharger charge status lights blink
The blinking went away as I had charged it for a very long time. However, it was noted that it would not work on the DVD. The battery needs to be replaced. That solved my problem. I still have to look for a new battery for this device: US Logic 680p DVD player with recharging capabilities due to the portability option. It works fine if plugged in, but the battery just needs to be replaced if I want to use it independent of the plug. Thanks for asking how I resolved the issue.
Nov 25, 2008 | US Logic 680P Portable DVD Player with...
clean the contacts of the battrey and the charger.if that does not work replace the charger or the battery.goodluck.
Apr 03, 2007 | kawasaki PVS-10921 Portable DVD Player
TruTech PVS12701 Portable DVD Player Logo
111 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
