Question about HP DeskJet 5550 InkJet Printer
Hp 5550 printer problem
Was printing a document and it just stopped on it's own. Now the orange and green lights are blinking.....printer won't do anything even after being shut off and restarted??? Please Help!!
  • Anonymous Apr 19, 2009
    This day and age... I guess you get what you pay for. Same problem.. no resolution.
    Guru:
  • 859 Answers
You have a paper jam. If you have more paper that is left to be fed than paper already printed, pull it out from the feed tray, if not pull it out from the ejection position. You will not harm your printer.
After you do this, turn you printer off. On your PC's desktop if there is still a printer icon near your clock display in the bottom right double click that and then in the window that pops up drop the file menu down and select delete print jobs. Turn you printer off, shut your PC down. Turn your printer on, press and hold the power on button until you receive a test page or use your menu to select print test page. Also, do a nozzle check and print head alignment too all while your computer is off. Once, done, restart your PC. When you have a desktop, go to start menu, control panel or settings, printers. Select your printer to open up the printer properties page. From this, print a test page. If you have done everything right it should print okay. If you still have a printer icon in the system tray (area next to clock display) double click this again, select any print jobs left in the printer and choose resume or print now or print.
If you have any questions your get stuck, use the comment box below to comment back to me. I'll get back to you as soon as possible to help you out. I'm in and out while operating my business.
Regards,
Worldvet
Posted on Aug 13, 2008
  • 876 Answers
Did it eject the paper? The paper may have been crooked or became so in the printer. Check the Paper jam area first. If there is nothing there, Let's try a simple reset of your printer.
Go to Control panel>printers and faxes>click on your printer icon and under documents click cancel all documents.
Turn the printer off
Remove the paper from the tray
Unplug it from the power source
unplug it from the PC
Now open the paper jam door and gently push the paper roller forward until it clicks
Now do everything in reverse order until you get to turning the printer back on. give it a few minutes and see if it resets itself.
when you reload paper, besure that it is aligned carefully and the holders are pushed into place.
Let me know if this helps. Good Luck!
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
I can't print and I have an orange flashing light on the right side of the printer. Whay does this mean?
Issue: The Power light is on and the Resume light blinks
In this error condition, the following light pattern displays on the product control panel:
•Print Cartridge status light : Off
•Resume light : Blinking (orange)
•Power light : On (green)
Causes
??¦The product is processing a print job, or waiting for the ink to dry on a document.
??¦The product might be out of paper.
??¦The product might have a paper feeding issue or a paper jam.
There are several possible solutions. To work through these suggest you follow the illustrated on-line guide found here.
Jan 16, 2011 | HP DeskJet 5550 InkJet Printer
The top orange light is blinking and it says its offline??? What do we do??
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
Oct 22, 2009 | HP DeskJet 5550 InkJet Printer
TOP LIGHT ON PRINTER KEEPS BLINKING - I'M UNABLE
This should help you. It details what the blinking lights mean and should allow you to diagnose what the problem is.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00061319&lc=en&cc=us&dlc=&product=305980
Oct 13, 2009 | HP DeskJet 5550 InkJet Printer
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
HP 5550 stopped
With the power off I manually pulled the print cartridge trolly to the left and then turning the power back on. This fixed the same problem for me.
Apr 28, 2009 | HP DeskJet 5550 InkJet Printer
No printing; yellow and green lights are blinking together.
Check page 10 in the manual at this link:
http://h10032.www1.hp.com/ctg/Manual/bpd09384.pdf
Ifthe "Resume" & "Power" buttons & lights are the ones you referto, then here is a page explaining how to resolve this issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=71895&prodTypeId=18972&prodSeriesId=71895&objectID=c00681585
Mar 20, 2009 | HP DeskJet 5550 InkJet Printer
HP Deskjet 5550
Here is a HP document on what causes the green (power) light to blink and how to T/S it:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00035263&dlc=en&product=71896
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 08, 2008 | HP DeskJet 5550 InkJet Printer
Both ink cartridges?
Both have to be in the printer,even if one is empty.
Read this HP document on the blinking lights code:
copy and paste the complete link into your browser.
Thanks, Joe
Aug 03, 2008 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
367 people viewed this question
Seeker5211
Seeker5211
