Question about XRS-757 Radar Detector
Windshield mounting clip
How to I connect the mounting clip to the detector ?
    Problem Solver:
  • 6 Answers
The front of the detector has a small **** in it about an inch wide and a couple mm tall. the tab on the suction cup mount slides into this **** on the front of the detector.
Posted on Dec 10, 2008
Where do I mount my radar detector?
The unit comes with a windshield mount - assemble the bracket ( if needed) and secure to a location on the windshield. Make sure its above the wipers and not behind any metal. Once installed, make sure that the radar detector is LEVEL WITH THE ROAD! This may require bending the bracket to level the unit. (Note: remove detector while adjusting the bracket).
Dec 28, 2015 | 14 Band Radar Laser Detector Voice Alert...
I need instructions on how to mount the nuvi 200w to my windshield
To secure the nuvi 200w to your windshield with the included suction cup mount (pictured below),
center the GPS on the clip, and tip the bottom edge on the bracket. Push the top of the GPS against the top clip until it clicks into place. Hold the bracket and GPS near the windshield where you like it best. Note where the suction cup is on the windshield in relation to the mirror, etc. Remove the GPS from the mount's clip by pushing the top tab back from the top of the GPS.
Clean the windshield (or portion that the suction cup will be stuck against) with a paper towel or newspaper and ammonia solution like Windex, etc. Clean the suction cup with the paper towel and Windex, too.
Lift the lever at the base of the mount - is shown in the picture above - if it isn't already. With the mount oriented as shown in the picture above, press the suction cup against the windshield where desired with one hand. Hold the mount firmly against the glass and use your other hand to press the lever on the base back toward the suction cup and glass. Press until it lays flat against the base / suction cup. Plug the power cord into the GPS and reinstall the GPS in the mount clips as done earlier.
To remove from the windshield, release the GPS from the mount clips, and lift the lever away from the base / suction cup. Locate the tab that is connected to the suction cup edge near the lever. Pull on the tab away from the glass to break the suction seal and remove from the windshield.
If this was helpful, please rate it 4 thumbs up. Thanks & good luck!
Sep 20, 2011 | Garmin GPS
You can order the windshield bracket on the manufacturer's website by clicking this link.
On the page which opens, select the part and proceed to check out.
Hope this helps. Than ks for using FixYa.
Sep 01, 2011 | XCS800 Radar Detector
Need Whistler radar 1660 mounts Ron Bartlett
windshield mount is available on whistler's website - or by calling 800-531-0004.
Jul 03, 2010 | DE-1660 Radar Detector
The wiper motor on my 1983 Ford Ranger still works but the wipers no longer move. I think there is a failure of the mechanical linkage. Where do I go to find repair parts?
why do you think the motor still works if the wipers don't move? Can you hear the motor run or can you see a little movement when you turn the switch on?
What happens when you activate the washers?
go to a salvage yard that allows you to remove the parts yourself. Then you can see how the motor and linkage assembly comes out.
don't have 1983 info, but here is 1994:
Section 01-16A: Wiper and Washer System, Ranger/Explorer 1994 Ranger and Explorer Vehicles Workshop Manual
DESCRIPTION AND OPERATION Windshield Wiper System, Ranger/Explorer The windshield wipers are actuated by a permanent magnet, rotary-type electric windshield wiper motor (17504) . The two windshield wiper pivot arms (17526) and windshield wiper blades (17528) are mounted on a pivot shaft, one at each side of the windshield. The windshield wiper mounting arm and pivot shaft (17566) are connected to the motor by windshield wiper adapter and connecting arm clip (17531) . Ranger and Explorer vehicles are equipped with an interval wiper and washer (IWW) system featuring a lever-type turn signal and windshield wiper switch (13K359) mounted on the steering column. The IWW windshield wiper governor (17C476) uses a relay contact to control current to the windshield wiper motor . The governor electronic circuitry controls the contact to supply current to windshield wiper motor . A rear wiper/washer system is available on Explorer vehicles. The rear window wiper system consists of a windshield wiper motor mounted inside the liftgate (40010) , an articulating windshield wiper pivot arm and windshield wiper blade , a windshield wiper/washer switch (17A553) and an inline circuit breaker. The front electric windshield washer system consists of a control switch, integral with the turn signal, a windshield washer reservoir (17618) and windshield wiper motor and the necessary windshield washer hoses (17A605) , windshield washer nozzle jet and brackets (17603) and attaching parts.
Pivot Shafts and Linkage Removal and Installation
NOTE: The left and right pivot and windshield wiper adapter and connecting arm clip assemblies are serviced separately.
  1. Perform Steps 1 through 9 of Windshield Wiper Motor Removal as described in this section.
  1. If servicing left windshield wiper adapter and connecting arm clip , remove left windshield wiper mounting arm and pivot shaft and windshield wiper blade assembly.
  1. Remove left windshield wiper adapter and connecting arm clip access cover.
  1. Remove left pivot nut, lower windshield wiper adapter and connecting arm clip and slide it out through left access opening. For installation, follow removal procedures in reverse order. Tighten nut to 10-13 Nm (7-10 ft-lb). Make sure the clip is fully seated in the windshield wiper adapter and connecting arm clip . Do not try to install clip with windshield wiper adapter and connecting arm clip on motor crank pin.
Windshield Wiper Motor Windshield wiper motor are not serviceable. If worn or damaged, the windshield wiper motor must be replaced as an assembly. Removal
  1. Cycle windshield wiper blades until in straight-up position and turn ignition switch OFF.
  1. Disconnect battery and wiper motor electrical connector.
  1. Remove the right windshield wiper mounting arm and pivot shaft and windshield wiper blade .
  1. Disconnect the battery ground cable (14301).
  1. Remove the right pivot nut and allow the windshield wiper adapter and connecting arm clip to drop into the cowl top outer panel .
  1. Remove the linkage access cover, located on the right side of the dash panel near the windshield wiper motor.
  1. Reach through the access cover opening and unsnap the wiper motor clip.
  1. Push the clip away from the windshield wiper adapter and connecting arm clip until it clears the nib on the crack pin. Then, push the clip off the windshield wiper adapter and connecting arm clip.
  1. Remove the windshield wiper adapter and connecting arm clip from windshield wiper motor crank pin.
  1. Remove nut and ground strap.
  1. Remove three attaching nuts from windshield wiper motor. Remove the windshield wiper motor .
  1. Position the windshield wiper motor and install the three attaching screws. Tighten to 13.6-19.0 Nm (10-14 ft-lb).
  1. Install nut and ground strap.
  1. Connect wiper motor electrical connector.
  1. Install clip completely onto right windshield wiper adapter and connecting arm clip. Make sure the clip is fully seated. Do not put the windshield wiper adapter and connecting arm clip on the motor crank pin and then try to install the clip.
  1. Install the left windshield wiper adapter and connecting arm clip onto the wiper motor crank pin.
  1. Install the right windshield wiper adapter and connecting arm clip onto the wiper motor crank pin. Pull the windshield wiper adapter and connecting arm clip onto the crank pin until it snaps into place. The clip is properly installed if the nib is protruding through the center of the clip.
  1. Install the right windshield wiper mounting arm and pivot shaft and nut. Tighten the nut to 9.5-12.5 Nm (84-110 in-lb). NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more to relearn the strategy.
  1. Connect the battery ground cable and turn the ignition switch on. Turn turn signal and windshield wiper switch off so windshield wiper motor will park, then turn ignition switch off. Replace right windshield wiper adapter and connecting arm clip access cover.
  1. Install the windshield wiper mounting arm and pivot shaft and windshield wiper blade assemblies on the pivot shafts to dimension X. Dimension X is the distance between the centerline of the blade saddle and the top edge of the cowl top outer panel grille. The value of Dimension X for each vehicle is given in the Dimension X chart in the Specifications portion of this section.
  1. Test the system.
Jan 04, 2010 | 1983 Ford Ranger
Where can i buy a windshield suction mount for a fb 3500
First this is not a Whistler made radar detector - it was made by Fuzzbuster. With that said, you might be able to use a Whistler bracket. If you know of someone that has a Whistler radar detector, try to see if your unit will work with it. If so, then you can call 800-531-0004 to order a windshield bracket or order it on Whistler's website -
Aug 10, 2009 | Fuzzbuster F4000 Radar Detector
Im trying to find out what windshield suction UNIDEN LRD6499SWS
Don't use this radar detector. It is horribly outdated technology and will lead to a speeding ticket. I am not joking.
Mar 17, 2009 | Uniden Vehicle Parts & Accessories
Broken windshield mount
The same has happened to me. Instead of monkeying with it i got two pieces of velcro. Put one on the top of the dashboard and the other on the bottom of the radar. Dashboards are usually highest over the instrument cluster so I mounted mine just to the right of that giving me a good height like when on the windshield, its out of your way, and still near the cig lighter. Mine works great in that position, I have not noticed any difference in function and it still saves me. ha!
Dec 09, 2008 | Passport 8500 Radar Detector
Whistler XCS-800 laser falsing
Have you tried it in another vehicle to see if it still alarms? The windshield pitting will not have any effect on the unit. After you test it in another vehicle contact Whistler at 800-531-0004.
Nov 18, 2008 | Whistler Vehicle Parts & Accessories
XRS-757 Radar Detector Logo
128 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
John Nolan
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
