Vizio 42 in. LCD TV Logo
Posted on May 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a 42 LCD. We're using the Dish Network and it works great until night time. After a dozen attempts last night we've determined that the remote only works during daylight hours or at night with the light on in the room. Any thoughts?
Anonymous
Level 2:
Novelist:
  • Expert 185 Answers
  • Posted on May 18, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
185
Questions
0
Helped
63246
Points
274
It sounds like there is an interference issue, we can change your remote to a UHF frequency to resolve this. Feel free to reply to me for more assistance!
Daniel Busa
DISH Network
Customer Service
Testimonial: "Great help!"
Okay I have been using my HP G61, for a while now. I bought it 3 months ago. And I used it for college everyday. I used it last night before I went to sleep. I've closed it and left it charging all...
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
What code do I use for my 20.0 dish network remote to use with my gpx tv
You need to call dish. I just did this last night. Took them less than 5 minutes
3answers
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Uhf pro fcc id DKNFSK01 MY REMOTE WILL NOT WORK AT ALL I'VE PUT NEW BATTERIES IN IT AND IT LIGHTS UP BUT WILL NOT WORK THE RECIEVER AT ALL ANY HELP WOULD BE GREAT THAT YOU
Hey edwards879,
It sounds like the remote needs to be addressed to the receiver.
I have provided the steps below to assist you with that, you can also check out this link: http://www.dishnetwork.com/SupportSection/remote-setup
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test remote and see if works.
If you reprogram it and it still doesn't work the remote may need to be replaced. If that's the case or if you have any other questions let me know!
Tommy Faust
DISH Network
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
2helpful
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
3 digit codes for 42" lg lcd tv for dish network
We would be happy to help you with getting your DISH Networkremote to control your LG TV. We're going to start by pressing and holding the TVbutton located on the top of your remote until all mode button back lights comeon, and then release. Use the number buttons to enter the codes for your LG TV; here are some of the codes we currently have: 627, 505, 520, 506, and 581, then press the pound (#) button. To check if the code works try severaldifferent functions on the remote to make sure it will properly operate yourTV. Remember that some codes may not be compatible with your equipment. If thisis the case, try the other codes listed for your LG TV until youfind one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
I have a 42 in Insignia LCD that I have only had
If a problem like this should develop within the retailer's return period, it is recommended that the TV be returned for an exchange.
Remote control code
The last few months, directv has been upgrading the software on their receivers to include Polaroid codes. Don't know if they will work with Dish, but the newest codes added are 10765, 10865. 11276, 11314, 11316, 11326, and 11327. Some Directv codes work with Dish. Worth a try.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
