I would like to add a dvd burner or drive to my dell dimension 3000 but not sure what to get or if I need upgrades to do so
    Problem Solver:
  • 22 Answers
When you purchase the product, it usually comes with all connectors and power cables that connect it to your pc. make sure when you purchase one that it is "plug-and-play" or if not, comes with its own installation software cd/usb key.
these drives usually work with all standard cpus. i googled your dell model and it looks like a standard desktop pc. make sure you don't void your warranty while opening it. you might want to inquire with your dell provider if you will indeed void your warranty if you do this operation by yourself.
Posted on Aug 13, 2008
SOURCE:
What do I set my CD-Rom Jumpers to in a Dimension 1100
Which is it a Dell 3000 or Dell 1100 ?
The jumper settings on the rear of the DVD drive; set the jumpers to "cable select" mode (if you are uncertain how to set the jumpers, check the documentation that came with your drive or look for a diagram printed on the drive itself). Insert your DVD drive into the selected drive bay and connect the IDE and power cables. Use the screws that came packaged with the drive to secure the component to the drive bay.
Dell Dimension 3000 Service Manual
http://support.dell.com/support/edocs/systems/dim3000/en/SM/sm.EXE Dell Dimension 3000 Users Guide http://support.dell.com/support/edocs/systems/dim3000/en/OM/j6758A04.pdf
Mar 02, 2013 | Dell Dimension 3000 PC Desktop
COULD SOMEONE HELP FIND THE DRIVE PART CALLED DELLG9237 IDEFOR THIS DELL DIMENSION 16X DVD+RWDVD.
im not sure what part you need you might have to buy the complete dvd drive or you might be able to locate a damaged drive for parts
postage is the big killer you should try to locate nearest you for a free local pick up
http://www.ebay.com.au/itm/Dell-G9237-IDE-16X-DVD-RW-DVD-Writer-Drive-Black-Bezel-/230809746972?pt=UK_Computing_Drives_Storage_CD_DVD_Drives_ET&hash=item35bd553e1c
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
http://www.paypal.com/
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Jun 24, 2012 | Dell Dimension 3000 PC Desktop
ASUS 22x Internal CD/DVD Burner not working
Look into the little jumpers on the back.
If its SATA its np But if its IDE you need to set the jumper to master or slave or cable sellect.
May 01, 2012 | ASUS 22x Internal CDDVD Drive Burner
Cd dvd burner on dimension 3000 desk top with xp light wont come on or tray wont open
sounds like the drive may have failed
Reseat the power cable to the drive
if no change, replace the drive
Jan 22, 2011 | Dell Dimension 2400 PC Desktop
My dell dimension 3000 pc has run out of memory space on the C-drive. How do I add more memory?
You can't directly add additional memory space to the C drive, but you can add additional hard drive and move the files from C drive to the additional drive. If there's enough space on D or E drive, you can move from C drive to the other drive. Note that your C drive includes your Desktop, My Documents files, My videos, My pictures, My Music etc.. So make sure you haven't saved extra files on you Desktop or My Documents. To free up some space, you can run DiskCleanup utility which is built-in with the Operating System. To do this, Right click on the C drive, Properties - Disk Cleanup... and then provide positive input, eg. yes or ok. good luck..
May 14, 2010 | Dell Dimension 3000 PC Desktop
DVD drive Read problem in my Dell Dimension 3000
Make sure you have any and all Windows 7 updates from Microsoft, along with any updates for your DVD drive for use with Windows 7. Some components work fine using Vista SP2 drivers, but some will need an update to work with Windows 7.
This Microsoft site might help verify if your DVD drive is compatible with Windows 7:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Feb 12, 2010 | Dell Dimension 3000 PC Desktop
I have a dell dimension 3000 and i want to upgrade ram
Best thing to do is to go to www.crucial.com and run their system scan. It will tell you how much you have, how much it will hold, and what kind of RAM you need.
Thanks for using Fixya.
Oct 14, 2009 | Dell Dimension 3000 PC Desktop
Dell dvd burner does not recognize media
sir, try using NERO software and make sure that your cd-r or dvd-r has no scratch and it should be new. hope that helps!
thank you for using fixya
CHARCOIS
Feb 06, 2009 | Dell (0R649) CD-RW Burner
Capable of upgrading more?
well i would say you really dont need to upgrade everything is cool with your computer really so it would just be a waste of money
Dec 19, 2008 | Dell Dimension 2400 PC Desktop
Open Questions:
Epson Wireless Printer tEcH SupPoRt pHoNe nUmBeR:~{-1{85526O0O64^-} Vusary Epson Wireless Printer tech Support Number +1{{85526O0O64}VuLogin Repair service center to resolve all Epson Wireless Printer customer service phone Number products. Epson Wireless Printer ROUTER is an American multinational company which was founded by Michael Epson Wireless Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Epson Wireless Printer ROUTER support number, and selling of computer-related services and products. Epson Wireless Printer ROUTER Tech Support Phone Number Recently, Epson Wireless Printer ROUTER has been named the number Epson Wireless Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Epson Wireless Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Epson Wireless Printer ROUTER Service Tag or a Epson Wireless Printer ROUTER Get Epson Wireless Printer ROUTER Technical Support Phone Number and Customer Services. Epson Wireless Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 18, 2019 | Epson Computers & Internet
Dell Wireless Printer customer care number%%[+l{855^26O0O64}%%:~NumbER USA Vuots Dell Wireless Printer VuLogin customer care Number +[185526O0O64]VuLogin Dell Wireless Printer tech support number USA Repair service center to resolve all Dell Wireless Printer tEcH SupPoRt pHoNe nUmBeR products. Dell Wireless Printer is an American multinational company which was founded by Michael Dell Wireless Printer using its company headquarters in Round Rock, United States of America. Contact Dell Wireless Printer for Setup & Installation Dell Wireless Printer Setup Free & Installation Dell Wireless Printer TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Dell Wireless Printer Connect, Dell Wireless Printer TECH Free Phone Number you'll be searching out Dell Wireless Printer Connect setup as well. So, here we're with all cthe setup process and for your to Dell Wireless Printer Connect. Get Dell Wireless Printer Setup Instant Free Dell Wireless Printer TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Dell Wireless Printer Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 18, 2019 | Dell Computers & Internet
Computers & Internet Logo
29 people viewed this question
Ekse
Alun Cox
