Question about Sony Handycam DCR-TRV280 Digital Camcorder
Ccd-trv37 trouble with recharging battery
When i try to recharge my battery (and its a new battery thinking that was the problem), it only shows a blinking battery symbol and not the battery with the parts colored in. is it not charging?
  • kelliwayne Oct 13, 2008
    I too have this problem. I have a Sony Handycam TRV37 and haven't been able to use it for over 5 years. Warranty was over after 1 year and that's when it decided to no longer hold a charge. I took it to a shop that usually can fix camcorder problems and they told me it was more expensive to fix than replace.
  • 10,594 Answers
I think, battery is not being charged in camera.
  1. Plug the charger in AC out let.
  2. hook up with camera, check camera wroks with charger,
  3. set camera power button in OFF / Standby position,
  4. attach battery to camera and check any Charge-Light lit?
  5. If yes, leave it on charge up to 4-5 hours for new battery.
Posted on Aug 13, 2008
BATTERY PROBLEM
Ultimate solution is change the battery... because the capacity of battery cells is poor.. this could be the reason if battery is old...
Still u can take a chance by completely removing the battery fluid and replacing it new battery fluid... but keep in mind that, after doing so, u'll need to charge the battery fully before using it in car...
This kind of battery problem is common in all diesel cars, the reason I think is, Diesel engine need heavy torque to start that draws heavy current from battery.. so if you are facing starting trouble for the vehicle, then battery is surely going to discharge frequently...
Still try the solution mentioned above and still the problem persists, then replace the battery with new one.
((I am considering that the battery you are having is 3-4 years old...))
Oct 16, 2012 | 1997 Ford Escort
I bought a HP CA 350 digital camera of 10 Mpx I use Ni-Mh batteries of 2500 mAh (adjusted on the camera) and although the batteries are not exhausted it happens the camera to switch off previously...
Try new batteries which are not rechargeable and see if the camera works correctly. Ni-Mh batteries can cause problems. Firstly, a standard non-rechargeable battery will be 1.5V but rechargeable batteries are only 1.2V. So if your camera takes two batteries, it requires 3V, but is only getting 2.4V. The battery monitoring circuit in the camera will be looking at the voltage of the batteries to determine if the voltage is dropping to the point where the cammera cannot function. As the camera draws more current from the batteries during certain functions e.g. zoomingor charging the flash, the battery voltage can dip with rechargeable batteries and this may cause the camera to think that the batteries are running out of charge.
Jul 03, 2011 | HP CA350 Digital Camera
Battery shows empty with new batteries. Recent development. Put batteries in, take a couple shots, battery is empty. Tried with several pairs of batteries. Contacts OK and tight. Suspect a software...
Take a look in your camera's menus. There should be a place where you can select rechargeable or non-rechargeable batteries. That setting enables or disables the battery charging circuit. If you are using rechargeable batteries, the camera must be set accordingly so that the battery charger will turn on. If you are using
Alkaline batteries such as Duracell or other types of non-rechargeable batteries the charger must be disabled. If you do not set that parameter correctly, you will get the symptoms you describe.
Oct 04, 2009 | Pentax Optio M20 Digital Camera
It says battery exausted even with new batteries
I beleive your batteries are of incorrect type or you need to set the type of the battery through menu. My favorite batteries are from Wal-mart: Energizer rechargeable Ni-Mh 2450mAh, (15 min recharging time) they fit any type of camera without setting the battery type through menu. Some incorrect type of batteries often damage the CCD. Ni-Mh Energizer never damages the CCD (black screen), while regular (non-rechargeable) Energizers may damage CCD in Sony S700 or similar cameras.
Jul 20, 2009 | Nikon COOLPIX L18 Digital Camera
I was given a nice sony handycam camcorder. i was told the battery is probley dead
Batteries have a limited life even if they are constantly charged.
Leaving batteries in constant charge will limit their life by causing gas leakage. Once depleted, they must be replaced. There is also a small button battery that keeps unit memory up, if you do not use camera for months at a time, replace this battery also.
Ni-Cad batteries need to be refreshed ony once a month by discharging them fully, then recharging them fully for best performance to erase memory effect
May 01, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony ccd-f55 Handycam
If it is a CCD-F555 the battery charger is also the AC Power adapter. There is a switch that states VTR...switch to it and plug into the camera and it should work. Have you had any other problems with your camera. I got mine in Japan when I was stationed over there and it will play back the tapes; however, it will not show the camera in the viewfinder. I know the lens is working because it will autofocus. I just can't see it. My email address is ds4190@excite.com
Dennis
Apr 26, 2008 | Sony Handycam CCD-F555 Camcorder
How Do I Edit the Film?
Look for the output jacks on your camera, hook them to your computer's audio/video input. Try accessing the recording utility on the computer then upload footage through NTSC format. You can then edit the footage. If your camera and computer utilize S-video, use them for best resolution
Mar 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Error code C:32:20
My best solution, is to pull all power sources form the camera for 24 hours. If this does not work, then take the small screws surrounding the Tape housing, in order to try and get the tape out. Best of luck dude ;)
Feb 05, 2008 | Sony Handycam CCD-TRV37 Camcorder
How do i recharge the batteries?
the camcorder should come with a cord to plug into a power point, it will charge once plugged in. Normally they take 3 hours to charge with a main power supply.
Dec 23, 2007 | Sony Handycam CCD-TRV37 Camcorder
PLEASE HELP!! Sony Handycam CCD-TRV37
The problem is usually caused by no drum rotation. Have it serviced.
Sep 14, 2005 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam DCR-TRV280 Digital Camcorder Logo
215 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
