Question about Akai LCT3201AD 32 in. LCD Television
Power supply problem
I have the same problem everyone else has. Turn on, green light comes on for a second, then goes red. I am an electronics tech for Texas Inst., so I can replace components myself. Is there a specific component that is the problem with this supply? Any help would be appreciated. Thanks,Frank
  • 2,326 Answers
There are 3 capacitors that become defective all the time, the values are 1000uF/16 volts and they are located in between two heatsinks on the secondary side of the power supply. You should also remove HS4 to check 2 other capacitors that could become defective as well, their values are 220uF/25 volts.
Let me know if you need further assistance.
Posted on Aug 13, 2008
  • Jaime Hernandez Aug 13, 2008
    The reference designators for the defective capacitors are EC18, EC19 and EC20 (1000uF/16V) and EC12, EC15 (220uF/25V).
My protron pltv-37c will turn on for 10 seconds the light turns green then goes to red after ten seconds
The green light indicates power is being applied. The change from green to red indicates that the power supply has failed
Oct 29, 2012 | Protron PLTV-32 Television
Hitachi Model 50DX20B No Sound or picture
GOOD question and well asked----Start at the beginning.
if light on main fuse is good---do you hear the power relay click on and off?
These sets for trouble shooting use a number of green and one red LED inside on the board--the red one should be on when power is connected and the others at turn on all should light--if do this with back off look for the Green ones---when set turned on do all light and then go out--look for one that goes out first or last---each is connected to a specific voltage coming out of the power supply---they will lead you to the area where the trouble is---this set is old enough you may be able to find a service manual online.
I have fixed a lot--going to need a volt/ohm meter for any real tests.
I am ready to help if you need it.
Apr 22, 2012 | Hitachi 50DX20B 50" Rear Projection...
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
Will not turn on. Light flashes green then goes back to red.
both t.v. and remote have a light but they do not communicate.  I get no sound or picture.
May 27, 2009 | Proscan 19LA25Q 19 in. LCD Television
TV won't come on. Standby goes green,then goes red blinks 3 times
3 flashes means the lamp door is not on correctly or the lamp door switch is broken.
Apr 08, 2009 | Sony Grand WEGA KF-50WE620 Television
TV is broken: on light geos from Green to Red
contact manufature for parts suppliers to order power supply.
Jan 23, 2009 | Astar LTV-1701 Television
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Akai LCT3201AD 32 in. LCD Television Logo
127 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
