Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door not working
We had a storm come thru and ever since garage door will not work, lights still work.. sensors are on. I have unplugged unit to try to get it to reset as I can not find the reset button. Have any idea where it is?
  • 118 Answers
Replace opener.
Posted on Jan 18, 2009
Liftmaster 3265M. Two units. Why does neither work since lightning storm?
Chamberlain Liftmaster garage door opener problems ...
? 3:10
https://www.youtube.com/watch?v=Zq_CxeTXoSM
Jul 2, 2013 - Uploaded by Mike McCarron
Might have taken a lightening strike, knocked out GFCI that was on the circuit that garage door opener was on. When I ... And sometimes after it happens it takes 30 or so seconds before the opener will work again. ... The keypad unit worked well butneither the homelink or the remote units worked.
Garage Door Openers - Lightning Strike - Forum - Bob Vila
www.bobvila.com/posts/30883-garage-door-openers-lightning-strike?...
Aug 6, 2005 - The house did not lose power and I do not believe the house was actually hit. ... the light comes on on the unit (as expected), but neither door opens or ... Afterplugging it back in, try opening the door with the hardwired button first - if it still doesn'twork, chances are your opener's taken some damage but not ...
I Have A Liftmaster Garage Door Opener Unit. The Remote Work ...
www.diyforums.net/i-have-a-liftmaster-garage-door-opener-unit.-the-re.
Jan 01, 2016 | Building Materials
I have two older craftsman openers. We had a storm come thru that effected other things at house. Garage doors both went up but will not go back down. No reset on opener. Unplugged and plugged back in, no...
How about some info to work with? Do they have electric eyes? Are they lit? What model Did you put in a Home-owners claim on your damaged household "other things"?
Oct 14, 2009 | liftmaster Chamberlain Garage Door Opener...
Sensors not working
The sensors must be pointed at one another to work properly. If one of them has been bumped it will cause the situation you have. Tweak them a bit to see if the light will come on. If it doesn't you have either a bad sensor or a bad logic board. Maybe you could move the sensors from the door that is working to eliminate the possibility of a bad sensor.
Aug 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door doesn't open
BE SURE THE EYES ARE AIMED PROPERLY.
IF THEY ARE POINTED AT EACH OTHER AND THE LIGHTS DON'T WORK YOU MAY HAVE PULLED A WIRE LOOSE - CHECK THE CONNECTIONS.
IF LIGHTS ARE ON AND IT STILL WON'T WORK, UNPLUG THE UNIT WAIT ABOUT 5 MIN. PLUG IT BACK IN & TRY AGAIN.
HOPE THIS HELPS
Jul 10, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Craftsman Garage Door Opener won't work after storm
Check to see if the trolley (the part that slides back and forth on the rail and is connected to the door) is jammed against the bolt just in front of the motor unit. If so, remove the bolt and run the door until it is closed. On the side of the motor unit there is an 'up limit' control. Turn this 3 turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Jun 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2hp Operator won't work after electrical storm
Sounds like the circuit board got zapped. You could price a new board or take it apart and check the components if you know how, but normal mortals would just buy a new unit.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't open
Unfortunately storms do bad things so door openers sometimes. It has most likely gotten to your logic board. You can remove that board and look for burnt or missing traces of the print. Random flashing of that LED is normal.
May 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener does not work may have beem electrical storm. unit has power model 248739
I have Sears Craftsman model 139.58778 and the remote is suddenly not working for no apparent reason. The transmitter in the garage works fine but the portable unit for the car does not. The red light goes on and the toggle switches are correctly set and match the overhead unit setting. Any ideas what is wrong? I purchased a new remote and it did not work either after being correctly set, Thank you!
Sep 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
151 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
