The jump drive will not boot into "my Computer"
  • 65 Answers
Ive had problems with jump drives in the past and ive found the the ceaper they are well the cheaper they are. my burned up and fried after 3 uses. it may very well be poor manufacturing.(Have you tried using it in a diffrent computer?-try putting it on a friends computer to see if it detects it.) or a driver problem.
to find new drivers, you may ned to acess your control panel-->add hardware. and check for new hardware. it should search for drivers for your drive and appear. *their may be a few options you need to choose from*
i hope this helps.
Posted on Aug 13, 2008
Cant find disk to boot
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Mar 25, 2013 | Acer Aspire S7 ultrabook
All about Windows SAM file
<b>Section 1 : General Information</b><br /> As you may or may not know, all of the passwords on a Windows XP computer are stored in a SAM File. This file is located on your computer's hard drive in the directory "C:WINDOWSSystem32Config" The file's name is SAM, obviously. Now, you may be thinking, "Wow, this was incredibly easy, I just right click the file, and click send to a floppy or where ever. Well, unfortunately, it isn't that simple. I will detail the various methods of getting the SAM file in the next section.<br /> <br /> <b>Section 2 : Obtaining the SAM file</b><br /> In the previous section, I discussed where the SAM file was found. As you may have found out, when you attempt to copy this file, you get a nasty error saying something along the lines of "Access is denied. File is in use." The SAM file is in use by the system, so you cannot just go to task manager, and end the process. You need to find alternate methods of starting up the computer without using the SAM file. As far as I know, this can be done several ways. <br /> <br /> Booting the computer up into Linux using a boot CD or floppy is one method. To use this method, you will need a Linux Boot CD, and access to BIOS. If you don't have access to BIOS then consult one of the many tutorials on the web on how to crack the BIOS password. <br /> <br /> To make a bootable Linux CD, you have to find a version of Linux, which can be burned and run off a CD (To find these, consult my links, or search google). This should be relatively easy to find. Next you need some kind of burning software, which allows you to burn an image onto a CD (Consult Links, or search google). This a bit harder to find for free, but a demo works just fine. After you have these, burn the image to the CD. You now have a Linux Boot CD.<br /> <br /> Now to alter the BIOS settings, so that you can boot into Linux from the CD. Shut down your computer, and during the start up screen, you should see a notice to press F1 or F8 (Maybe a different key) to enter Boot setup. Press it. This will take you into the BIOS, however, if there is a password on the BIOS, then you have to consult an article about cracking BIOS passwords. Next go to Boot Order and change the CD drive to first. Save your changes, insert your Linux CD and exit. Let the system boot up. It should boot into Linux if you did everything correctly. Now all you have to do is insert a blank floppy, and copy the SAM file to it, since it is not in use anymore because Windows is not running. Congratulations, you now have the SAM file. Be sure to get the SYSTEM file in the same directory as well, as some passwords are encrypted with keys from within that file.<br /> <br /> Another, somewhat easier way of obtaining the files is using a MSDOS boot disk. This method doesn't require you to go looking for some software, or using special burning software. Just insert a floppy, right click on it in My Computer, and click on format floppy. When the menu appears, mark the box for "Create a MS-DOS startup boot disk", and then click the start button. After you have made your disk, restart your computer with the disk still in the drive. Make sure you BIOS settings boot from the floppy drive before the hard-drive. When the computer boots, you should se a screen similar to that I command prompt. "A:&gt;" is most likely the prompt you will see. First you need to change drives to the c drive. This is done various ways on different computers. "cd C:" or "C:" usually work. Next you will need to use the copy command to copy the SAM and SYSTEM files to other areas of the hard drive. The syntax for the copy command is as follows without the quotes : "C:Copy (file to be copied) (destination)" so the correct command which will get the file for you is "C:Copy C:WINDOWSSystem32ConfigSAM C:" This will copy the SAM file to the C drive. Replace "SAM" with "SYSTEM" to get the system file. Next you might want to rename these files. This is the syntax for the Rename command : "C:ren (file to be renamed) (new file name)". The command, which will rename your files for you, will be "C:ren C:SAM Whatever" if you saved it to the C drive. This will rename you SAM file to Whatever. Now restart your computer without the boot disk in and start up windows. Copy the files onto a floppy. Note : you may have to zip it as the SYSTEM file is pretty big. The reason these methods work, are because the SAM file is not in use when you aren't running Windows, and when u copied and renamed the file, it did not get used by windows when you logged on. Now on to the easy part, cracking the SAM file.<br /> <br /> <b>Section 3 : Cracking the SAM file</b><br /> There is a wealth of programs available that will crack the SAM file for you. You can also attempt to crack it by hand. I having neither the time nor the skill required to do this, used a program. Some programs I recommend are SAMinside, which unfortunately costs money, Proactive Windows Security Explorer, which actually can import the SAM file from memory, so you will not need to obtain it by yourself if you are doing this on your home computer, and of course CAIN and ABEL will do the trick as well. Most of these programs test about 4 to 5 million passwords per second, at least on my machine, so if the password if below 7 characters, it should be able to crack it in one day. However, if the password is 7 or more characters in length, then it will take a substantial amount of time. When I did this, my password was 7 characters in length and it took my computer just over 3 days to crack it.
on Dec 24, 2010 | Computers & Internet
How can I a boot disk system failure on my Asus without a system disc?
Nov 30, 2012 | Computers & Internet
Logical drive has been disabled due to possible data loss
Replace the HDD whose led is blinking in AMBER ( orange ) colour.
Mar 11, 2012 | HP Compaq ProLiant DL380 G4 Server
My Studio 1535 has crashed. It will not reboot Vista. When I turn it on it will show the Dell Splash Screen and then go to the "Windows Error Recovery" screen which shows these options:...
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer. Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Sep 23, 2011 | Dell Studio 1535 Notebook
My HP e9120f gave me the following error message the other day. "reboot and select proper boot device..." My first thought was my hard drive was bad. I could turn off the computer and after a...
You might have another part that has gone bad. Check the RAM and see if it gives you any problems.
There is a program call mem test that you can burn to a CD and test your memory. But if your no longer able to get to the bios:
you def had a hardware problem.
The motehrboard bios doesnt boot from usb to install windows, how can i update the bios to boot from the usb?
Insert your USB jump drive into a USB port on the computer containing the bootable program. Copy the information to your jump drive, then insert the drive into a USB port on the computer you wish to boot the program from.
Power on the computer. When the computer begins displaying its startup information, hit the key indicated on screen to enter the computer's BIOS (the "F1" or "Delete" keys are commonly used to access the BIOS).
Browse through the menu options in the BIOS to locate the computer's startup and booting options to locate the "CMOS" menu, which is where you'll have the option to set which devices will boot at startup.
Browse though the list of bootable option---they'll be ordered as "First Boot Device," "Second Boot Device" and so on. Set the USB jump drive as the first bootable option---your BIOS may refer to the drive as a "USB Removable Floppy Disk."
Save and exit the BIOS. When your computer restarts, your program will boot first before your operating system.
Feb 17, 2011 | Intel QDI P2PE/800 Pro 82845PE Socket 478...
Whenever i try to turn on my Acer Aspire One it says: """ Intel UNDI, PXE-2.1 (build 082) Copyright (c) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller...
The problem you are mention is related to the boot order of your computer. You computer is trying to boot from the network wireless card instead of the primary hard drive. To solve this, you will have to enter the BIOS and change the boot order.
With the laptop turned off, switch it on and when you see the ACER logo press the F2 key. You will enter the BIOS. Now press the right arrow key in the directional pad until you arrive at the "BOOT" tab, you will see something like this:
Now change pressing F5/F6 the boot order, putting the hard drive at the top. Press F10, then "Y" and "enter". The laptop will reboot and the message should disappear.
If it doesn't disappear you will have a failure on the hard drive, which you will have to replace by a new one.
Feb 08, 2011 | Acer Aspire 7720 Notebook
Computer crashed and says "Missing NTLDR." I have
Hello, before you do anything drastic, my computer crashed and on reboot said the same thing. After panicking (and a cup of tea), I found the bios had defaulted to booting from the wrong disk. All was ok after I set the bios back to boot from the correct disk again.
Hope this helps!
best wishes,
Dec 29, 2010 | Toshiba Satellite M35X-S149 Notebook
Booting my laptop
This is a "security" feature, to allow _only_ the person who knows the password for the encrypted disk-drive to use (and boot from) the unit. There's no way to bypass this security.
May 09, 2009 | Acer Aspire 5315 Notebook
Computers & Internet Logo
David Payne
David Payne
