Question about Goodman Heating & Cooling
While ac is running, the fan blower comes on for a couple of minutes then stops and there is a humming sound at the blower motor. Is it the blower motor?
  • 958 Answers
Yes it is the blower motor,
it is stopping due to mechanical problem.
it may need a simple re-oiling of the bushings or bearing replacement or conversion from bushings to bearings.
tnx 4 using fixya.
drcool
Posted on Aug 13, 2008
  • 594 Answers
Yes the blower motor is trying to go out. you can probably take it out of the casing and spin it with your hand to get it going again but it will only last a few min. i would suggest to by a new a/c
What causes my AC to sometimes stop cooling & can hear a buzzing from the motor?
The blower motor probably needs very badly to be cleaned, lubricated, or replaced, Michael.
Aug 06, 2014 | Heating & Cooling
AC blows cold air, fans stop blowing
I think you have a "variable speed resistor" problem, it's overheating. It's an electronic device usually located near or attached to the AC motor blower that controls the fan speed. This is a common problem with aging AC blowers with electronic controls.
Apr 13, 2014 | 2001 Pontiac Sunfire
Blower fan does not operate
I assume you are referring to the indoor blower motor. can you here a "hum" from the blower motor as if it is trying to come on and sounds "stuck"? If so, while its humming safely give it a spin (WATCH YOUR HANDS BLOWER WHEEL IS SHARP) . If it takes off and runs you need a capacitor
Oct 03, 2012 | Goodman CKL30AR30 Air Conditioner
Ac stops blowing and is making humming noise started blowing again after van was off for a while but still has humming sound.
sounds like you have a bad blower motor their replace the blower motor should do the trick.
Aug 27, 2011 | 2003 Dodge Caravan
Hi' I have a coleman roof top AC unit on a 1991 Tioga i just purchused a couple of months ago! When i turn on the AC it makes a humming sound...no fans spin or no air comes out! If i let it hum for...
The blower motor is seized up...you will need to get up top and remove the cover...then remove the fan blades and the motor and replace the motor....sometimes a temp. fix will be to get WD-40 and then oil worked into the bearings...but that is usually a very short lived fix...
Replacing the motor can be frustrating and time consuming, so you may want to hire someone to do it for you...you may also find that a replacement unit is more cost effective..
heatman101
Jun 14, 2011 | Dometic Rooftop RV Air Conditioner
The ac will run then the blower just stops. then it will come back on like 10 minutes later for just a couple minutes
Sounds like the blower motor is junk or has a bad connection. Check the ground on the motor. Does this car have manual controls or Auto temp control.
May 29, 2011 | 1998 Buick LeSabre
AC fan won't run . No air coming out at all. Also heater won't run.
First check the fuse for the fan. If it makes a humming sound, check if the fan blades have jammed somewhere and being physically stopped, it creates a humming sound.Also check the insulation of fan armature to see if an of the coils have shorted out. Also dont forget to check the condenser/capacitor which initiates the rotation of the fan................sodeep
Sep 04, 2009 | 2000 Dodge Caravan
Samsung Ac compressor stops after 20 minutes and fan keep running. Again after 10-15 minutes if ac is restarted the cooling happens for 20 minutes and compressor stops.
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
Mar 15, 2009 | Samsung AW0693L Air Conditioner
Ruud a.c. unite
Push in on the door safety switch,and use a screwdriver to help start the fan motor, while it calling for fan-on, if it takeoff and run , youll probably need to changeout the fan motor & capicator!
Sep 01, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
109 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
