Question about Whirlpool Refrigerators
Mod.# ET18GKXGHO 2 ser.# EJO631773 Water leaks on the inside on the back .
4 Suggested Answers
  • 5370 Answers
SOURCE: i am an independent appliance tech. i replaced a
• Is the water tank frozen because the Refrigerator temperature is too low? Try selecting a warmer setting on the main display panel. If the tank is getting cracked due to over freezing then either the temperature is set very high cooling or the defrost is not working properly, get the defrost checked.If too much ice gets collected in the freezer section, the internal parts gets over cooled and this cause freezing to some parts and they gets cracked.Other wise this eater tank parts are quite strong to function and work properly as well as last long.-------- --------- Also click this link and check the tank wiring diagram:--- http://downloadcenter.samsung.com/content/UM/200907/20090726134517125/DA68-01819A-EN.pdf ----------- The wiring diagram on page number 37. Check the water tank heater wire.May be that heater wire is got loose and due to that water tank got over cooled and this cracked the tank.------ --------- This will help.Thanks.Helpmech.
Posted on Jul 06, 2011
heatman101
  • 43501 Answers
SOURCE: Load periodic clunking noises. Water
Here is a tip that I wrote about the clunkingor thumping in refrigerators...
Refrigerator Clunkingin back
heatman101
Posted on Sep 10, 2011
  • 842 Answers
SOURCE: mod.g17fvcxw001 leaks water from vents inside
Hi,You will need to look at either the filter or water line too and from the filter housing for the leak. I have seen filters with flat spots on the "O" rings that will cause them to leak, even brand new out of the box.
Good Luck
Posted on Oct 10, 2011
Dishwasher leaking from bottom of dishwasher. Maytag Portable Dishwasher MOD MDC4650AWWO SER NW4610106
Hi
The issue is with the water not draining as something might be blocking the drain pump assembly thus the water is leaking. To solve this issue you'll have to take the front lower access panel out and then clean the drain pump assembly completely, also clean the impeller and chopper assembly located at the bottom of the unit. After this is done the issue should be resolved, if not then check the float switch mechanism and make sure that is fine. Hope this helps...please post back for further assistance.
Daniel
Jun 28, 2011 | Dishwashers
GE Potscrubber Mod GSD3630Z00WW Ser Vs783297B 5.2 amps Other 44.4 amps leaking underneath
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
760o7808gh
Aug 09, 2010 | GE GSD4100J Dishwasher
Water in door works but ice maker quit .its a roper side by side mod#rs25aqxfnoo ser#sg1235753
That ice box uses a dual solenoid dual mechanical valve and operates the water on one side and ice maker on the other. The solenoid for the icemaker (which has a smaller water line) might be open or the mechanicals inside may be fouled with sand and sediment or lime deposits. If that checks out then the thing that powers that water valve is the ice maker itsel. So if your water valve is good then your ice maker is bad most likely. I have a page which shows repair photos and manual: HERE
Feb 14, 2010 | Refrigerators
Dry-spin doesn't work, because after rinsing the clothes are still wet. MOD- VBXR1070WOWW SER-SZ107967H
I'm assuming this is a G.E. brand because of the model number. Take the four screws off the very bottom panel of the front of the washer. Inside you will see a twist off rubber cap. Place a pan under it big enough to hold 2 quarts, and twist the cap open. When the water comes out and it is empty remove any accumulation of lint, loose change, etc. This should be done monthly to help the washer discharge the water on spin cycles.
Also, inside the door is a flat rubber ring. At the bottom pull the flap back. There are small holes there for the water to drain out. Lots of stuff accumulates there too, even as large as a pocket knife or ball point pen. Check that daily when washing.
May 19, 2009 | Washing Machines
Whirlpool ultimate 2 model#lsw9750pw3 ser.ct1941128 leaking in front. appears to leak from a bow with 2 hose connected.
Your water pump is attached to the motor and is probably the source of your water leak.
Replace the pump.
Use the attached video to show how to access the cabinet and pump.
May 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water dispenser not working
replace your duel water valve / water side is bad
Nov 26, 2008 | Kenmore 53642 / 53644 Side by Side...
The solenoid on the water inlet valve leaks... need illustrated parts list so I can order proper parts assembly
you have the info rite / it is called the water inlet solinoid valve. this along with the mod. ser. # is all you nead to order the replacement valve. hope i was a help
Oct 20, 2008 | Refrigerators
Refrigerators Logo
77 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
