Question about Vacuums
Parts replacement We have a Hoover Steam Vac that has a broken part #10 in your picture or Part # 37271035. Does this part cover the whole top section of the Vac? Is it hard to replace? Where can you get the best prices on Hoover parts? I have been on Hoovers website and they don't even recognize this Steam Vac. which is hard to believe they don't even recognize their own unit? Thanks Ray
  • Ray Gibson Aug 14, 2008
    I will dissamble it before ordering the hood, Thanks, Ray
    President:
  • 1,673 Answers
This the hood or top cover. There some screws on the bottom as well as on the top, then it comes off.
Posted on Aug 14, 2008
Install upper control rod
Hi, it's Jeremy from Crucial Vacuum.
To attach the upper handle to your Hoover Steam Vac remove the clean solution tank (upper tank) from the deep cleaner. Then, attach the upper handle to the lower handle by pushing the upper handle down onto lower one. Use the provided bolts to secure the handles. Push the bolts into the accompanying holes on the front of handle. If the bolts do not go through the holes easily, your handle is not pushed completely down. When the handle sections are completely together, squeeze the trigger on the upper handle to snap the trigger rod into place.
If you require further help with your assembly, you can find a step-by-step manual at: http://www.searspartsdirect.com/partsdirect/user-manuals/f5865900-hoover-parts-steam+vac-manual
You can also purchase all of your Hoover Steam Vac replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+steam+vac
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 10, 2014 | Vacuums
I have a Hoover Steam Vac. Even though I don't
There in the trigger assembly is a release button that might be broken.
Nov 28, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
There is no suction on the steam vac help
the srub brushes have 2 belts that run the beater and scrub brush. These are probably broken. A vacuum cleaner repair shop should have them. About 8 to 10 bucks to get replacement parts.
Jun 02, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hi, i have a hoover steam vac agilty. the brushes on the bottom front quit spinning. they are not locked up as i can freely turn them by fingers. is there a belt that i need to replace? if so, how do i get...
The brushes on all hoover steam vacs are air opperated it uses the suction of the vacuum motor to spin a turbine and in turn spin the brushes. Most likely that path of air is clogged with hair or carpet fuzz. On the top of the machine there is a little clear cover undr that cover there is a screen which keeps that hair for entering the turbine kinda like you clothes dryer lint trap. Take the cover off and clean that screen this should help. If you have any other questions or need parts for that machine or any other visit www.stevessewandvac.com
Aug 12, 2008 | Hoover Vacuums
Spin brushes on Steam Vac
The cover is only secured by 3 screws. One on the top, and two other on the underside. The two on the underside are located on the black plastic and are deeply recessed. After removing these 3 screws, on the top there are 2 snap in post. Simply squeeze these posts inward, towards the center and the cover should lift off.
Jul 19, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover F7458900 steam vac brushes won't turn
No, there is a turbine that turns the brushes. You can take the top cover off to get to it, open it up and clean it out and then try it again. If that doesn't work, then replace it, or just replace it to begin with.
Jun 08, 2008 | Vacuums
I have a Hoover Steam Vac V2, model #F7430-900. The spring loaded valve on the soap dispenser needs replacing -is this possible or do I have to get the entire tank. Thanks
Hoover Steam Vac V2, Model #F7430-900
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You cannot replace the spring loaded value on the soap dispenser – it is a whole assembly and would need to replace the entire tank, you can buy them new or sometimes a local vacuum dealer may have a good used one on hand and that would work as well – check the yellow pages for a local vacuum dealer or Hoover dealer for replacement of the part.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 16, 2008 | Vacuums
Vacuums Logo
94 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
