Question about Acer Computers & Internet
I have an Acer 3680 that has slowed down to a crawl. Can you fix this so that it runs at a normal computer speed?
    Scholar:
  • 65 Answers
Hello, thier are several ways to help speed up your system.
  • you can configure your start menu, and close any programs that are running unnessissarily.
  • you can run a checkdisk through you ms-dos prompt (just type "checkdisk /all" at the prompt and press enter)
  • check your ram, some times ram sticks can go bad or burn out. or just may need to secure them tighter.
  • also: their is a clean-up that can be done from time to time. in your computer folder: right click the drive you want to clean up and click the properties tab. thier should be a clean up button. also in the more options tab at the very top their are other system repair options such as defrag and scandisk. ect...
  • what speed is your processor? maby you could upgrade your proccessor to a higher speed alog with your ram. these are always good ways to improve your system. just not always inexpencive.
I hope these tips help, if you can think of any more specific inquieries to your problem, just ask.
Posted on Aug 13, 2008
    President:
  • 2,961 Answers
Uninstall any programmes you no longer use, run a virus and spyware scan, as this alone may be the cause, if you have non installed go here:-
http://free.avg.com/ww.download?prd=afe
check you have atleast 1GB of hard drive space free as this can cause slow ups and look how much memory is installed as you may need to upgrade the amount of memory to work newer and more memory hungry applications
I have a acer laptop that I let my son use and I've noticed that it is very slow and also it gets very hot. What do you think the problem is?
Dear Kristen,
1. Your laptop is running slow because there are too many applications running in the background. Go through the start menu and remove them if you don't need them.
2. Defragment your hard disks. Use a tool such as O & O Defrag Pro.
3. Your Acer heating up is a normal issue. Some older acer laptops heat up quite a lot. This is not an issue in laptops purchased after 1/1/2010.
If you are worried, get your laptop checked and serviced by a qualified technician or just simply hand it over to the nearest service center.
Oct 19, 2012 | Acer Computers & Internet
Computer slows down to a crawl after windows updates
after the re installation also if the computer is working slow. there could be some hardware issue.
Oct 28, 2008 | Acer Aspire 5610-4648 Notebook
Computer is running slow, usage space is almost full
If by "usage space" you mean RAM, it is time to install more RAM, I'd recommend ~2-4GB RAM. If by usage space you mean the hard drive, clear a BUNCH of space. It will make Windows be able to use virtual memory, which will speed things up a hair.
Dec 19, 2010 | Acer Aspire 3680-2633 Notebook
Healthrider H550I show 20 mph then slows down to crawl
OK two things, first is that you must check if the belt is in good condition and the deck also. second, we turn to the recommendation, review the motor controller if any diode or MOSFET is bad, and maybe check the main motor has to re-coiling
Feb 05, 2010 | Exercise & Fitness
Very slow and problems with dvd burner
hi..the solution is u need to re-format your system and Hard Drive and re-install a new OS..i think your system is a lot of Bugs/error came from virus or worms...but b4 format back-up your files using like,USB flash drive or external Hard Disk/Drive..Good Luck mam/sir...God Day and God Bless..^_^
May 11, 2009 | Acer Aspire 3680 Laptop
Aspire 3680-2682 just too slow
To stop the machine shutting down,
Go to Microsoft and install updates,
Service packs etc...
Then run a scan to check for viruses.
This should stop the shutdowns ( if there is no damage to system already ) this should resolve that problem,
Wireless is abit slower ( that's just wireless )
Wired is better, if this is possible.
Slowness issue....
Run...Disk-cleanup, Defragmenter, ( from start, accessories, system tools )
Run CHKDSK.exe from a command promt, this is start, run box, type CMD, in the black screen command prompt, type CHKDSK.exe, this will check system files are good,( for the shut down issue too )
Delete any applications you do not use or are old. in Program's & feature / all programmes.
( in start, control panel, all programmes /features.
Scroll...check for outdated programmes, un-install them..
Increase the performance now.
Go to start, control panel, system, advanced system properties, advanced tab, performance tab, performance settings,under visual effects, adjust for best prformance.tick this box. ( better speed )
Increase the page file size too...
start, contol panel, system, system properties, advanced tab, under virtual memory, click change, click custom size, (( in the 2 white boxes put the recommended page file size ))
((look at the bottom it says total page file size for all drives-RECOMMENDED its the middle value ))
Put this figure in the 2 white boxes, click set, and click ok to complete procedure.
(( you should get a dialog box saying, you must restart system for the page file and the performance switch over to be functional.
Have a shut down and re-boot.
If this is done correctly, this will improve performane for you.
Regards
Richard.
Mar 13, 2009 | Acer Aspire 3680 Laptop
Avanquest system suite 9
you have to run one suite at a time , if you are running both the suite than the speed was automatically slowed down . but after doig you again have to check wheather any windows file missed or not if missed than you hav to istall that again thats the major prob.
Jan 29, 2009 | HP Pavilion Media Center a1330n - AMD...
Acer Aspire 3680 too slow
Sure but if it has acually been slowing down you must also find the problem. Have you disk cleaned up and defragged your hard drive lately. Cleaned out all the junk from your internet exploier?  Have you gotten rid of everrything that you don't need or want. Slowest thing in a computer is the Hard drive seek/read time.
  According to you manual (Link below) You can have up to 4GB total memory. Two strips of 2GB each soDIMMs
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=1016&formid=3425&website=AcerPanAm.com/canada&siteid=7297&words=all&keywords=&areaid=17
Jan 04, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3680
sometimes norton fights against other programs. It may be a problem with norton and vista. check into update patches from microsoft.
Apr 15, 2008 | Acer Aspire 3610 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
