Question about Panasonic Televison & Video
I can't find a part # for a screen for a Panasonic pt-51hx42f TV. Can you help? Thanks, Pat
  • 2,337 Answers
Click here to find a list with the parts numbers for your TV.
Posted on Aug 13, 2008
SOURCE:
I have a 51" Panasonic Rear Projection HDTV,
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Aug 12, 2013 | Televison & Video
I HAVE A PANISONIC HDTV1808I PROJECTION TV MODEL PT-51HX42F ITS A 2003 YEAR IT WAS WORKING THEN WENT TO TURN IT ON AND NOTHING ITS POWER RED LIGHT BLINKS 5 TIMES THEN PAUSES AND STARTS BLINKING THE SAME...
You need to replace the "Lamp" check Google Shopping for pricing. Enter your TV model # and add the word "Lamp" Make sure you get a Phillips or Panasonic lamp don't get a Chinese knockoff. They don't last!. Hopr this helps.
Jul 02, 2011 | Panasonic Televison & Video
Panasonic pt-51hx42f replaced 2 convergence chips and 6 convergence resistors. still can move any of the convergence set-up arrows. was told it might be the pico fuses. But I cant locate them on the...
No thats not the Problem you have to know HOW TO ENTER SERVICE MENU Their is a Long Step in getting into the SM
if not done correctly you can really Mess this TV up! Once you Enter the service menu then you can go to convergence and adjust
to correct Pattern,Then you Must Exit correctly with the Save Mode to Save alinement or you will have to adjust all over again.
Sep 20, 2010 | Panasonic PT-51HX42 51" Rear Projection...
Tv wont turn on
how was the pix on your tv befor it shout off if it look like a 3d piix you have bad con.v ic to see f you do open it up and look for two big ic or stk. and look for the power suppy line and unplug it now tv should come if it do come on you have bad con.v stk 392-120or 110
Dec 07, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Wavy lines appear across the screen
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Pioneer PT-51hx42f
hello. it sound like a power supply . problem to me.!!! check it.!!! "good luck"
Aug 02, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Slinte please help me fix my Panasonic!
Yes you can respond directly to me at [email protected] and I would be happy to assist you with your problem.
Jun 19, 2008 | Televison & Video
Panasonic PT-51HX42F Alignment problem
need to replace both of the convergence ICs STK392-110 you can get new ICs at this link and they will provide free installation instructions with pictures so you can do the repair yourself. They also offer free online tech support in case you need more help. Its fairly easy takes about 45 minutes from start to finish. A repait tech will charge about 400.00 the parts cost 20.00 each at this link you need two.
http://servicemanuals.vstore.ca/
Apr 27, 2008 | Televison & Video
Sometimes, in the Panasonic projection sets, one of the convergence IC's shorts out and draws so much current that one of the resistors next to it glows red hot. The computer senses the extra current and shuts the set back off. This is quite an easy problem to correct, but the set should be serviced by a qualified tech familiar with panasonic projection sets.
Aug 23, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
