If the blinking light is on Toner Low (4th light starting from left), press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
For further assistance, please contact Lexmark Technical Support
We would like to know more about the flashing lights you're referring to. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
For us to give the common light sequences, please provide us information which light is flashing on the printer.
For further assistance, please call Lexmark Technical Support.
After installing a new cartridge and the blinking light is on Toner Low, it means that the photoconductor is almost full and should be replaced soon. Press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, replace the photoconductor kit.
If ! light displays a solid light it means that the printer front door is open, print cartridge is missing, or a flash option has been installed that is not supported. Please Close the door, install a print cartridge, or install a supported flash option. The printer will automatically reset.
If ! light and Continue button (green button) displays a solid light, it means a printer error. The printer memory is too full to collate the print job. To continue printing press and release continue button to clear the message. To cancel press and release the X (red button).
You may also press Continue button twice quickly to see the secondary error code. For further assistance, please call Lexmark Technical Support.
We would like to know more about the lights you're referring to. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
Since the printer will print, for us to give the common light sequences, please provide us information which light is orange on the printer.
The light is second to the right is Toner Low. If ! and toner low displays a flashing light it means that the photoconductor kit is full and must be replaced. The printer will not print any more pages until the photoconductor kit is replaced.
Press and release Continue button to print a photoconductor kit instruction page. If the light is still blinking, replace the photoconductor kit.
the first orange light has an ! the 4th light is toner light. What does the ! light mean
