Question about Canon NP 6035 Copier
Faded black and white print out (Canon NP 6035/6028)
Thanks;
The motor gear wheel arrangement inside the toner box does not seem to roll and load in toner, hence the print out is fade.
How do I remove the toner box for sericing, what voltage do i expect at the motor terminal, Perhaps you can help with a service manual, I will ever be grateful.
  • Canon Expert
  • 1,326 Answers
Are you getting a E0020 code? If not there is nothing wrong with the hopper. Has the OPC unit been replaced recently? Also, have you looked at the developing unit? Dose the developer Mag. roller have a even coat or brush on it? If not have you cleaned the S-Blade or doctor blade? Also, have you cleaned the optics?
Posted on Apr 14, 2009
I have a Canon NP 7130F which prints out only blank paper
check cartridge setting how-
check all spring on correct place
check ITR spring touch point
check printer to cartridge touch point
Apr 01, 2014 | Canon NP 7130 Black and White Copier
What causes a white streak and faded print to appear on copies?
Most often on the PC940 this means your toner cartridge is getting low on toner. To prove this is the cause, just remove the toner cartridge and while keeping it relatively level, shake it side to side a few times. This will re-distribute the remaining toner in the cartridge. Re-install and make a copy. The black streak/faded copy should be much better. If so then I would go ahead and get a new cartridge on the way.
Thank You for using Fixya.
Testimonials are always appreciated!
WheatlandServices
Oct 21, 2010 | Canon PC-940 Black and White Copier
How do I replace the main top print roll on a NP6551 copier?
It is to hard to explain in typing so if you could call me in the morning say around 8am PST I will talk you through how to get the upper fixing assembly apart. If you need this tonight 6/13/10 go ahead and call me…. I am in San Diego.
Thanks and I will do what I can to help you.
Chris
Jun 14, 2010 | Canon NP 6551 Black and White Copier
How do I add toner to NP 6551 copier?
toner supply box is located on top of the machine on the right side there is a slot there were you can put the toner.
May 23, 2010 | Canon NP 6551 Black and White Copier
Samsung CLX-2160, keep getting faded toner stripe down page. changed toner numerousof times The same problem occurred for me after only 300 pages. The black color on the all prints is faded out on the...
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
May 18, 2009 | Samsung CLX-2160N All-In-One Printer
Will not reset for next copy
Sounds as if it is low on toner.When they run low, the motor will continue to run trying to add more toner.The toner add system is a glorified flour sifter.Eventually it will set the add toner on.Good Luck
Mar 24, 2009 | Canon NP 7130 Black and White Copier
Paper jam flasher
Henry, try blowing it all out with compressed air to clear jamb.
Nov 27, 2008 | Canon NP 7130 Black and White Copier
Canon NP-1215
1-toner may be bad (moisture)
2-primary wire not charging - no contact or broken (unit with a thin wire above drum)
3-seperation unit shorting out (wires under the drum)
Sep 01, 2008 | Canon imageRUNNER 1023iF Black and White...
Gray background, but copied text is visible
With toner being dropped I would take a close look at the cleaning unit next to the drum. Sometimes they become clogged or wear out. Inside the machine, can you see toner that has spilled or piled up? If so that is an indication of a faulty cleaning unit.
MM85
May 23, 2008 | Canon NP 7130 Black and White Copier
Canon NP 6035 Copier Logo
187 people viewed this question
old marine
old marine
