Programs like Gom player and IE. When I try to open Gom player for example it says that it stopped working and when I click on "problem details" is shows this:
Problem signature: Problem Event Name: BEX Application Name: GOM.exe Application Version: 2.1.28.5039 Application Timestamp: 4cd8f983 Fault Module Name: StackHash_6913 Fault Module Version: 0.0.0.0 Fault Module Timestamp: 00000000 Exception Offset: 0237d3b0 Exception Code: c0000005 Exception Data: 00000008 OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033 Additional Information 1: 6913 Additional Information 2: 6913beb4fa4b1018024e4fa94497876d Additional Information 3: eb0e Additional Information 4: eb0e75a1633bb6235622ebbaa80003d9
Recently I've used Intel® Driver Update Utility and updated "Intel® 6, 5, 4, 3, 900 Series Chipsets" from "Intel® Chipset Software Installation Utility" as it said it needs updating for compatibility issues.
Could this be the cause?Programs like Gom player and IE.
Problem signature:
Locale ID: 1033
this is the details of the problem one more time:.............. Problem signature: Problem Event Name: BEX Application Name: GOM.exe Application Version: 2.1.28.5039 Application Timestamp: 4cd8f983 Fault Module Name: StackHash_6913 Fault Module Version: 0.0.0.0 Fault Module Timestamp: 00000000 Exception Offset: 0237d3b0 Exception Code: c0000005 Exception Data: 00000008 OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033 Additional Information 1: 6913 Additional Information 2: 6913beb4fa4b1018024e4fa94497876d Additional Information 3: eb0e Additional Information 4: eb0e75a1633bb6235622ebbaa80003d9this is the details of the problem one more time:.............. Problem signature: Problem Event Name: BEX Application Name: GOM.exe Application Version: 2.1.28.5039 Application Timestamp: 4cd8f983 Fault Module Name: StackHash_6913 Fault Module Version: 0.0.0.0 Fault Module Timestamp: 00000000 Exception Offset: 0237d3b0 Exception Code: c0000005 Exception Data: 00000008 OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033 Additional Information 1: 6913 Additional Information 2: 6913beb4fa4b1018024e4fa94497876d Additional Information 3: eb0e Additional Information 4: eb0e75a1633bb6235622ebbaa80003d9
Recently I've used Intel® Driver Update Utility and updated "Intel® 6, 5, 4, 3, 900 Series Chipsets" from "Intel® Chipset Software Installation Utility" as it said it needs updating for compatibility issues. Could this be the cause?Recently I've used Intel® Driver Update Utility and updated "Intel® 6, 5, 4, 3, 900 Series Chipsets" from "Intel® Chipset Software Installation Utility" as it said it needs updating for compatibility issues. Could this be the cause?
Re: A lot of programs in widows 7 has stopped working
Hi What happened recently? Have you installed driver or new device ,, ? Give us samples or some names for software that stopped working, please. Good Luck
Go on with the following steps: 1. Start PC 2. Hold down or press the F8 key frequently. 3. Soon a text menu will appear. 4. Select ( Last Known Good Configuration ), using down arrow key. 5. then, Press Enter Key
Please, tell us your results Good LuckHi,
1. Start PC
Good Luck
You can't post conmments that contain an email address.
You can purchase a recovery disk from the manufacturer for around $15 plus shipping. It will put your system back to original factory settings. Please note that your settings, programs and data will no longer be there when you do this.
Unfortunately a lot of devices do not have Windows 7 drivers and some manufacturers are reluctant to provide these drivers for their older products. Try going to the Belkin WEB site to see if there are Windows 7 drivers for your DVD creator. THIS WORK AROUND MAY WORK. Try running XP emulation within Windows 7 - for details how to do this, check out this WEB site. http://www.microsoft.com/windows/virtual-pc/download.aspx
Go to program,look for tascam folder and adjust channel 1&2 to analog.This should make your music program work fine.And then do research on both analog and digital recording.
-William Marcelin
You will probably have to look on the net for a driver that is compatible with windows 7 for your bluetooth device. If you cant find one designed for windows 7 you could try a driver made for vista as many vista drivers work for windows 7 devices as well
Your problem is a little hard to say. Have there been any power outtages or has you computer been powered-off rather than the regular shut-down procedure. Windows registry and programs can be thus corrupted.
Also computer viruses can disrupt programs so please run for example Mcafee's free online anti-virus to rule-out a virus problem. http://us.mcafee.com/root/campaign.asp?cid=45694
Even if you have an anti-virus installed, it needs to be running the latest virus definitions.
You could also try in programs accesories system tools to select "system restore" and bring back your computer to a date where you understand the problem was not happening. (Try this one last)
Have you tried going to windows update and installing all the updates? Vista was released with a lot of bugs and Microsoft releases updates to fix these bugs on a regular basis. Let me know if this solves the problem or if you are not sure how to do this.
Problem signature:
Locale ID: 1033
Hello;
I've done that but it didn't work. Still got the same problem.
