Question about HP Office Equipment & Supplies
Text being scanned does not produce a clear print to our cannon ip18oo printer
  • pfsnider Aug 13, 2008
    the answer that you gave is of no use what so ever the printer has been cleend up and we can get clear prints from the screen to the printer but not from the scanner to the printer
  • 1,498 Answers
Hello pfsnider,
When scanning documents to image without OCR, you need to go with a higher resolution than you would when scanning a picture. Weird Huh? This makes for huge doc sizes so be prepared for that.
The resolution default on the scanner software should be set at 300 dpi minimum. If there is fine print, up it to 600 dpi.
Color settings should also be high.
The default file type to save the raw data should be Bitmap (BMP). That way no detail is lost through compression. You can then open the image scale down the size (transform, resample), while keeping resolution high. Then do a Save As to a JPEG format. This way you get rid of the the massive file size without losing the detail. They will print full page without being blurry.
Hope this helps. I can walk you through the process if you like.
Remember: Good things come to those who Rate.
Thanks for using FixYa.
Mike
Posted on Aug 13, 2008
    Master:
  • 788 Answers
If you intend to scan something to be able to print it latter I would scan at a resolution of at least 600dpi (dots per inch). You should be able to select your scan resolution in the scanning application.
    Genius:
  • 1,665 Answers
Print another document ie. from word to see where is the problem. Printer or scanner.
    Master:
  • 623 Answers
Check ink cartridge...
  • ritchie dempacco
    ritchie dempacco Aug 13, 2008
    clean head
  • ritchie dempacco
    how to clean print head
    www.weeno.com/art/0899/140.shtml
    Genius:
  • 1,011 Answers
Dear sir/madam,
It sounds as if you need a new printhead. Or try to clean the printhead.
thanks
good luck
  • 594 Answers
Alot of the time if you scan something it will streach the image because of the scanner resolution. check you setting on the printer. you might need to change the settings to stop it from doing that to make he image more clear. if that doesn't work than also some printers are just like that when you scan something. it will also make one page turn into two pages. that may just be the way the printer is.
YADAYADA.Hang on. That amber light remains on BUT THE THING IS WORKING. Both scanning a text document and printing say an Email. I'm happy with that. Keith
Hi Keith
You need to reply by clicking COMMENT under his post in your original posting. That was Yada gets a notification. Fixya gets 7 million posts a year, so the chances of him seeing it are slim to non-existent.
This link takes you too your original question.
Andrew - Fixya Moderator
Ggeriatric with Cannon MP230 trying to instal new genuine 510 black...
Oct 12, 2016 | Canon PIXMA MP230 Multifunction color...
How do i get my cannon mg 2520 printer to scan
Have you installed the scanner software on the computer ?
Mar 30, 2016 | Cannon Office Equipment & Supplies
Cannon LBP 2900B printer doesnot printing documents but when it restarts it was printing please help me what to do
Dear
pl. try to make printer on line.
click on START-PRINTER AND FAXES-right click on printer ICON-select USE PRINTER ONLINE,make a test print, if it ok, check your anti virus lapse date or reinstall OS.
Thanks.
Feb 26, 2015 | Cannon Office Equipment & Supplies
Cannon MG6120 printer will not print text. I have cleaned print heads several times. I think I have a clogged print head. Which of the 2 black ink cartridges prints text? How do I clean a clogged print...
I think you need to do is reinstall you software driver for the print program and start with known parameters. Then you can try to clean the heads. You should get something out of the printer if the heads are plugged it might be a dot or smear on the paper.
Dec 31, 2012 | Canon Pixma MG6120 InkJet Printer
How can i copy a legal document with cannon MF3200
you can print legal document through print command go to print property and give command on legal size.
but you can't scan legal document in single go.
if it urgent to scan in legal scan it in 2 parts then join using some software like corel draw or word.
Jun 10, 2009 | Canon MF3110 All-In-One Laser Printer
Cannon IP5300 line missing in print
you should open the software or on the printer select clean print cartridges, or align cartridged
Mar 17, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
Feb 27, 2009 | Epson RX620 All-In-One InkJet Photo...
44 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
