Audio/sound on my tv
The sound will not work on the tv i.e i put the colume up to max with the remote control but it still stays at mute
    Sergeant:
    Champion:
  • 258 Answers
Check switch for internal/external speakers.
also check A/V wiring.
Posted on Aug 14, 2008
The volume on my 32 Insignia flatscreen TV suddenly went to max volume and wouldn't go down, both on the remote and the TV
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electro-medical.blogspot.com/
Nov 25, 2016 | Televison & Video
My he okevia tv all of a sudden does not have sound. I go to menu go to sound hit speaker but it is not staying. I have to constantly go to menu. What is wrong
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 17, 2016 | Televison & Video
The sound system was working this morning. Now is has no sound. Tried two different remotes and checked batteries.
Unplug Boso Solo unit for 5 minutes; then plug back in. You should hear a two-tone audio tone.
Sep 18, 2015 | Bose Solo TV sound system - Black
My isis tv has lost its sound and itnot the remote
Jul 08, 2015 | Televison & Video
My audio has suddenly disappeared. the volume button on the TV and the remote are working, but I am not getting sound. Any idea why?
Dec 09, 2014 | BenQ DV3750 Television
We lost sound on our Sansui TVD2798 even though the speakers work. Mute button has no effect. Using the remote, we can't find any option for sound off or on.
There usually is an option for turning off the internal speakers as part of the TV setup routine...BUT you may have had a failure of the internal audio in your TV. Your Zenith remote might have a MUTE button which turns off TV sound and displays a mute message or the MUTE buttton might have been pressed accidentally and has become stuck
Jan 08, 2013 | Sansui Televison & Video
Suddenlink tivo apex tv code
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1)
From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 23, 2012 | Televison & Video
I have a maxent 26inch LCD TV. Today, I was watching the TV when something very weird happened. The sound went all the way up to maximum and stayed there. I simply cannot turn the volume down...
Wow, that's a bit of an off brand...
It may be hard to find parts for.
If you can find parts, replacing the board with the audio section on it will be the easiest fix.
The cheapest fix is to get a stereo potentiometer, and put it inline with the speaker so that you at least have a manual volume.
If you are capable of running the unit into a stereo, see if the mute button works, the mute usually won't affect the line out, and you can control the audio from your stereo.
Here's a (quick and dirty) schematic of how to put a potentiometer in a speaker line correctly.
The idea is you can control the speaker anywhere from leads shorted (no sound) to leads across tv output (full volume). Choose a potentiometer value around 100 ohms with a linear taper if you can find it. Most pots will be logarithmic..for the most part it won't matter.
Mar 10, 2011 | Maxent MX-50X1 50 in. Plasma Television
My KDS-R60XBR1 turn up volume to maximum loud and stays loud
Question:
Take the batteries out of both the remotes and then try to turn the TV on with it's On/off switch built into the TV.
If it turns on and the volume stays the same, then it must be an issue with one of the remotes.
If the tv turns on and the volume ramps up to max. Please check if volume knobs/buttons on the tv itself to see if they are sticking.
If they aren't, there is something wrong with one of the boards in the tv of course. This sure should be something a Sony Service Shop can fix. I don't think it will be expensive. Maybe a $100 to $200 repair if they do the work.
Blessings,
A/V Media Guy
Nov 20, 2009 | Cameras
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
