Question about Canon PowerShot A720 IS Digital Camera
Card is locked and my zoom in and out button stoped working
Hello, My camera card locked on me, and my zoom in and out button stoped working.
  • 10,594 Answers
Hello, I'm sorry, my PC power went OFF and I lost contact in chat yet I will assist you here.
Posted on Aug 13, 2008
How can I switch on memory card?
Make sure the memory card in not write protected. There is a small sliding switch on it.
On the camera, go to Settings and look for Save to Camera, Save to SD Card.
Jan 26, 2016 | Kodak EasyShare Cameras
Camera says that my sd card is locked and it isn't
try to put some glue on a your card lock , in unlock position. But be carefully do not delete your picture by accidentally.
May 31, 2010 | Canon PowerShot A710 IS Digital Camera
"The card is locked"
Take you memory card off the camera and on the side of the card you should have a small lock symbol. Make sure this is set to unlock
May 16, 2010 | Casio Exilim Zoom EX-Z9 Digital Camera
Memory card not working
If you're sure the slide switch on the side of the card is in the unlocked position, try this. Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Apr 05, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Casio ex-z80 shows card locked ?
Hello. If you look at the edge of your card you will see a small slide button ,make sure it's moved to unlock.
builderdale
Jan 28, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Camera says card is locked in the unlocked position. The internal memory works fine.
Hello
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Jan 02, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Have purchased an olympus m+2gbpicture card and want to know if it will work in my olympus c-750 ultra zoom camedia camera?
Check the compatibility of the card. If yes insert the card, turn camera on and see if the camera recognizes the card. One cannot say more because there are different memory card formats.
Hope it helps.
Sep 12, 2009 | Olympus Camedia C-750 Ultra Zoom Digital...
Casio Z80 card locked
Make sure the write protect lock is off by taking the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
If the lock is off and you still get the error then the card maybe damaged.
Hope this helps.
Good luck
Jun 22, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Card not initialized
Kyle850. I have a fujifilm finepix camera myself, and just recently had the same problem. The camera worked fine until one day I turned it on to take a picture and there was the "card not initialized" message. To fix the problem, just turn on your camera, push the menu button and use the right/left arrow buttons near the zoom button in the top left corner of the camera. Push the right arrow button until you come to the "option" window in the camera's view finder and use the "up" function of the zoom to highlight the "set-up" window. Press "ok", and use the right arrow button scoll over to the "2" tab and press the ok button again. Then use the "up/down" function of the zoom button to scroll down to the "format" tab. Press ok button again and use the "left" button near the zoom in and out button to highlight the "ok" option in the format window. By pressing the ok button here, it will reformat and reinitialize your picture card. If you do have pics already on your pic card, you may want to take your pic card to a photo center and see about recovering these pics before you go through the reformat process because there is a good chance that when you reformat your pic disk any pics on it will be gone. Good luck. SG
Feb 26, 2008 | Fuji FinePix 30i Digital Camera
"the card is locked"
try seeing if there is a button on the side of the card that moves up and down... sometimes it gets switched and locks the card...
Feb 11, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Canon PowerShot A720 IS Digital Camera Logo
83 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
