Question about Dryers
Dryer belt hoe do i route the dyer belt around the ilder and motor pulleys when simply put it around the pulley there's to much slack.
  • 5,911 Answers
There are a number of dryer belt diagrams available at Just click on the "Repair Help" heading at the top of the page and look for the "Dryer Belt Diagrams" link on the next page. The diagrams are listed by manufacturer. If you have any questions, let me know. I hope this helps you.
PS For future referense, please include your BRAND NAME and MODEL NUMBER when posting questions. This information is crucial in order to provide the best and most accurate information for you.
Posted on Aug 13, 2008
How do i get the belt around the motor pully wheel on a white knite cl637wv
If you can't push the tensioner pulley back far enough to allow the belt to go around it, disconnect the tensioner spring, route the belt, then reconnect the spring. If it's a question of having adequate strength to push against the spring and still have a hand free to route the belt, find something to jam against the tensioner to hold a bit of slack in the pulley. Make sure the jamming tool (large screwdriver, block of wood, etc.) is sturdy enough to hold securely, and well-braced. An ill-timed slip could cause severe hand injury.
If your dryer does not have a belt tensioner mechanism, the motor bracket probably has belt adjustment slots in it. In that case, loosen (but do not remove) the motor mounting bolts that go through the slots, push the motor over a bit to give you the slack you need,route the belt, then pull the motor back to tighten the belt and retighten the motor bolts. Sometimes a tight belt can be rolled onto the pulley by starting it on one side of the pulley and turning the pulley by hand while pushing the belt along in the direction of the turn, but it is better to mount the belt with slack in it; excess stretching causes premature failure.
Nov 30, 2014 | Dryers
The other pulley is spring loaded it puts tension on the belt.
Pull the pulley back and the belt will slip ight over then release the tension pulley and your done!
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
Hoe to replace serpentine belt on 1998 mazda protage
there is a tensioner around the engine (it looks like an idler pulley) there will be a 13-15mm bolt that moves the tensioner to the 'slack' position, while you are holding that tenioner slack you need to remove the belt from one of the pulleys ( usually the highet pulley is the easiest) then just reverse the order of the procedure to install the new one.
Apr 18, 2011 | 1998 Mazda Protege
How to replace a belt on my dryer, my old one broke so i am trying to replace a new belt to the drum but am finding i have alot of slack
you don't have it around the idler pulley next to the motor,if its routed the correct way you will need to pull up on this pulley to get it over the motor pulley,then when you release pressure on this idler the belt will be taught then
Nov 17, 2010 | Zanussi TC7102W Electric Dryer
Need to replace drum belt
Most dryers have a tensioner pulley that the belt needs to go around to keep it tight. The belt goes around the motor pulley and the drum, but it goes around the tensioner pulley in a way that would keep it tight (you also need to release the tension on the tensioner to get the belt around it) If there's not a tensioner pulley there has to be some other means of putting tension on that belt, look around the the other pulleys that the belt goes around.
May 07, 2010 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Routing dryer belt for kenmore 11060702990
rap the belt around the drum ribs down,if you get your pants belt and fold it in half and pinch it around 4 inches from the folded part that's how the belt will look when it goes around the pulley, your fingers are the pulley and the loop that's on the end goes onto the motor,pinch the belt together and the loop that's left on the end goes onto the motor
Mar 13, 2010 | Kenmore Dryers
Install dyer belt MAYTAG
Hello there
Here is a detailed instruction for you ok
  1. Remove the two screws that hold the control console to the dryer; they are located on each end of the console. Turn the control console forward onto its face. Disconnect the wiring harness from the dryer to the console. Press in on the locking tab and pull the connectors apart. Set the control panel out of your work area. To remove the top, insert a putty knife between the front and top panels. Locate the retaining clip and push in on it to release the corner of the top panel. Lift up on the corner and release the opposite retaining clip. Set the top panel out of the way. Two screws that attach the front panel to the sides are located at the top corners. Remove the screws and swing the top of the front panel out so that you can access the door switch wiring harness. Disconnect the wiring harness from the door switch and lift the front panel away from the dryer.
  2. Replace the Belt
  3. Locate the idler pulley by reaching behind the drum and motor assembly. Using your hand, push the idler pulley to the left to release tension on the belt2.gif. Notice the routing of the belt around the motor and idler arm for reference when attaching the new belt. Remove the belt from the motor pulley. Lift up on the drum slightly and remove the belt from the drum.
    With the rib side pointed inward, lift the drum up and set the belt around the drum. Route the belt through the motor pulley and idler pulley. Pull the idler pulley to the right to reapply tension to the belt. ok?
  4. not too hard
  5. hope this is verry helpful for you
  6. Best regards MIke
Oct 15, 2009 | Maytag PYE4500AY Gas Dryer
Installing the belt around the dryer drum and pulleys. I have a broken belt and a loose pulley at the bottom of the dryer. How to I get the pulley on? Where does the pulley attach to create the proper...
you will have to take the drum out to see where the tentioner was inserted , it is in line with the motor pulley, should be a couple holes it fits into.
putting the belt on is easy , with the lined side of the belt down on the drum take the slack at the bottom with a finger holding the belt , move the belt toward the tentioner until it touches the tentioner pulley
then with your other hand help bend the tentioner pulley with the belt on it until you can touch the motor pulley with that finger , slide it off your finger onto the motor pulley and the belt is on.
let me know if you have any questions.
Apr 14, 2009 | Dryers
Need a btlt route so i can put the new drum back in my ge profile
route the belt around the drum, pull the spring loaded idler pulley to the postion that requires you to hold it there..
put the belt : 1 through the motor pulley and around the idler pulley, or 2. around the idler pulley which ever works to keep the tensioner tight. (Idler pulley, tensioner same thing its the pulley not on the motor.
Once you put the belt on the durm, pull the idler pull so there is tension on it it should be clear how it goes.
Feb 08, 2009 | GE Profile Harmony DPGT750EC Electric...
Which wa does the belt on a Maytag Atlantis dryer run around the motor and idler pulley. I have the belt groove side down, which is the way it goes in the Atlantis, but I couldn't find a schematic for the...
Hi you're correct in putting it groove side down. Now make a loop, like when you first started tying your shoes with the slack around the drum. Push the entire loop just beneath the idler pulley through the metal channel and apply pressure to the idler pulley assembly. pushing it towards the motor pulley until you can get the loop you are holding over the motor pulley and Waa Laa you've installed your new belt. Good Luck!
Dec 10, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
Top Dryers Experts
