Question about Nextar MA933A MP3 Player
SSLlllllllllllllooooooooowwwwwwwww on the computer it plays just fine but on the player everything is so slow that the player shows one second but it is really 3-5 seconds. it is a 1gig player brand new. it has 60 songs on it now.please help! :(
  • 8,596 Answers
Make sure the songs are in the correct format
Posted on Aug 14, 2008
SOURCE:
Cd player won't play disc it says
Hello
Clean the laser pickup lens by insert a lens cleaning disc into the set, and play it at least three times. If it does not help you. replace the laser pickup unit, with same type and number. OK.
Jan 19, 2012 | Panasonic Audio Players & Recorders
CD not working
probably your dvd player's lens is dirty try to clean it using a dvd cleaner disc.
Jun 09, 2009 | Televison & Video
Files in player not showing up from computer
hey the music is on here but it wont play. basically when i plug it up to the computer the music on here plays btu it wont show on the ipod or i cant find the music on the ipod.
May 24, 2009 | Audio Players & Recorders
Mp3 Files Slowed down and Garbled
I would go ahead and upgrade the firmware. I might suspect that the sampling rate was too high, but it is playing fine on other mp3 players.
Here are other helpfu lhints:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 04, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2gb only plays parts of songs
The songs you have loaded have a restrictive license on them that only allows full playback on a computer, not on an mp3 player. If you only download songs in mp3 format, you will never have this problem.
Jan 01, 2009 | SanDisk Sansa Clip MP3 Player
I try to listen to one particular song, but Sansaclip 2gb freezes
Epsilon - delete that one song and see if the other songs play fine
unschool:
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa Clip MP3 Player
Need help!!!
Okay, timi-boo and JoD3 i believe i have a solution to your problem, on your device, go to the settings section and search for the reset all option. When you select it, everything on your Sansa should be erased.
The same problem occured to mines too. All you have to do is relax and plug it back int o you computer. The reason i implicate that it won't play on the computer is because its already erased so there's no data there, but your computer has memorized the information and just shows it(e.g. cookies) . As long as your computer can tell you theres __ this much memory left(which should be 980/40 sumthing) then everything is perfectly fine. =) Hopefull i helped! ^_^
Dec 13, 2007 | SanDisk Sansa c240 MP3 Player
Monitor runs comp game slow?
tell me which LCD u r using & what are running resolution, frequency of ur game u r playing on it.
Oct 21, 2007 | Acer AL1717 17" LCD Monitor
Nextar MA933A MP3 Player Logo
21 people viewed this question
Top Nextar Audio Players & Recorders Experts
Marvin
Marvin
Robert Graf
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
