Question about Aiwa AV-D58 Receiver
Won't come out of eco mode
Even after removing plug, stull comes on in eco mode with no other functions just red eco led on, how do i return to normal?
  • mrsmoneybags Sep 21, 2008
    yes im eco mode what do I do?
  • Anonymous Apr 09, 2009
    wont come out of eco mode
If the receiver is on, you can press the "Eco" Button and then, you have to rotate the "Multi-Joy" in the next 3 seconds to change Eco-Mode to Off. When you selected it, you have to confirm with enter.
Posted on Jan 09, 2009
  • 2 more comments
  • Sarahj40 Mar 17, 2012
    The unit won't even turn on for me to be able to do that. The power button does nothing. Unplugging the unit does nothing. all I get is that little red eco light.
  • Jerry Jul 13, 2013
    Did you ever get a fix to this? Having the exact same problem
  • Enoch Jul 31, 2013
    Did you ever get a sloution to this, having the exact same problem.
  • Nelson Garcia
    Nelson Garcia Dec 20, 2015
    How can you turn off eco mode if the Receiver is off
How do I turn on eco mode for toyota camry 2012 hv ?
Check your fuses in the fuses, box especially the relay.
Jan 22, 2015 | 2012 Toyota Camry
LG 17LX1R flashing red LED - TV won't power up
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | LG 17LX1R 17 in. HD-Ready LCD Television
Sony model no KP51WS520 red light flashes 9 times but wont turn on
Check if the TV is in an AV mode.
Normally if I leave my TV in an AV mode with nothing plugged in, it starts flashing the red led..
If no luck return it
Mar 17, 2012 | Sony Televison & Video
Forgot the combination to the lock. Is there a way to retrieve the combination or return it to its factory default combination 1, 2, 3, 4, 5
The instructions below are copied from the programming instructions (page 11):
ERASE ALL PROGRAMMING
(The "out of box" factory default will be restored)
1. At the back of the lock, remove the screw at the bottom of
the lock housing and remove the cover.
2. Take out the battery pack and remove battery power by disconnecting
the battery pack.
3. Plug in the (provided) male shunt connector into the yellow
wire female connector.
4. With shunt connector connected, re-connect the battery
pack. The lock will immediately sound 3 short beeps (if
these 3 beeps are not heard, then restart at step 2).
5. The lock will then sound more slow beeps, 1 beep for every
second it takes to clear the memory.
6. After a few more seconds, the LED will slowly alternate between
flashing red and green--disconnect the yellow wire
shunt connector.
7. The LED will continue to slowly flash green and red for 25
seconds. To enroll Function Cards, proceed immediately
as follows:
• With the lock LED slowly alternating between flashing
red and green, present the Function Card #1
to the lock. The lock will sound 5 slow beeps.
• The lock LED will flash green rapidly. The lock is
ready to enroll the Function Cards.
• Re-present Function Card #1 to the lock. The
lock LED will flash green then red, with two beeps
(indicating the card was enrolled successfully).
• Present Function Card #2 to the lock. Again, the
lock LED will flash green then red, with two beeps.
• Continue to present, in order, Function Cards 3-
9. Each time a new Function Card is presented, the
After the 9th Function card is presented, the lock LED will flash
green twice, sound two beeps, and will then remain silent,
ready for use. Note: If the lock continues to beep after presenting
the 9th Function Card, check to verify that the yellow
wire shunt is disconnected.
Note: If you only wish to use the first 3 Function Cards, simply
allow the lock to "time out" after 30 seconds.
Here is the link to the complete instructions, in PDF form. You will need Adobe Acrobat or equivalent to view them:
http://napcosecurity.com/download/PL3000_WI1280A.04_PROG.pdf
Good luck-and please provide feedback if this helps!
Nov 04, 2011 | Trilogy ALARM LOCK PL3000 Series T3 Prox...
I cannot hear any sound out of my Polaroid TDX-01930B television.
Hello
First make sure that the "Mute" function is OFF. If it is set to "ON", no volume will be there.
Your TV has a volume lock function included [Global Volume Lock].
The remote comes preset to allow independent volume control of each selected device (Global
Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that
one device's volume will control volume in all other modes. After that, you can perform Individual
Volume Unlock on a selected device to set its volume control for independent operation or Global
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
[2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for
example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
[2] Enter 9-9-3 and then press VOL+. The LED blinks four times.
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
[3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected devices.
OK
May 06, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
Nissan pulsar 1987 n13 the ECM light came one and the car cut out and won't start again and I need to know where the ECM is
Hi, the computer is under the passenger's seat. Code extraction procedure is pasted below.
READING CODES Modes will not switch while the engine is running. The ECM automatically switches to MODE I when the ignition is switchedOFF.
1984-90 Vehicles With Dual LED System
The self-diagnostic system has 5 modes. To switch modes, switch the ignition ON and use a screwdriver to turn the mode select switch through the access port on the ECM. The inspection lights will begin to flash. When the desired mode has been entered, turn the screwdriver fully counterclockwise. The red LED and green LED perform different functions in different modes.
Mode I-
This is the normal vehicle operating mode. The green LED will indicate loop status. If the green LED is not blinking when the engine is running, the vehicle is in open loop, or the HO 2 S, O 2 S, or sensor circuit has a malfunction. If the green LED is blinking, the vehicle is in closed loop. If a malfunction takes place, the red LED and the MIL will glow, indicating a malfunction has occurred.
Mode II-
Both the red LED and green LED are used to monitor mixture ratio feedback control. The green LED will function as described in MODE I. If vehicle is in open loop, the red LED and green LED will remain on or off. In order for results to be valid, vehicle must be in closed loop. In closed loop, the red LED remains off if the system is running rich, comes on if the system is running lean, and blinks at the same time with the green LED if system is within 5% of the exact air/fuel ratio.
Mode III
-When this mode is accessed, the codes stored in the ECM's memory will be flashed by the green LED and red LED on the side of the ECM. The red LED will light first. This is the first digit of the trouble code; the green LED will flash next, showing the second digit of the code. For example: 2 flashes of the red LED followed by 1 flash of the green LED corresponds to Code 21.
Mode IV-
This mode is used for checking the throttle plate (TP) switch, starter, and vehicle speed switch status. When the TP switch or starter switch is activated, the red LED will briefly flash as the status changes. For VSS status, the green LED will remain off when vehicle speed is less than 12 mph (19 km/h) and come on when vehicle speed is greater than 12 mph (19 km/h).
Mode V-
This mode represents a real-time diagnostic test of the crank angle sensor, ignition signal and the mass airflow signal. The malfunction code will be displayed only when the malfunction occurs and will not be stored in memory. The output code will appear as a single or short string of pulses. Count the number of pulses for the malfunction code.
1 pulse-CMP sensor signal lost or noise in signal 2 pulses-MAF Sensor signal abnormal 3 pulses-Fuel pump circuit shorted or open 4 pulses-Ignition signal lost
Apr 19, 2011 | 1987 Nissan Pulsar
When I'm trying to change the menu setting of my AOC Led Monier I get a error message saying "OSD Locked", What should I do to resolve this?
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
Mar 23, 2011 | AOC 912Vwa-1 19" Monitor
PD523 no picture, led blinks
Hy !
Seems to be the colorwheel. When a segment is broken, the unbalanced wheel causes vibrations. Costs approx. 100-150$. Take away back and top so you can see if wheel is not complete.
Good Luck!
Jul 07, 2008 | Acer PD523 Multimedia Projector
Aiwa AV-D58 Receiver Logo
1,313 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
