Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia i can connect wirelless with my netopia modern
  • Anonymous Oct 01, 2008
    WONT CONNECT
Bloofyx thing - sometimes connects sometimes doesnt - what gives - piece of ****
Posted on Oct 19, 2008
I need to find a driver/sortware program to get my netopia 3D reach wireless adapter up and running. all i can find are these driver scans that want me to install them and scan my computer to tell me I...
Here's a driver-free, software-free solution.
Turn your cable-modem (or DSL-modem) off.
Turn your Netopia off.
Connect:
Ethernet--port on cable-modem <-- cable --> WAN port on Netopia.
One LAN port on Netopia <-- cable --> network-port on your computer.
Turn the cable-modem on, and wait until its lamps settle-down to a repeating pattern.
Turn the Netopia open, and wait until its lamps settle-down to a repeating pattern.
Restart your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway ... 192.168.123.456
Start Internet Explorer
Type http://192.168.123.456 (or whatever numbers you see)
Login to the web-server running "inside" the Netopia.
Click to run the "Wireless Networking Setup Wizard".
Enter an SSID of your choice.
Select the 'WPA' level of encryption.
Enter a network-password of your choice.
Click OK
Restart the router (if it did not automatically restart).
Disconnect the Ethernet cable from your computer's network-port.
Click "View Available Wireless Networks".
Click the SSID of your new network.
Click Connect.
Enter the password, when prompted.
Voila! You have a wireless connection to the internet.
Oct 24, 2010 | Netopia 3-D Reach (TER/GUSB-N1)...
Stop people accessing my wirelless router
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Jul 24, 2010 | D-Link DIR-300 Wireless Router
Modern Warfare 2 Open Up NAT
Have a look in the user control panel of the router.
It's probably at 192.168.1.1 or 192.168.1.254.
Admin username and password will be as default unless you changed them.
It's probably to do with your router firewall. Ensure that it's configured to allow traffic to and from your xbox.
Mar 01, 2010 | Netopia (3347NWG-VGX) Wireless Router...
Labtec wirelless laser mouse not working
get the model number off the back of the mouse and keyboard and try to google for the driver
Mar 19, 2009 | Labtec Wireless Desktop Keyboard/Mouse...
I have Netopia 3347-02 but i have a Wireless Error help!!!
As im sure you found out the hard way, you have to swap the netopia out. You must've really snapped your lucky fingers for that one. I do this stuff all the time for a living, and I've never seen a Netopia not function correctly, a new one that is from your ISP anyway. Did you get the netopia from your ISP? or did you buy it on E-Bay, or Amazon.com, a netopia from another ISP wont function properly, but the wireless still should.
Bad modem, just swap it out. Its under warranty, its a new modem, that model number just came out last year. You wont even get charge for it. Its just frustrating when new equipment fails, and unfortuanatly, its becoming more and more common place it seems. Don't even get me started on my new motherboards from ASUS.
If its not a project, its no fun, right?...hehe
spin
Feb 22, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
WHAT ARE THE STEPS TO HOOKING UP MY WIRELESS ROUTER TO MY NETOPIA ROUTER - RIGHT NOW NETOPIA IS BEING FED BY MY CABLE MODEM
the cable modem should be giving the netopia an ip address
go inside the netopia by opening Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
once in, click on configure, lan, then wireless at the bottom
make sure the wireless box is checked
name your network (SSID its called) like randy578
then click advanced if you want to enable wireless security encryption, your key to get online securely
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, click the wireless connection icon by your clock
connect to randy578 network
you should now be online
spin
Jan 11, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Connecting a linksys wrt54g to a netopia modem
Is this an ISDN modem?
Generally: Netopia Ethernet out -> Linksys WAN port with a standard ethernet cable.
(Not the yellow LAN ports! - They are for your computers/printers.)
Dec 28, 2008 | Linksys Wireless-G WRT54GS Router...
Netopia Router - No Connection, Clicking
Yes, you need to swap the router out.
This is assuming you dont have the netopia in bridge mode with another device behind it.
spin
Jun 26, 2008 | Netopia 3346N-ENT Router (3346NENT)
Wireless connection
os is operating system ( xp vista etc). DHCP is dynamic host configuration protocol. For a wirelless connection to work you need first to authendicate on a wirelless networks ( if that is a secure network), Then depending on the network you are connected to you must optain an IP adreess a default gateway address and a DNS address. All this are listed after you type the ipconfig/all command.
Can you connect to the internet by using a cable connection to your modem?
PS:For ipconfig/all command do not type the "".
Feb 07, 2008 | Sony VAIO PCG-K35 Notebook
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
