Question about Nikon Cameras
I just bought a Nikon D60. I can't access "Metering" on the "Custom Setting Menu" "Metering" is not highlighted on the menu and I can't find the solution in the manual. Thanks, Stan
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
What exposure mode is the camera set to? You can only change the metering mode in the PSAM modes. The automatic point&shoot modes are automatic for a reason, the camera selects the metering mode and a lot of other things.
Posted on Dec 30, 2009
Nikon d60 flash will not popup
turn camera on keep the lens cap on and push the button on the side of the camera with the image of a lightening bolt at the same time help the flash door up if that doesnt work go to menu then custom setting then go to braketing/ flash toggle right and turn on builtin flash
Aug 06, 2014 | Nikon D60 Digital Camera
Turning flash off on Nikon D60
Based on what you said, it appears that you want to know how to turn the flash off on your D-60.
On my D-90, you do this by rotating the mode switch on the top center left side of the camera one click counterclockwise, from the green automatic setting, to the white automatic with no flash setting.
You can also change flash settings from the menu. For my D-90, the manual says you use custom setting "e2." Check your manual for the D-60.
I never turn my flash off from the menu because it takes too long to turn it back on when you need it. Another alternative is to simply hold the on-camera flash in the down position while you shoot.
Apr 19, 2014 | Nikon D60 Digital Camera
How do i reset nikon d60
The D-90 and D-60 are similar so this may work for you. On my D-90, you go to the menu, then click on the little pencil Icon. The top line will read: Reset Custom settings." Click on this line then click "yes" to reset all custom settings back to default. You can also reset individual settings back to default by clicking on the line for the specific setting you want to reset.
In addition, on the top right side of the camera you will find a "+/-" button and an "AF" button. Both are marked by little green dots. Press these two buttons simultaneously for several seconds and it will reset most of the custom settings back to default.
Feb 06, 2014 | Nikon D60 Digital Camera
I have a nikon d60 and cannot get the pop up flash to flash, any suggestion
Go to menu then custom setting menu then turn your built in flash on problem solved
Nov 13, 2012 | Nikon D60 Digital Camera
How do I reset my Nikon D60 to factory settings?
You will find "reset" in the custom setting menu.
Oct 29, 2010 | Nikon D60 Digital Camera
How do I set it up on my Nikon D60 to use this remote?
I assume you're referring to the ML-L3 infrared remote?
Select Release Mode from the Quick settings display. Select Quick-response remote. This will make the camera take a picture when you press the button on the remote. Well, almost. The same focusing and exposure metering delays occur as if you'd pressed the shutter release button.
You can also use the Delayed remote mode for group pictures. This gives you two seconds to hide your hand behind your back before the camera takes the picture.
By default the D60 will time out after one minute if you don't press the button on the remote. Custom Setting #17 allows you to set a longer interval.
Jun 17, 2010 | Cameras
Nikon d60
Sorry to say but this camera does not come with a internal memory with it, so you really need to get a memory card for it for you to use it.
Here;s the link for the complete specs of this camera.
http://www.digitalcamerareview.com/default.asp?newsID=3317&review=Nikon+D60
May 02, 2010 | Nikon D60 Digital Camera
I have a Nikon D60 and my autofocus has stopped working. It is not because of the lense because i have tried other lenses and the auto focus won't work with them either so it must be an issue with the...
You should check custom menu setting 2, and make sure it's set to one of the auto modes. Make sure the lenses you are using are AF-S and not regular AF lenses. The D60 has no autofocus motor, so autofocus only works with AF-S lenses.
I always suggest folks take a look at Ken Rockwell's website also, here's a link to a specific page on autofocus on the D60.
Post a comment here if none of this works and I'll see what else we can do.
http://www.kenrockwell.com/nikon/d60/af-settings.htm
Jan 08, 2010 | Nikon D60 Digital Camera
I have that same problem but i own nikon D60 what settings do
M (Manual).
You won't get autofocus, nor will you get any metering. It's completely manual.
Aug 28, 2009 | Canon Opteka 650-1300mm F8/16 Super...
Need to change language on Nikon D60
Within the menu items that can be viewed on the back of the camera, there is a language option that you can set. You may have to scroll through all of these to get the correct setting. Nikon tends to change the menu layout from camera to camera, so it may not be the same in your D60 as it is in a D300 or other model.
Jun 03, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Cameras Logo
62 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
