Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Instalation I bought a sound card to replace my on board sound card. I don't know which are the power, ground, left and right pins on the new card, so I don't know where to plug each connector. Can you help??
  • Anonymous Aug 19, 2008
    I want to downloud a driver for my Creative SB Live ! 5.1 ! Digital
  • IT aid
    IT aid May 11, 2010
    could you write more ditals about it what model anythink?
  • 594 Answers
Go to www.creativelabs.com or www.soundblaster.com
sound blaster is an off brand of creative labs. you can get your driver at either of the sites.
Posted on Aug 23, 2008
Visio e422ar no sound no picture
Just got one of these in. Same problem. You may not have to purchase parts for this one. If you can open the back cover,(there will be two wires still connected to cover upon opening, remove these, to actually pull cover off) be careful. You will find a power supply board on the left side. Take the power supply out. (Be sure your TV has not been plugged in for about 4 hours to reduce shock.) You will need to resolder the pins on resistor RP 12. I found a bad ground. Also resolder pins on Transfomer T2 and T3( these are yellow boxes on top of board). We are are soldering under the board of coarse. Now on the right side of the power supply board, find the signal board. You will see four grounding strips taped in black. Purchase at hardware store, metal tape (used for taping duct work). Retape the four ground straps, while pressing down on these springing ground straps. Many, many times a bad ground will cause problems as described. Replace boards and cover and cover wires (as mentioned on removal). If you cannot do this, take this info to a TV tech. Let me know how this works. Thanks for asking, sincerely Matt of Martins TV Repair.
Jun 04, 2013 | Televison & Video
I just bought the car last week, and only the right front speaker is working. I thought the stereo was bad and replaced it with a new one only to find the same issue. Is it possible that they may have a...
Every stereo has it's intricacies, once you learn the controls then you can adjust the sound. if you have adjusted the balance to equal, then you may have a broken by door swing ground or positive, sometimes the ohms are split by a common positive connection (front and rear) contained with in the circuit of left or right. This crappy circuit could kill 3 of your 4 speakers, but then with the addition of an after market sub, who knows what kind of monkey business has been committed. Start from scratch in stead of chasing down electrical gremlins. Run new wires to all the speakers, dump the sub. Rebuild what should be there in the first place. Verify manufacturers connections and your interpretation of said, in the harness. Verify that the radio or amp can handle a sub without some goofy mono marriage of rear channels to obtain required ohms for crappy walmart sub Bazooka.
On second thought go to best buy, apply for credit card, and tell them that you want to bump down the road.
Jul 31, 2010 | Car Audio & Video
Need wireing diagram for instalation
Hello bulldogwjm,
You can download the Kenwood manual here:
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Just select the model number from the dropdown and download it.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
Ruud furnace won't stay lit.
Hi, welcome to Fixya. If you have spark ignition turn off the power and using sand cloth clean the rod(s) and hood of the spark ignition. If it is a Hot Surface Igniter (glow coil) look on the opposite end of the burners and you will see a rod protruding in to the flame. It's called a flame sensor. Clean it with the sanding cloth. If either of these works then you bought some time but should consider replacing the part fairly soon. Please report back to let us know your progress. Good luck.
Jan 25, 2009 | Ruud Central System Air Conditioner
I have a intel 478 board an don`t know how to connect power poer led
The power led wires ( there are two) go onto the two pins on the top row of the front panel coonetcor block on the board, on the 1st and 2nd pins working from left to right.
The full connector block is wired as follows:
top row: left to right >>
1st& 2nd are Power LED, the 3rd & 4th are the power switch, the 5th is empty.
The bottom row: left to right >>
1st & 2nd are hdd light, the 3rd & 4th are the reset switch, the 5th pin has no connector to the pin
Note: the power led and hdd terminals are to produce a light when the pc is on and busy.If the lights do not show, turn off the pc, turn the connectors round 180deg, reconnect and turn back on again. Job done
compdoctor2005@btinternet.com
Dec 10, 2008 | Computers & Internet
My A8N-SLI Premium
Hi big_cool, do you still have you're manual for the A8N-SLI board? Go to page 2-29. The ground is clearly marked in the manual. Wire colors are different from case to case. Black & white are commonly known as ground. Every case connector will have one wire color in common. The common wire will be positive +. The speaker connector uses to wires in a four pin connector. Red is positive & black is ground.
This pic (below), has been blown up to help you see. EX: The hard drive LED + sits on far left edge. Bottom row. The ground is the next pin to its right. Up on the top row. Left edge pin is the positive pin for the PLED = Power LED. Skip one pin to the right & the next pin, (Third from the left) is the ground for PLED.
1d367be.jpg This should help you get the rest of you're case LEDs connected.
Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Motherboard
Power switch went bad. need to know which pins attach to which wires
Looking at the front of PC remove the left side panel. Now looking in at the board. There are two rows of pins in the lowest right hand corner of the board. Your PWRSW is your power switch. Its a two pin connector. The ground wire will be black or white. The ground faces to the right & connects at pin 4 counting from right to left. Power switch takes up pin 4&5.
All done. If tech switched the wires by mistake than flip the connector 180*.
Jan 01, 2008 | VIA ASUS A7V8X-MX KM400 Chipset Ultra...
Mother Board connection
Go to the site below. Its a manual for the 800/i65GV group. Go to page 67 and zoom in. You'll get a nice look where everything goes. Two rows of pins. Upper row and bottom row. Real close to each other. Do not place connectors up to down. Connect only left to right.
The reset connector has two pins. One will be white or black. These are - grounds. So connect it to the bottom row onto the most right two pins. Moving to your left. Skip one pin. Take the Power Switch a two pin connector. Remember Black & White is ground & ground goes to your right for both rows of Mb pins.
http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4p800/e1324_p4p800.pdf
Go to IDE_LED next. Its the last two pins towards your most left of the bottom row of pins. Move to the upper row & the power LED. Same as the bottom row keping the grounds to your right. Lastly is the speaker. Its connector holds four pins but you only use two. One in each end.
Good luck & please vote....
Dec 22, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Durabrand Db1200 installation
As per our chat session I said I would be back while I search out your product...so here is your information; http://dbproducts.net/i/product/manual/DB1200_OM.pdf
Aug 24, 2007 | Durabrand DB1200 CD Player
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
32 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
