Question about Jenn-Air W30400P Stainless Steel Electric Single Oven
Display light the display light is very dim and hard to see when the room lights are on otherwise it work great, How can I fix the problem
  • kander6192 Sep 05, 2008
    I have the same problem, along with others, and Jenn-Aire will not fix it. You will have to purchase a $230 part and have someone install it. So much for paying more for a brand name that used to be trusted.....
  • bjhmail Jan 06, 2009
    I have the dim display problem as well. has anyone successfully installed the part?
Found out that I could replace the C3 capacitor with a 100uF 35V (high temperature - 105 C). Spent $1.69 for the capacitor and 1/2 hour taking the unit out, soldering the new capacitor in, and remounting the upper clock unit back on the oven. Works like a charm. No need to buy the whole Clock/Temp unit, waste of money.
Posted on Jan 07, 2009
  • strike3again Jan 09, 2009
    More info on oven display, might be helpful. Try URL below:
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
How do I fix the oven heat indicator light on kenmore c970 665621
If you are talking about an electronic digital display type control that is dim, most likely the only way to fix it is to replace it. Most electronic control units are not repairable in that sense.
Apr 09, 2015 | Ovens
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
Lighting panel in my electric Thermadore double oven is dim.
The cap replacement worked....saving $250 (every 2 years !!!) I posted it on another its making its way around the web....its the only value added thing I've done on the web (sadly!).
Nov 14, 2008 | Thermador SC302T Electric Double Oven
Front panel with the clock settings is dim.
The only way to brighten is to replace the ERC or computer
May 04, 2008 | GE JKP45 Electric Double Oven
Control Panel
The main control board probably needs to be replaced with an upgrade and the clock display will need to be replaced as well. Depending upon where you are and the cost of service your probably looking at about $700 for parts and labor.
Nov 10, 2007 | Thermador C302U Electric Double Oven
Display Panel Light
There is a replacement display assembly, i think its around $150-$200. Its pretty easy to change if you are at all mechanically inclined. Good Luck!
Oct 29, 2006 | Jenn-Air W30400P Stainless Steel Electric...
Jenn-Air W30400P Stainless Steel Electric Single Oven Logo
390 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
