Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Wont spin or drain.
I have the whirlpool ultimate care 11 LSQ9564J Top Load Washer. Every thing works fine in all the different stages except the rinse or spin cycle. It just stops and wont do anything. Any help would be great. Also how do I get the water out or is there a way to jump wires or bypass to get it to work. Thanks
  • 5,911 Answers
Check your lid switch. It may be loose or not making good contact. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading as item number 11 (part number 3949247). For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
You can by-pass the lid switch to drain the water by performing the following:
1. Unplug the washer and remove the console and case.
2. Unplug the lid switch connector from the timer and remove the entire lid switch assembly from under the washer case.
3. With the old lid switch assembly in hand, cut the square white connector plug off the end leaving about 2 to 3 inches of wire.
4. Clip the middle wire (green, or green and yellow) flush leaving the two black wires. Strip the wire ends and twist together using a wire nut or wire crimp. You have now made yourself a by-pass plug.
5. Plug the by-pass into the lid switch receptacle on the timer and place washer case back in place.
6. Plug unit back in and move the selector know to the final spin cylce. Pull the start knob and the washer should begin to drain.
It is strongly recommended that you DO NOT run the washer for exended periods of time with the lid switch by-passed as this is a designed safety feature of the washer. And, for your own safety, do not run the washer with the exterior case removed.
This is a simple and inexpensive repair. I hope this helps you. Let me know if you require further assistance.
Posted on Aug 13, 2008
Whirlpool ultimate care heavy duty leaks underneath, not agitate or spin. only humms and fills up
Again!! Any washer that does not drain has a bad Drain Pump. Very Common. I see this in 40-50% of the problems. Replace the drain pump and your washer will be very happy
Jan 19, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
The Ultimate II washes clothes fine, and the water does drain, but the clothes are still wet after the spin cycle
see this causes and fix it. God bless you
Washer does not drain Again, depending on the brand, different parts should be checked. 1st check the lid switch. If you hear the machine trying to work but no water seems to be draining, you might have something stuck in your drain pump. You need to check the drain pump. Whirlpool & Kenmore direct drive systems use a mechanical pump attached to the front of the motor. Most other newer models use an electric drain pump except for some of the older Frigidaires, Maytags, Amanas, & Admirals, they have a belt driven pump. Check for clogs & belt conditions on these models.
Oct 11, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
WHIRLPOOL LSQ8520JQ0 WONT DRIAN OR SPIN, HOW DO YOU REMOVE THE TOP CONSOLE, WHERE THE DIALS ARE
This video will show you how to open the control panel(and remove cabinet) what i would check if it agitates yet wont spin or drain is the lid switch
Gene
Aug 07, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer ultimate care II will not spin motor is working
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer problems
Remove your drain pump and check for lint and debris.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont drain or spin
Check your lid switch it's probably broken.
Jul 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine wont spin
Try and help it to spin in the spin mode.. if it moves.. sounds like a clutch problem ..IF NOT... you may have something like nail, screw ect... binding the spin tub from moving.. get a flash lite do some close checking inside the spin tub
Aug 28, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
176 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
