Question about RCA R52WM24 52" HDTV Projection Television
R52WM24 HELLO, I NEED KNOW WHERE CAN I GET A CONVERGENT POWER SUPPLY FOR THE MODEL R52WM24 YX51
  • 1Islandbmet Nov 17, 2008
    When the unit is powering up, there are three lines (blue, red & green) at the top of the screen that resemble a weak AC wave.
    After the power up sequence is completed & the TV channel comes on, the images on the screen has a 3D like image with a multi colored fade.
    Is the convergence power supply suspect as well?
  • mr_z_222 Jan 18, 2009
    i have the same problem. will replacing the convergence board solve the problem? i can't solder for nothing.
  • RCA Master
  • 8,617 Answers
I will need you to look on the rear tag and let me know the chassis number as that model was produced with two different chassis numbers ITC222 and the ATC221 chassis was used, But the chassis number will be on the tag on the rear panel. Please reply to this same post and I will help you locate the power supply board.
Posted on Aug 13, 2008
Rca r52wm24 the tv has double vision and shadows , then goes black screen. I unplug it for 10 - 20 min . screen still distorted
HELLO AM RICO, I WORK ON TVS SOMETIMES. ON THIS MODEL OF TV ITS COMMON FOR COLD SOLDER AROUND THE FLYBACK, CHECK THE FLYBACK, IF THERE IS COLD SOLDER AROUND THE FLYBACK. YOU NEED TO RESOLDER THE FLYBACK AND REPLACE A 5 AMP PICO FUSE. IF YOU NEED MORE HELP PLEASE FEEL FREE TO CALL ME AT 602-810-7149 I LIVE IN MESA AZ
Dec 31, 2010 | RCA R52WM24 52" HDTV Projection Television
I got a 55" RCA tv that will not stop Judder.
Dried capacitors and poor grounds are common to this TV. You will need to rework the power supply. Be extremely careful. Thanks for asking and show a few hands of support!
Sep 26, 2010 | RCA R52WM24 52" HDTV Projection Television
I NEED TO KNOW WHICH KIND/ITEM# OF PROJECTOR LAMP FOR A RCA R52WM24
look for the model number on back of your tv then go on google and type brand and model and part you are looking for e.x Lamp
Feb 08, 2010 | RCA R52WM24 52" HDTV Projection Television
RCA Convergence problem TV model #R52WM24..parts?
Thats an easy repair. The flyback develops solder carcks which cause the FL231 fuse to blow and weakens DL231 so the set will lose the convergence options under the on screen menu. You can get the ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com which contains the components and the CD with repair instructions. Its very inexspensive and includes shipping.
Jan 03, 2010 | RCA HD52W59 HDTV Projection Television
Replaced the fuse in RCA R52wm24 and resoldered the flypack now the tv power light turns on blinks three times then turns back off. We had no issues with the tv before today. Any help is greatly...
The fuse blows when there is aproblem with the convergence board - if the TV just had issues with the convergence b4 you soldered and replaced the fuse then the set should not be dead - I would check all plugs especially the 2 flexible (short) cables that jump the (ssb) two boards together. Do you hear the HV trying to start (a little chirp sound near the flyback) If so the set is in shutdown mode if not then power supply problems are usually the cause - check for swelled capacitors in power supply.
Oct 06, 2009 | RCA R52WM24 52" HDTV Projection Television
Will not power on power flashes three times before shouting down modle d52w14yx1
Hello mz_scorpio75,
This is a power supply problem. If you wre to take the back off of the unit, and look at the deflection board or the main power supply board you may see that some capacitors appear to the bloated, these will have to be changed out. I would suggest having a qualified TV technician perform this repair. I say this due to the dangerous voltages that may be present.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 04, 2009 | RCA R52WM24 52" HDTV Projection Television
About rca model r52wm24
Yes I know where you can get the signal board for your model. Go to the following link and leave them a email with your model and chassis number and let them know you need a signal board. They will respond back quickly. they have about any bopard you need for RCA they dont list them all, but inquire, and I am almost positive that they have one.Heres the link.
http://servicemanuals.vstore.ca/
Jul 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Tv model r52wm24
You most likely need a new convergence power supply board if fl231 keeps blowing thats the most likely cause, also check for shorthed capacitor cp231. If you need a link to get a replacement convergence power supply board, let me know I know where you can get them.
Jul 19, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA CONVERGENT PROBLOM
The convergence problem is likely to be in the convergence power supply which is located above and between the two boards which lie flat inside the chassis. The power supply has a chip on it which is a common problem (If it is not the transistor type then change the whole board.) part number on the chip where the metal heat sink is located. Part number may be STK 730-010 or STK 730-130 both number will work and must be unsoldered and new soldered in.
Jan 02, 2008 | RCA P52937 52" Rear Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
134 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
