Question about HP Computers & Internet
Hp deskjet f2200 all-in-one series printer has done test sheet ok scans ok loaded software, connected usb when prompted,will not print from computer. have tried restarting pc, switching off printer. hp solution centre states that the printer is on line and ready
    Problem Solver:
  • 12 Answers
Let the windows promp you, then when it asks for the cd say "i have one" or something around that line. exit out of the auto run set up and go with the windows set up, then once installed you're ready to print.
Posted on Apr 26, 2009
    President:
  • 2,961 Answers
Go to your installed printers in control panel and check that the F2200 has the tick on the icon which indicates it is the default printer
Posted on Aug 13, 2008
There's a document in the Hp deskjet f2200 series that i canceled cause the printer didnt print it (of course i clicked the print button) , im canceling it and then the status changed to...
disconnect the usb cable from the printer to computer then turn off the printer, restart the computer then check the pending again if it is empty connect back the printer
Aug 07, 2011 | Office Equipment & Supplies
HP Deskjet 3500 series, my printer keeps telling me that is is off when the light is green, keeps stating it is offline. When I installed the printer everything was fine, now when i print the printer...
Hi
HP Deskjet 3500 serie --
There could be a Software issue or hardware issue --
1) To check the software issue
Print a Test Page -- from the computer
2) To check the hardware
Press the Power button to turn the product on.
Press and hold the Power button
Open and close the front cover four times.
Release the Power button. The self-test will print
and it it is printing the hardware is fine ...
3) Then you can check by changing the USB Cable connection
Jan 01, 2010 | HP DeskJet 3520 InkJet Printer
INSTALLARE CDA HP DESKJET F2200,L'ICONA SOLUTION CENTER
my hp f2200 deskjet printer solution center have not installed but are all are thing installed properly. my problem that i could not scan anything
Aug 12, 2009 | HP DeskJet F380 All-In-One Printer
HP Deskjet F2210 won't install on Vista
Go to control panel/programs and features and uninstall the HP driver and all associated software.
Reboot, then reinstall the LATEST version written SPECIFICALLY for VISTA SP2. Install the driver BEFORE you connect the printer. After you install the driver if your computer still doesn't recognize the printer, leave it connected and reboot.
You should see the 'found new hardware' wizard open and automatically install the printer.
Hope this works. Good luck.
Jun 11, 2009 | HP Deskjet F2210 InkJet Printer
Printer will not print
I recommend downloading the latest driver updates. You can get them here:
h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972
Also check your printer settings to make sure they are set on plain paper and full size. Under your writing program, make sure your settings are unicode.
Jun 02, 2009 | HP DESKJET 2200XI 14PPM 600DPI PRINTER p/n...
Help get software for new printer
Greetings,
Since F2200 is a series number it is hard to get a specific driver but if you look on the lable on the back or bottom of the printer you should be able to see what the actual printer model is.
Here is a link to all of the F2200 series downloads on the HP website. Once you know what the actual model number is for your printer all you will have to do is click on the apropriate option and download the driver for your OS.
If you need any additional assistance please let me know.
Here is the link:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=Deskjet+F2200+&submit.x=10&submit.y=9
Dec 30, 2008 | HP Office Equipment & Supplies
Have loaded hp all in one for first time and after many attempts the device set up has failed to complete screen displays.have followed instructions over and over and is installed but no program or views...
To begin with you need to turn the printer on by the electric outlet, but not the usb lead to the computer, when you turn the printer on for the first time it will print an alignment page, put this face down on the scanner bed, and then load the software, the software will tell you when to connect the usb lead. Do not connect the USB lead until instructed to do so. You will then be guided on what to do next on the screen and which parts of the software you want to run. I suggest doing a complete install as this will come with HP solutions enabling you to get help if you run into problems. If you have the software loaded on the computer but it failed to connect the printer then maybe windows tried to pick it up. Do not connect the usb lead and windows will not pick it up. Uninstall the software and try again as instructed above. When the software starts to load and it instructs you to connect the usb lead, windows may tell you that it has found new hardware, ignore the pop up as the drivers will be loaded from the cd.
I hope this helps
Nov 30, 2008 | HP Computers & Internet
Printer disc is f2200 but printer is deskjet f2280
Don't Worry you have the right disc.
The printer you have is of Deskjet F2200 Series and F2280 Is on of them.
Although the printers are segrigated but the Printer driver and software are the same for the F2200 Series.
So you can install the same.
Good Luck
Oct 04, 2008 | HP Office Equipment & Supplies
Mac not printing to HP Deskjet F2200 series
1) First let's make sure the hardware is working. Place a document face down on the scanner glass. Press Start Copy Black. Did it scan and print?
If not, please let us know.
If it did, go to the next step.
2) Please confirm the USB cable is plugged firmly into the back of the printer and to the computer. Do not go through a hub, switch, or router.
3) Click on your Apple icon (upper left corner), System Preferences, Print and fax.
Do you have the F2210 printer listed more than once?
I am going to suggest removing the F series printer. Highlight it and press the minus button to delete. Once you have removed it, close all windows back to the desktop.
On the computer click on Hard Drive > Applications > Hewlett-Packard > Device Utilities > HP Setup Assistant. Follow the on screen directions to add the printer back to computer. Do not re-register the printer (choose skip or register later). Once your are able to click finish, try printing again.
I would suggest trying to print from Text Edit first. This will rule out any possible issues with the Word document you were trying to print. Click on Hard Drive > Applications > Text Edit. Type your name in the untitled screen. Click on File > Print. Make sure the F2200 series printer is selected. Click Print. Did it print?
Sep 24, 2008 | HP DeskJet F380 All-In-One Printer
Communitcate/test sheet
You didn't mention installing the 920c on your computer. You should have received an HP Deskjet 920c series printer software CD which installs the printer on your computer. You may need to check the HP web site to see if your computer is equipped with the appropriate driver. The 920c is an older HP printer. One of my printers is a 920c and I had no problem installing it a computer with Windows XP.
Sep 08, 2008 | HP DeskJet 920c InkJet Printer
Computers & Internet Logo
187 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
