One more time?
What I want is my printer to work the way it did before I had to change my operating system. It is a HP Photosmart 321-xi All-in-One printer, scanner, copier My new computer is an HP so the printer is working. But the disk that came with the printer does not work with Vista. I went to HP's website and asked how to obtain an upgrade, clicked on the link and was left with a google search...so I thought I would give you guys a try....but so far it is not working either.
    Guru:
  • 1,894 Answers
Sir is this model HP Photosmart 3210xi All-in-One?
or
HP Photosmart 321 -xi All-in-One??
because HP has either A321 else 3210xi
and if it is
HP Photosmart 3210xi All-in-One then click here for the driver link
select your proper vista and then install it in your system...
Posted on Aug 15, 2008
HP Photosmart 2570 All-in-One Printer
Have you tried going to hp.com, put in photosmart 2570, which comes up as 2575. Try that driver. Most of the time, there is not a great difference in the drivers. Use the basic driver. If your printer has a v or xi next to the 2570, the use that basic driver. Make sure you select the operating system on your computer. Go to "My computer, right click, select properties, the operating system will be there on the general tab.
Jan 30, 2011 | HEWLETT-PACKARD HP Photosmart Printer...
I have HP photosmart 321 all in one and I have
here.. check this out. a solution to your problem.
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
Jul 05, 2010 | HP Photosmart 3210 Printer
My HP 2410 Photosmart printer is making a clicking nose on start up. In the past I was instructed to unplug it and everything attached to it, including the computer, for 15-30 minutes and it would reset...
Uninstall the printer completely starting from the software.
Go to Start Menu, Control Panel, Add/Remove Programs, select the HP Photosmart software and remove it.
Then, go to Start Menu, Control Panel, Device Manager (usually under Administrative Tools/Computer Management).
Select under "Printers", the HP Photosmart 2410 All-in-One InkJet Printer and remove it.
Restart your computer and follow the instructions from your HP manual to setup your printer again.
Apr 06, 2010 | HP Photosmart 2410 All-In-One InkJet...
Some software cannot work and hp product assistant has stop.
Check with HP customer care for updated drivers for your Photosmart c6100 running VISTA. They may suggust changing operating system to VISTA 32 bit.
Sep 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
Can an HP Photosmart C4480 printer work on Windows
This unit requires windows XP as the minimum operating system that it will work, so the unit wont work with Win 98 here is a link for the complete details of this unit
http://h10010.www1.hp.com/wwpc/uk/en/ho/WF06b/18972-18972-238444-410635-410635-3655558-3655585.html
Aug 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
2610 xi HP printer will not print, copy or print a FAX
Lift up the part under the glass and you'll find the print cartridges. Just lift up and pull out.
Jan 26, 2009 | HP Photosmart 2610xi All-In-One InkJet...
Driver for HP 2210 xi All in one
You can download here from HP. Just pick your operating system.
Jan 19, 2008 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 1315 xi all in one
Here is the link for the driver for your printer. Download the correct driver for your operating system and install.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=306892&lc=en&cc=us&dlc=en&lang=en&cc=us
Jan 19, 2008 | Office Equipment & Supplies
74 people viewed this question
k24674
jasbo
jasbo
