I have a Technosonic MT-PH02 turntable and I have smashed the cover on it. Do you know if there is anywhere where I can get a replacement cover online?
Fisher mt 6250 I need a replacement stylus. What will fit my turntable?
Hi, your Fisher MT6250 takes a Pickering XV-15 stylus. We have them in stock. cheers john. Stylus City
Jan 25, 2014 | Audio Players & Recorders
Hi. I have a technosonic kha712 model and my needle skips over the first 10-15 seconds of the first song on every record. Is this fixable?
You could try increasing the weight at the end of the turntable arm. It will be a question of trial and error. Trying a record to see if it stops, but putting to much weight will make the sound rumble.
First however check to see if there's something on the arm somewhere that makes the record jump. Could be anything: muck, a pin, or a wire.
Aug 07, 2013 | Audio Players & Recorders
PX-E860 Turntable: I need to replace the cartridge of my aiwa turntab...
my aiwa PX -E800 TURNATBLE has stopped working ,, is there anywhere i can get a replacement turntable .
May 17, 2010 | Aiwa PX-E860 Turntable
I need to replace my remote for the Technosonic SA 201 DVB freeview but I need the code to set up the new universal remote. Any thoughts. many thanks Duncan
You SHOULD get the codes with a new Universal Remote.
Have just gone through my lists but they do NOT show a Technosonic anywhere in them.
Feb 02, 2010 | Televison & Video
Estimate of 21v AC turntable motor, also the plastic spindle?
If the model number you posted this question under is correct, a replacement turntable motor costs anywhere from $25 to $35 on average. The turntable coupler (also called the turntable shaft) can cost anywhere from $5 to $15. This all depends on the exact model number.
Replacement parts can be purchased on line at any of the following websites:
Prices vary between sites, so shop and compare. The first three sites on the list also have helpful exploded view parts illustrations to assist you with parts identification/location.
If you need instructions on how to replace a turntable motor, the following link explains:
If you have any questions, please post back and let me know. I hope this helps you.
Jan 28, 2010 | GE JVM1630 Microwave Oven
Need replace bsaket in PegPerego Duatte MT or call 1-800-671-1701 order it from the manufacturer direct.
Good Luck! from Moms Just Know
Sep 14, 2008 | Peg Perego Duette MT Newport Twin Stroller
Fisher turntable mt 6410 removal
Look at spindle bearing in center of t-table. There is probably a small ring lock there holding the table. Use a pick or small screw driver to carefully remove this ring.
May 07, 2008 | Audio Players & Recorders
How do I replace the belt on a mt-6410 turntable
Just lift the platter off the turntable, and you'll see where the belt goes. You'll see a metal spindle/motor - this is where the belt wraps around. Then you will have to wrap around your turntable platter. This is a little tricky, but you should be able to figure it out.
Apr 22, 2008 | Technics SL-1200MK2 Turntable
240 people viewed this question
