Question about Canon PIXMA MP600 all-In-One InkJet Printer
Help i cant print
My printer kepp saying error code 5100
  • 4,041 Answers
Hi You can Try 2 things. So good Luck
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Gives me a code 5100
Canon i550 Service Error 5100 ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/25975
Oct 6, 2006 - I recently dropped my printer out of my car by accident, and now everytime I try to print something, it gives me a Service Error 5100.
Canon Pixma MX420 Printer 5100 Error and Loading Ink ...
? 5:57
https://www.youtube.com/watch?v=tmTJdJTAhYU
Mar 13, 2012 - Uploaded by Dustie Meads
please help me,i have problem in my printer,wifi on printer can't search .... I too was given the generic "5100" error message just tonight.
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
I can't print my documents. My Printers model is Canon IP2700 and it says there that the error code is 5100. How can I fix the problem? we need the print immediately. Is there any solution we can fix it?
Usually, error code 5100 means some kind of obstruction in the print path, maybe something that had fallen inside the printer, the gears being jammed by something that got loose inside the printer, or ink on the clear plastic encoder/timing strip (a plastic strip about 1/4" in width that you can see running from side to side and connects to the print head).
Clean the plastic strip with alcohol , check if there is nothing blocking the head carriage set (sometimes kids play and hide toys, pens, coins, inside printers, VCRs or any other devices that have "doors"...).
Hope this info may help you!
Mar 12, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Error code 5100
5100 means either there is paper stopping the carriage from moving properly, or there is grease on the plastic strip behind the carriage. If you wipe off the grease with a Q-tip the error will go away.
Jun 24, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Everytime I try to print Error 5100
Hi, Error E22 5100 is a carriage error. Check that nothing is stopping the cartridges from sliding back or fore acroos the silver bar inside the front of the printer.
Nov 05, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Help i cant print
Error code 5100 refers to blockage along the print path. While this could be a number of things, simple remedies may include lubricating the slider rod where the print head moves along. This could be as simple as a drop of oil, cleaning and checking no paper bits or accumulated dust/ dirt or grime. Another area to check is the waste in pad. This would be the white receptacle below the print heads when in park position. On certain instances, the sponge may be dislocated and would simply require moving back in place. At other times, there could be obstruction blocking the print heads resting in the correct park position. This again could be dirt,grime, bits of paper, paperclips, staplers, or even gummed up or dried ink.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 13, 2008 | Canon PIXMA MP600 all-In-One InkJet...
I get ERROR 5100 message for my i350 printer...of course it will not print. How is this fixed? Please help.
I had the error code 5100 for my canon pixma ip6220d printer and all it was a pen in the track of the cartridges. I've been looking for that pen for awhile too. So I would say look for something in the way of the cartridges. Hope this helps everyone.
Aug 03, 2008 | Office Equipment & Supplies
Error code 5100
Error code 5100 /this error is an error within the printer. This error means that there is
something obstructing the printing process. Check inside your printer through the gears that
you can see under the lid. There should be something obstructing the gears such as dirt or
in my case popcorn. Check VERY thoroughly.
Mar 23, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
80 people viewed this question
old marine
old marine
