Question about Kitchen Appliances - Others
Hoshizaki KM-600MAH-E won't start
I can't get the ice machine to start. No water flowing to the tank. I cleaned the unit including the float valve and checked continuity of float switch which works. No beeps from unit. No noise at all. The red LED power lamp is lit on control board. Any other areas to check? I think it may be the inlet water valve but how do I check it?
  • Anonymous Aug 13, 2008
    i want driver for apollo pro via chipset vt82c596 for windows 98se
  • 38 Answers
I don't have a wiring diagram for this machine so I can't be specific, but I may be able to offer a few suggestions. Check for voltage on the coil by slipping the two wires back off their coil connections you should be able to expose enough of the connection to measure voltage. If voltage exists when machine should be filling, you either have a bad coil, or water is not reaching this point. Check coil resistance by removing wires and testing coil. Resistance reading of 0 or O/L (out of range) would be grounds for replacing the coil.
If coil tests good, look for plugged water filters on water line leading to machine.
Hope this helps,
Kermit
Posted on Aug 19, 2008
My hoshizaki ice machine KM-900mrf model beeps 3 times and stop making ice. After reset it starts, but stats beeping again after an hour.
Have a look at the side of the evaporator; there is a probe (thermistor) attached to it that tells the control board when to initiate the harvest cycle. make sure it's clean and attached properly and doesn't need replacing. If hitting the float switch initiates the harvest cycle it sounds like you have a blocked/ scaled water tube or switch housing. take off the bottom of the switch assembly (black rubber bit) and clean through to the water chamber. run a cycle of descaler before trying again.
Jul 04, 2015 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km-900mah ice maker won't start the freeze process
cycle is, fill cycle for 1 minute first. If there is not water entering the unit when first turned on, look for that issue. Water turned off, water valve not working or some restriction, clogged water filters, etc. That is got to happen first. Don't over look the bin stat being bad. Nothing happens if teh bin stat is bad. It sends voltage to the control board that runs the unit.
Jul 28, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Model KM 630 MAE
Look for a stuck float switch. unit fills with water for 1 minute, then the board "looks" at the float to "see" if there is enough water in the unit to run. If float switch is stuck down, it tells the unit there is not enough water and the unit stays in the fill cycle causing the sump to overflow and send water down the drain constantly. Compressor will not run till the board senses that there is enough water to run.
Jun 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km-900mah not going into harvest when float switch opens. New circuit board installed still no harvest. I can set an egg timer and manually operate machine but I can't leave it unattended...
Hoshizaki machines must have a very clean evaporater other wise the ice will bind causing a slow harvest. This may be from lime scale build up. "Lime A Way" is recommended for this proper cleaning. After that is done check to see that the water inlet valve screen is clean and that you have a filter installed.
Last check the thermister attached to the suction line.
http://www.hoshizakiamerica.com/techtips/Pdf/All/tips105.pdf
Aug 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
KM-500-MAE Hoshizaki Problem huge cubes, alarm code three beeps
Might need to clean float switch, or water inlet valve bypassing water. Deep clean Hoshizaki.
Sep 30, 2010 | Hoshizaki Commercial Freezer KM-500MAH
I have a Hoshizaki Model KM500MAE that keeps freezing up. What can I do to stop this problem
several things cause freeze ups.
If you have water filters on the water system, be sure they are not restricting the water flow. water flow pressure should not go below 20 psi.
The bin stat may not be shutting off the unit properly. It should shut off machine within 10 seconds of ice making contact.
Make sure the float switch is not dirty. Be careful when cleaning. Fragile
Make sure water pump runs the entire time it is in the freeze cycle.
Be sure the evaps are clean. Ice cubes will hang on if not clean.
Water solenoid has a screen where the water line screws on to it. Turn off water and check screen to be sure it is clean. This can restrict water flow.
Make sure water valve closes all the way. Turn machine off and see if water is still running. Valve may be leaking water thru.
Dip switches on the board, #1 and #2. Turn them both on and it will change the defrost time to 3 minutes. If both are off, they are set on 1 minute.
Hope this solves your problem. Let me know
Apr 07, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KM-600mah beeping
PCB requires to be reset. White button power needs to be on or it wont reset.
Feb 19, 2010 | Hoshizaki KML-600M Low-Profile Crescent...
Harvest cycle on ice machines
My ice machine Hoshizaki km-500 mah is cycling to fast. Causing poor production of ice it's real small and it doesn't produce enough ice aswell. Wha seems to be the problem.
Jun 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Ice Machine Model KM-500MAF
(Quated From Hoshizaki Technical Bulletin)
An alarm code of 3 beeps
every 3 seconds means that the control board has shut
down on the 60 minute freeze cycle back up timer.
The “E” control board has a 60 minute timer that starts at
the beginning of the freeze cycle. If the float switch fails
to open and start the next harvest within 60 minutes, the
board will automatically start the harvest cycle. If this
occurs in two consecutive cycles, the control board will
shut the unit down on the manual reset, freeze cycle
back- up timer. The yellow fault LED marked “60 min.”
will illuminate. This safety is designed to help prevent a
freeze up of the evaporator.
Once you have identified the 60 minute alarm, there are
several things to check. Reset the alarm by depressing
the white reset button to the right of the fault LED’s.
This must be done with the power “ON”. Now check the
float switch to see if it is stuck in the up position. A stuck
float can occur if scale is present on the reed switch
shaft inside the housing. To check it, drain the water
reservoir, unplug the black float switch connector (K5)
from the control board and check it with an ohm meter
for a closed switch (zero ohms). If the float switch is
sticking, clean it with ice machine cleaner or replace it as
necessary.
An inlet water valve which is slowly leaking by during the
freeze cycle can cause a 60 minute alarm. If the inlet
water valve is stuck wide open, it is unlikely that any ice
will form on the evaporator. Check for a slow leak by
allowing the unit to cycle into the freeze cycle and
disconnecting the hose at the outlet of the water valve. If
water leaks by during the freeze cycle, the water valve
diaphragm is likely damaged or the small diaphragm bleed
port is clogged with scale. Clean the bleed port or replace
the diaphragm or entire water valve as necessary.
(I Recommend to get a refrigeration tech for this part).
Another possibility is a refrigeration system problem. You
should use normal refrigeration diagnosis procedures to
check for one of these problems. If the thermostatic
expansion valve is not feeding properly or the refrigerant
charge is low, the evaporator will not form ice as it should
and a long freeze cycle will occur. This could also be the
result of the hot gas valve not closing completely during
the freeze cycle or if the compressor valves are weak or
inefficient. An inefficient compressor however, will
usually show up first on the KM model through a longer
than normal harvest cycle. This is because of cooler
than normal discharge gas. Use proper refrigeration
practices to repair a refrigeration system problem.
While these are not the only reasons for a 60 minute
freeze cycle, they are the most common and should be
checked to resolve a 3 beep/yellow fault LED alarm.
Feb 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Kitchen Appliances - Others Logo
300 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
