Question about Pinnacle Dazzle DVD Recorder
Recording stops within 10 minutes
I have Dazzle setup on my Vista laptop. Recording starts and about 10 minutes or so into it the recording stops and the message disk finished appears. What do I need to do? The last menu screen tells me that I can record up to 133 minutes. Thanks...
  • 50 Answers
Hi G-DyBiec
If the video capture automatically stops capturing at approximately 18 minutes (17 minutes and 55 seconds), then most likely the drive that is being capture to, is formated using Microsoft's FAT32 file system. Microsoft's FAT32 file system has a maxium file size of 4 GigaBytes (4 GB), which equates to a DV video clip of nearly 18 minutes. (18 minutes = 1080 seconds, @ a data rate of 3.6 MB/sec is approximately 4GB). So for hard drives that are formatted using FAT32, this behavior is normal. This is not a limitation of Studio..
To see what file system your hard drive uses do the following:
1. Right click on the Start button and choose Explore
2. Under My Computer, locate and highlight the drive you are capturing to
3. Right click and select Properites
4. On the General tab, towards the top, it will say "File System". It will be listed as either FAT32 or NTFS.
There are a few solutions if your drives are formatted using FAT32:
  1. Convert your FAT32 hard drive to NTFS *
  2. If you can copy any important data from this drive to other drives, it may be faster to re-format the FAT32 drive using the NTFS file system. **
  3. You can do multiple 18 minute captures and string them together in the Edit mode of Studio.
    • Since the first 18 minutes is already captured, rewind the camcorder or VCR to 5 - 10 seconds before the initial capture stopped (which can be edited out later in Studio).
    • Start a new capture to a new file name.
    • Repeat this process until all the desired video is captured from the tape.
    • After all the files have been captured, go to Edit and assemble the captured files from the Album to the timeline in the order you desire.
This is a manual method to workaround Microsoft's FAT32 file system and if this is too time intensive for your needs, then steps 1 and 2 above may be more suitable and should be considered.
* Note: If you need assistance with step 1 above, go to the Microsoft web site at http://www.microsoft.com/ and search on "convert FAT32 to NTFS".
** Note: If you need assistance with step 2 above, go to the Microsoft web site at http://www.microsoft.com/ and search on "how to format a drive in XP".
NOTE: Microsoft's NTFS file system is only supported on Windows 2000, Windows XP and Windows Vista. NTFS support a file size of 4 TB (terra bytes), which is larger than any current consumer hard drive capacity, so if NTFS is used, the capture file size will only be limited by the size of the hard drive.
Posted on Aug 20, 2008
Burn error Instant Dvd Recorder windows 7 Dazzle dvc 100
Set the compatibility back to windows 7 and then uninstall the program and all of it's drivers, then reinstall it and see if it works then.
Jun 08, 2012 | Pinnacle Dazzle DVD Recorder
Instant dvd recorder software 'not responding'
Hello Joshua,
Instant DVD Recorder 2.6.1 UPDATER
  • Please install the Instant DVD Recorder 2.6.1 UPDATER if you are using the Dazzle DVD Video Recorder, Dazzle Video Creator or Dazzle Video Creator Platinum with a previous version of Instant DVD Recorder. This updater also includes the hardware drivers.
  • If you are using a Dazzle product already that includes Instant DVD Recorder version 2.6.1, then you do not need to install this update.
New with this version:
  • added support for Windows Vista 64 bit and Windows 7 (32 & 64 bit)(
  • Includes Windows Vista and Windows 7 drivers (for both 32 and 64 bit) for the DVC 100, 101, 103, 107 hardware NOTE: DVC130 and DVC170 don't have 64 bit drivers and can only be used with Windows XP and Windows Vista 32)
  • 16x9 detection
  • PCM Audio (already included with Instant DVD Recorder ver. 2.5)
Supported Hardware:
  • Dazzle Video Recorder ( DVC90) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC130) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator Platinum ( DVC170) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC100 and DVC101) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator ( DVC103) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator Platinum ( DVC107) Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • and other compatible hardware
Installation Instruction:
  • To be able to install this version, you must own an Instant DVD Recorder Version 2.x full version
  • To install this Instant DVD Recorder version not as an update but as a full version you need to enter your Instant DVD Recorder Version 2.x serial number during the installation process. The serial number was included in your Dazzle product.
  • With Windows Vista 64 bit or Windows 7 64 bit, you need to install Instant DVD recorder 2.6.1 as a full version.
  • If you own an Instant DVD Recorder Version 1.x full version, to only install Instant DVD Recorder 2.6.1 full version.
  • If you use this Instant DVD Recorder Updater to update the Instant DVD Recorder included with Studio Version 12, 11 or 10, please make sure that Instant DVD Recorder is already installed on you system. Please note that the version of Instant DVD Recorder included with Studio Version 12, 11 or 10 can't be installed under Windows Vista 64.
For Windows XP
http://apps.pinnaclesys.com/cdb/register/enter.aspx?checkRegistration=1&langue_id=7&supportFileID=35261&productid=2250
For Windows Vista 32 Bit
For Windows Vista 64 Bit
For Windows 7
Sep 15, 2011 | Pinnacle Dazzle DVD Recorder
My dish network dvr stops recording some programs, i think its just shows that are to be recorded on tv 1. It will record only like 10 minutes or less and stops recording
jeff_rhondac,
Check the timers you have setup for the programs that are suppose to record. Make sure the timers are setup correctly. Do you have any timers setup to begin early and end late? A new software update rolled about 2 weeks ago. Did you start experiencing the problem after that? Also, how much available time is available on the HD? Please let me know so I can further assist you.
Thanks,
Ray Calo
DISH Internet Response Team
Jun 24, 2011 | DISH Network ViP722 DTV Receiver /...
Why does my recorder prematurely stop recording, even after I ask for no chapters and a 60 minute recording time? It used to work just fine, but now it suddenly stopped working correctly. Please help.
Your computer could be running out of ram, or go into the properties and see if you might have hit something by accident. may i ask what you are recording with?
Dec 19, 2010 | Pinnacle Dazzle DVD Recorder
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
How do you get your min.in a Dazzle dvd recorder...............
Are you referring to put the time record or the total minutes for your recording? on step number one make sure that you choose your dazzle dvc device after that go ahead and go to step number 4 and put the total mins of your video.
Nov 15, 2009 | Pinnacle Dazzle DVD Recorder
Why does my dazzle record without colors?
Maybe you're recording in the wrong format (ntsc, pal-m, pal-n). Try selecting a different format from the one you're using now. (Click in "options"). You'll be able to preview it before starting the recording.
Aug 12, 2009 | Pinnacle Dazzle DVD Recorder
Losing Audio Halfway Through Recording
The audio failure sounds more like a VHS player failure than a DVD software/recorder failure. Both audio and video are transferred at the same time to the DVD, and as long as the DVD recorder is working, that's really all there is. I would check the VHS player and confirm that the sound actually works all the way through.
Mar 02, 2017 | Pinnacle Dazzle DVD Recorder
Cant capture sound with DVC 90 with vista
Make sure you check the recording source for audio and also the volume levels. Check the default audio input settings in Vista as well as the audio recording source in the recording program.
Jules
Dec 17, 2008 | Pinnacle Dazzle DVC 90 (210100371) Video...
Pinnacle Dazzle DVD Recorder Logo
459 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
