Question about Aiwa AM-F80 Personal MiniDisc Player
Aiwa AM-F80 displays "No Adjust!" when charger is plugged in
I have a Aiwa AM-F80 displays "No Adjust!" when charger is plugged in, and it will not function.
Have tried resetting the unit and a new battery but still show the same message.
Can anyone provide me with a solution.
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
How to recharge the rechargable battery in the Aiwa md afm70? Are the mini disks awailable?
Plug in the appropriate power supply or charge the batteries through an external battery charger.
There are discs all over eBay. Don't pay more than $2.25 each.
Apr 30, 2011 | Aiwa AM-F70 Personal MiniDisc Player
Just want to know what the code FLO stands for kid lost the manual
The digital display shows "FLO" to indicate that the unit is in float charge mode. The battery "fully charged" icon will display on the LCD screen and the arrows pointing to the "+" and "-" will flash. In this mode, the unit monitors the battery voltage and charges as necessary to assure the battery maintains full capacity. The unit remains in float charge mode as long as the charger is connected to the battery and plugged into a functioning AC outlet. I hope this has answered your question.
Apr 01, 2011 | Stanley Black & Decker Stanley Bc1509 15...
Does not work, we tired a new battery, but no help.
Instructions
    Technical Difficulties
  1. If the phone doesn't turn on, make sure battery is charged and fully plugged into phone. Remove battery from phone and use rag to brush away dirt that may interfere with connection. Reconnect and try again. If using cigarette-lighter adapter, make sure it's properly plugged in. Make sure charger is properly plugged into outlet and into battery.
  2. When the battery doesn't charge, plug lamp or other electrical device into outlet to verify that outlet works. Borrow friend's charger to see if charger or battery is problem. Replace charger or battery if necessary.
  3. In case the phone gets wet, remove the battery from the phone and allow both to dry thoroughly. If rust or corrosion develops, wipe it off with a stiff brush. If phone still does not work, replace it.
  4. Should the display not be working, try getting it to room temperature, extremely cold or warm conditions may affect display functions.
  5. If the keys don't work, look for a display of a symbol that looks like a lock. The keypad may be locked. The display often tells you how to unlock it. If not, check owner's manual.
Jan 24, 2011 | Lands Phones
Belt wont start on a brand new Sole F80. Motor
It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
Mar 12, 2010 | RTO Sole F80 Treadmill
Hard reset and charging problems
do the hard reset again .. hold the power button down while operating the reset in the back .. keep the power button down for a few seconds .. that should bring up a display "delete all" .. you can choose to do so .. that will be a hard reset .. now if the battery is dead and the charger is not working then nothing will work for you .. you might have a bad charger .. often the end that plugs into the unit develops a broken wire inside the cable ..
the m515 wont charge from the sync cable (shame) it needs the external power adapter .. make sure the connections on the charger and palm are clean .. the power adapter is 5 volts and i think about 1 amp .. )(center pos) if you want to try another adapter .. the tip is rather standard ... also you can get a universal power adapter from radio shack that will work on just about anything .. you just plug in a suitable tip .. the tip for your palm is an "A19" .. the power adapter is "IGO" wall adapter 23-1401 model PSM08VADJ ... that seems to work nicely and it plugs directly in to the palm .. so you can work with it plugged in .. when the charger is working there should be a lightning bolt thru the battery symbol .. it sounds like you already know that .. if the battery has gone open then it may not indicate a charge .. but the unit should still work while on the charger if that is actually working ....
Apr 13, 2009 | Palm m515 Handheld
Dead Garmin c550
had same exact problem. my unit would come on for a minute and then go black. if you take the silver ring around the face you will see the four screws to take the unit apart if you do have to replace the battery. however first try hitting the reset button on the right side of the unit. remember the cover needs to be off. i hit the reset and my unit powered on with no problems
Oct 31, 2008 | Garmin StreetPilot c550 GPS Receiver
Nuvi 200 GPS
We did not have a charger to plug in the GPS to charge, so my husband plugged it into a battery charger. I guess the battery charger was low, so it drained the unit rather than charging it. It was so low it would not come on again. I have an electric charger that adapts the car charger into AC current, so I tried that and the unit came on. Problem solved and the GPS is working again. Thanks for responding.
Jun 20, 2008 | Garmin nuvi 200W GPS
No sound from stereo
If you can hear a hiss then the spkrs and amp are OK. It sounds like you're not on whichever source you're wanting to hear or it is on mute. Make sure ther is no function enabled that turns the sound off or over-rides it (like a tape monitor or AUX in...).
Sep 09, 2007 | Aiwa NSX-DS55 CD Shelf System
Power on but no display
Hello Coach T, Reset Instructions: 1. If pressing the power button does not turn the unit off, unplug the unit, then plug it back in. 2. Press the power button while pressing the ENTER button. This will bring the unit back to factory defaults. Please let us know if you need any additional help. Best regards, nightdiver
Aug 21, 2006 | Aiwa AV-D57 Receiver
Aiwa AM-F80 Personal MiniDisc Player Logo
196 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
