Did you check the GFCI on the plug to make sure it doesnt need resetting and is the plug live?
If water comes out of the lance (even low pressure water) and the power supply is good, the problem will be the pressure switch in the main pump body. Unless you're an engineer best take it to a repairer. The pump has to be separated from the motor housing, the switch plunger cleaned and probably the pump oil renewed while you're there - might be good to renew the seals too. Good machine when it's working tho...
