Question about HP Pavilion dv1000 Notebook
HP Pavillion dv 1000 Does not boot up
Yesterday I was away and I plugged my pc in to be charged of which was left on the charger for a minimum of at least three hours. For some strange reason all of a sudden I can't seem to get it to boot up, the lights across the top of the key board comes on but thats it. In fact I spoke with someone in technical support from HP last night. It was suggested that I detach both the battery and also the cord I had plugged in use for charging and I did that then I was asked to hold down the power button for a two minutes which I did and then plug back in the power cord and see if it boots up, and once again know function of my pc if you would please assist, I would greatly appreciate it.
Thank you
Gerald
mimg@urassociation.com
  • gpmccoy Aug 13, 2008
    I appreciate the help and your timely response. Would you gather that this would be a costly expense.
    Thanks
  • Anonymous Dec 14, 2008
    I have same problem in my laptop. Can u help me?
    Scholar:
  • 53 Answers
Once you can try connecting the external monitor to the notebook and check the display on the external screen.
Conect the Desktop computer monitor to the notebook VGA port and press Fn+F4 to see the display on the external monitor, if there is display on the external monitor, then the issue is with the notebook screen.
If there is no display on the external then the issue could be with the motherboard itself.
If you send the notebook to HP, then you will be charged $398 for motherboard repair.
So, I suggest you to check at local service center, if they ask you for more than $398, then you can send it to HP by contacting Hp Chat support. Shipping charges includes in $398
Posted on Aug 13, 2008
    Champion:
  • 221 Answers
I would venture to guess a motherboard failure. I would have it replaced/ repaired by HP if it's still under warranty
  • Suvvy Roy Aug 13, 2008
    if your computer is under warranty, then it will be free
Can i charge my hp pavillion dv1000 from my desktop through a usb port?
NO! You will damage one or both computers. You really need to repair the laptop or ac adapter to correct the charging problem. The HP dv 1000 as well as the other HP entertainment laptops have had a lot of problems. Not charging just one of them. I would strongly suggest a professional repair of this laptop.
Apr 01, 2011 | Computers & Internet
Plugged in, not charging hp pavillion dv-7
power lights.. is that coming on the charger??? if so
remove the battery and put it back
then try... if not working\\contact HP
Mar 16, 2011 | HP Pavilion dv7-1468nr Notebook
The charging indicator light no longer comes on when the laptop is plugged in. Just replaced the battery. Also tried a different power cord.
Possibly a failed or damaged charging port (does it feel loose)? After that, charger may not be chucking out the voltage (19.5 volts)? Test with multimeter set to DV volts, with one probe on the inside of the plug ant the other on the outside.
Does the charger LED light blink when connected (sign that power is not making a circuit)
If the above fail to work, then the problem is with the connector on the mobo, this may just be a Charger port needing replacing (wired or soldered version), or the charging circuit of the motherboard gone
Feb 10, 2011 | HP Pavillion DV6227 Notebook
How cain i connect my laptop Hp pavillion dv 1000 to TV
you can purchase a usb device with TV outputs. look on ebay or purchase one from your local PC retail shop.
Apr 16, 2010 | HP Pavilion dv1000 Notebook
HP Pavillion dv-51235dx not charging
please check the charger is fit or not
Mar 05, 2010 | HP Pavilion dv6000z Notebook
MY HP PAVILLION DV 1000 HAS NO SOUND DEVICE NOW
Below is a link to download the sound drivers for your laptop. Download, install and reboot and everything shoud be fine.
ftp://ftp.hp.com/pub/softpaq/sp28001-28500/sp28481.exe
Jan 22, 2010 | HP Pavilion dv1000 Notebook
Laptop turns off when charger is plugged in !!
Charger is bad and is not putting out the correct voltage which causes the computer to shut down. Battery probably isn't much good either if it only lasts for one hour. Get new batter and charger. Ebay'ers will help you find one cheap.
Jun 01, 2009 | HP Pavilion dv1000 Notebook
My red xbox 360 controller wont charge with the included play and charge kit after i turn off my console, it works if i do it as soon as it dies but not if ive played for a little while and then turn it...
Basically an xbox battery has a built in 'memory' that it tells the xbox how much charge is in it and the problem with rechargable batteries is that if they're not used for a while and left at room temperature their charge begins to dissipate so when you plug it in the battery 'thinks' it's charged and tells the xbox the same when in truth it's not. What to do is keep plugging and unplugging the charger on top (waiting until the light comes on) until the charger light stays red (as opposed to going red then immediately green) the small amounts of charge put in each time will eventually give the battery enough juice to clue it as to just how much power it REALLY has in and will then start charging as normal.
Apr 25, 2009 | Microsoft Xbox 360 Controller
How do you charge a DV 1000 hp pavillion laptop?
plug in the power adapter, make sure the battery is installed firmly, let it run for 6 to 10 hours..hopefully the battery, installed under the unit, will be fresh enough to accept a recharge cycle.
got backup for that computer?
Feb 19, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
335 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
